I have two issues:
Primary issue is that my HS WD100 dimmer switch is not “Node is not communicating with controller”(Habmin and PaperUI)
I’ve tried multiple remedies other than trying new physical switch. It physically works fine. I’m running OH2.5 Snapshot and updated recently. I’ve tried following somes instruction on removing the device(exclusion) from controller but it doesn’t seem to work. Everytime I remove the device, it keeps showing back up when I try to add it without pressing any button on the switch.
I’m stuck. Here’s a log excerpt: (I forget how to format the log to get it work with with Chris’s log viewer)
2019-03-10 19:57:53.712 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:15da5b25003’ has been updated.
2019-03-10 19:58:02.065 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:15da5b25003:node4’ has been updated.
2019-03-10 19:58:09.891 [hingStatusInfoChangedEvent] - ‘zwave:device:15da5b25003:node4’ changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to UNINITIALIZED
2019-03-10 19:58:10.056 [hingStatusInfoChangedEvent] - ‘zwave:device:15da5b25003:node4’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-03-10 19:58:19.221 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node12’ has been removed.
2019-03-10 19:58:19.232 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node10’ has been removed.
2019-03-10 19:58:19.243 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node13’ has been removed.
2019-03-10 19:58:19.248 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node11’ has been removed.
2019-03-10 19:58:29.185 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node4’ has been added.
2019-03-10 19:58:29.185 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:15da5b25003:node4’ to inbox.
2019-03-10 19:58:29.210 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:15da5b25003:node10’ to inbox.
2019-03-10 19:58:29.210 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node10’ has been added.
2019-03-10 19:58:29.277 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:15da5b25003:node11’ to inbox.
2019-03-10 19:58:29.281 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node11’ has been added.
2019-03-10 19:58:29.293 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 12: Device discovery could not resolve to a thingType! Manufacturer data not known.
2019-03-10 19:58:29.299 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:15da5b25003:node12’ to inbox.
2019-03-10 19:58:29.305 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node12’ has been added.
2019-03-10 19:58:29.306 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 13: Device discovery could not resolve to a thingType! Manufacturer data not known.
2019-03-10 19:58:29.311 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:15da5b25003:node13’ to inbox.
2019-03-10 19:58:29.314 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node13’ has been added.
2019-03-10 19:58:45.687 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:15da5b25003:node4’ has been removed.
2019-03-10 19:58:45.722 [hingStatusInfoChangedEvent] - ‘zwave:device:15da5b25003:node4’ changed from UNINITIALIZED to INITIALIZING
2019-03-10 19:58:45.728 [hingStatusInfoChangedEvent] - ‘zwave:device:15da5b25003:node4’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-03-10 19:58:45.734 [hingStatusInfoChangedEvent] - ‘zwave:device:15da5b25003:node4’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
2019-03-10 19:58:45.737 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:15da5b25003:node4’ has been updated.
2019-03-10 19:58:45.751 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:15da5b25003:node4’ has been updated.
2019-03-10 19:58:45.753 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:15da5b25003:node4’ has been updated.
2019-03-10 19:58:45.824 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:15da5b25003:node4’ has been updated.
(Edit: I did a hardware reset on my Aeotec Z Stick and that resolved my problem, but a somewhat drastic solution)
