I can successfully update parameter=8 through the habmin gui and the device goes into the correct operating mode, but when I use a bound item to the channel it does not affect the device. It does reflect the correct value in habmin when I update the channel directly.
Here is the debug log when I send number 0 to the channel: (node 96)
2018-01-21 21:20:28.732 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 96: Command received zwave:device:de0bde91:node96:config_decimal_param8 --> 0
2018-01-21 21:20:28.740 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 96: Creating new message for application command CONFIGURATION_SET
2018-01-21 21:20:28.743 [DEBUG] [ommandClassTransactionPayloadBuilder] - At build null
2018-01-21 21:20:28.745 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 96: Creating new message for application command CONFIGURATIONCMD_GET
2018-01-21 21:20:28.747 [DEBUG] [ommandClassTransactionPayloadBuilder] - At build COMMAND_CLASS_CONFIGURATION
2018-01-21 21:20:28.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: Adding to device queue
2018-01-21 21:20:28.751 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: Added to queue - size 4
2018-01-21 21:20:28.753 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2018-01-21 21:20:28.755 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: listening == false, frequentlyListening == false, awake == false
2018-01-21 21:20:28.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Node not awake!
2018-01-21 21:20:28.759 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: listening == false, frequentlyListening == false, awake == false
2018-01-21 21:20:28.761 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Node not awake!
2018-01-21 21:20:28.763 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 89: listening == false, frequentlyListening == false, awake == false
2018-01-21 21:20:28.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 89: Node not awake!
2018-01-21 21:20:28.766 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 96: listening == false, frequentlyListening == true, awake == false
2018-01-21 21:20:28.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from sendQueue
2018-01-21 21:20:28.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2018-01-21 21:20:28.779 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2018-01-21 21:20:28.780 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-01-21 21:20:28.780 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-01-21 21:20:28.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-01-21 21:20:28.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-01-21 21:20:28.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2018-01-21 21:20:28.783 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-01-21 21:20:28.784 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2018-01-21 21:20:28.800 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2018-01-21 21:20:28.803 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: Transaction Start type SendData
2018-01-21 21:20:28.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1354: [WAIT_RESPONSE] requiresResponse=false callback: 136
2018-01-21 21:20:28.807 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: null
2018-01-21 21:20:28.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: 0
2018-01-21 21:20:28.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2018-01-21 21:20:28.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:30 EST 2018 - 2000ms
2018-01-21 21:20:28.816 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 1354: [WAIT_RESPONSE] requiresResponse=false callback: 136
2018-01-21 21:20:28.818 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:28.820 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:30 EST 2018 - 1993ms
2018-01-21 21:20:28.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2018-01-21 21:20:28.823 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:28.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:30 EST 2018 - 1990ms
2018-01-21 21:20:28.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: Adding to device queue
2018-01-21 21:20:28.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: Added to queue - size 4
2018-01-21 21:20:28.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2018-01-21 21:20:28.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2018-01-21 21:20:28.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:28.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:30 EST 2018 - 1984ms
2018-01-21 21:20:28.831 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:28.831 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:28.832 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:28.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1354: [WAIT_RESPONSE] requiresResponse=false callback: 136
2018-01-21 21:20:28.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-01-21 21:20:28.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1354: [WAIT_RESPONSE] requiresResponse=false callback: 136
2018-01-21 21:20:28.835 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:28.836 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 96: sentData successfully placed on stack.
2018-01-21 21:20:28.836 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance ST: WAIT_RESPONSE
2018-01-21 21:20:28.837 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance WT: null {}
2018-01-21 21:20:28.838 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance RX: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:28.838 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance TO: WAIT_REQUEST
2018-01-21 21:20:28.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1354: Advanced to WAIT_REQUEST
2018-01-21 21:20:28.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: TID 1354: Transaction not completed
2018-01-21 21:20:28.906 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-01-21 21:20:28.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2018-01-21 21:20:28.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2018-01-21 21:20:28.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:28.913 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:33 EST 2018 - 4927ms
2018-01-21 21:20:30.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=136, payload=88 00 00 83
2018-01-21 21:20:30.122 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=136, payload=88 00 00 83
2018-01-21 21:20:30.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=136, payload=88 00 00 83
2018-01-21 21:20:30.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1354: [WAIT_REQUEST] requiresResponse=false callback: 136
2018-01-21 21:20:30.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-01-21 21:20:30.126 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1354: [WAIT_REQUEST] requiresResponse=false callback: 136
2018-01-21 21:20:30.126 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 1354: (Callback 136)
2018-01-21 21:20:30.127 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2018-01-21 21:20:30.128 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 1354: callback 136
2018-01-21 21:20:30.129 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=136, payload=88 00 00 83
2018-01-21 21:20:30.130 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 96: SendData Request. CallBack ID = 136, Status = Transmission complete and ACK received(0)
2018-01-21 21:20:30.131 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 96: resetResendCount initComplete=true isDead=false
2018-01-21 21:20:30.131 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: Transaction COMPLETED
2018-01-21 21:20:30.132 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance ST: DONE
2018-01-21 21:20:30.132 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance WT: null {}
2018-01-21 21:20:30.133 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance RX: Message: class=SendData[19], type=Request[0], dest=0, callback=136, payload=88 00 00 83
2018-01-21 21:20:30.134 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1354: TransactionAdvance TO: DONE
2018-01-21 21:20:30.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: Response processed after 1332ms
2018-01-21 21:20:30.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: TID 1354: Transaction completed
2018-01-21 21:20:30.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: notifyTransactionResponse TID:1354 DONE
2018-01-21 21:20:30.136 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-01-21 21:20:30.137 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 96: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-01-21 21:20:30.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-01-21 21:20:30.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2018-01-21 21:20:30.139 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 62: listening == false, frequentlyListening == false, awake == false
2018-01-21 21:20:30.140 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 62: Node not awake!
2018-01-21 21:20:30.141 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 10: listening == false, frequentlyListening == false, awake == false
2018-01-21 21:20:30.141 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 10: Node not awake!
2018-01-21 21:20:30.142 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 89: listening == false, frequentlyListening == false, awake == false
2018-01-21 21:20:30.142 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 89: Node not awake!
2018-01-21 21:20:30.143 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 96: listening == false, frequentlyListening == true, awake == false
2018-01-21 21:20:30.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from sendQueue
2018-01-21 21:20:30.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2018-01-21 21:20:30.145 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = redacted
2018-01-21 21:20:30.146 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 96: Sending REQUEST Message = redacted
2018-01-21 21:20:30.149 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2018-01-21 21:20:30.151 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-01-21 21:20:30.153 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-01-21 21:20:30.155 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = redacted
2018-01-21 21:20:30.170 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2018-01-21 21:20:30.171 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: Transaction Start type SendData
2018-01-21 21:20:30.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1355: [WAIT_RESPONSE] requiresResponse=false callback: 137
2018-01-21 21:20:30.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: COMMAND_CLASS_CONFIGURATION
2018-01-21 21:20:30.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: 6
2018-01-21 21:20:30.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2018-01-21 21:20:30.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:30.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:32 EST 2018 - 1999ms
2018-01-21 21:20:30.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 1355: [WAIT_RESPONSE] requiresResponse=false callback: 137
2018-01-21 21:20:30.178 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:30.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:32 EST 2018 - 1996ms
2018-01-21 21:20:30.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2018-01-21 21:20:30.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1355: [WAIT_RESPONSE] requiresResponse=false callback: 137
2018-01-21 21:20:30.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2018-01-21 21:20:30.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-01-21 21:20:30.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2018-01-21 21:20:30.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2018-01-21 21:20:30.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:30.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:32 EST 2018 - 1990ms
2018-01-21 21:20:30.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:30.202 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:30.204 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:30.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1355: [WAIT_RESPONSE] requiresResponse=false callback: 137
2018-01-21 21:20:30.205 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = redacted
2018-01-21 21:20:30.206 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-01-21 21:20:30.207 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1355: [WAIT_RESPONSE] requiresResponse=false callback: 137
2018-01-21 21:20:30.208 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:30.209 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 96: sentData successfully placed on stack.
2018-01-21 21:20:30.210 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance ST: WAIT_RESPONSE
2018-01-21 21:20:30.211 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance WT: ApplicationCommandHandler {}
2018-01-21 21:20:30.212 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance RX: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2018-01-21 21:20:30.212 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance TO: WAIT_REQUEST
2018-01-21 21:20:30.213 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1355: Advanced to WAIT_REQUEST
2018-01-21 21:20:30.214 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: TID 1355: Transaction not completed
2018-01-21 21:20:30.215 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-01-21 21:20:30.215 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2018-01-21 21:20:30.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2018-01-21 21:20:30.217 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2018-01-21 21:20:30.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Sun Jan 21 21:20:35 EST 2018 - 4996ms
2018-01-21 21:20:30.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=137, payload=redacted
2018-01-21 21:20:30.233 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=137, payload=redacted
2018-01-21 21:20:30.242 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=137, payload=redacted
2018-01-21 21:20:30.243 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1355: [WAIT_REQUEST] requiresResponse=false callback: 137
2018-01-21 21:20:30.244 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2018-01-21 21:20:30.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1355: [WAIT_REQUEST] requiresResponse=false callback: 137
2018-01-21 21:20:30.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 1355: (Callback 137)
2018-01-21 21:20:30.247 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2018-01-21 21:20:30.248 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 1355: callback 137
2018-01-21 21:20:30.249 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=137, payload=89 00 00 02
2018-01-21 21:20:30.251 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 96: SendData Request. CallBack ID = 137, Status = Transmission complete and ACK received(0)
2018-01-21 21:20:30.252 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 96: resetResendCount initComplete=true isDead=false
2018-01-21 21:20:30.253 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance ST: WAIT_REQUEST
2018-01-21 21:20:30.254 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance WT: ApplicationCommandHandler {}
2018-01-21 21:20:30.255 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance RX: Message: class=SendData[19], type=Request[0], dest=0, callback=137, payload=redacted
2018-01-21 21:20:30.256 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance RQ: RREQ=false, RCLS=ApplicationCommandHandler
2018-01-21 21:20:30.257 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1355: TransactionAdvance TO: DONE
2018-01-21 21:20:30.258 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1355: Advanced to DONE
2018-01-21 21:20:30.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: Response processed after 88ms
2018-01-21 21:20:30.260 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: TID 1355: Transaction completed
2018-01-21 21:20:30.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 96: notifyTransactionResponse TID:1355 DONE
2018-01-21 21:20:30.263 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-01-21 21:20:30.265 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 96: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-01-21 21:20:30.266 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-01-21 21:20:30.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2018-01-21 21:20:30.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2018-01-21 21:20:30.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2018-01-21 21:20:30.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
Here is the log while I update directly from the habmin configuration paramaters field to “vacation” (2):
