I am running a pi with the Z-Wave ZME_UZB1 Me USB Stick and did not have big problems yet.
However, recently I have experienced that the USB stick used a different port after a power failure in our neighborhood (I did not even touch the pi, nor the stick
Usually itâs ttyACM0: [ 5.443830] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
After the power failure I got:
openhab.log: Serial Error: Port /dev/ttyACM0 does not exist
and:
[51029.137224] cdc_acm 1-1.5:1.0: ttyACM1: USB ACM device
After a reboot it was fine again.
How to make sure that this does not happpen again!?
I guess I need some help with it.
I created /etc/udev/rules.d/50-usb-serial.rules
with (according to my devices) - which I know from lsusb and dmesg
SUBSYSTEM==âttyâ, ATTRS{idVendor}==â0658â, ATTRS{idProduct}==â0200â, SYMLINK+=âUSB_zwaveâ, GROUP=âdialoutâ, MODE=â0666â
SUBSYSTEM==âttyâ, ATTRS{idVendor}==â0a5câ, ATTRS{idProduct}==â2122â, SYMLINK+=âUSB_btâ, GROUP=âdialoutâ, MODE=â0666â
I also changed openhab.cfg accordingly: zwave:port=/dev/USB_zwave
Finally I added to /etc/init.d/openhab (as parameter below JAVA_ARGS_DEFAULT="-Dosgi.clean=true
-Dgnu.io.rxtx.SerialPorts=/dev/USB_bt:/dev/USB_zwave
But I get an error in the openhab.log:
Serial Error: Port /dev/USB_zwave does not exist
But I can see it:
lrwxrwxrwx 1 root root 7 Jan 1 1970 /dev/USB_zwave -> ttyACM0
Did I miss something obvious?
The owner of the Symlink above is root:root, but the ttyACM0 itself belongs to the dialout group.
I cannot change the group to dialout for the Symlink - might this be the problem?
By the way:
In the beginning I did not have access to ttyACM0 (as openhab), so I added the openhab user to the dialout group.
This fixed the problem with the device itself.
So whatâs the problem with the Symlink then?
I have the same error in my log, my USB is on port /dev/ttyUSB0, which is how it is listed in the openhab.cfg and I am getting the same error in my log as well, âPort /dev/ttyUSB0 does not existâ. I can see it:
crw-rw---- 1 root dialout 188, 0 Dec 1 21:01 ttyUSB0
Iâm not sure this is an issue with openhab. This sort of issue is more a system issue with the environment so itâs not easy to suggest how to help, and thereâs nothing that can be done in openhab itself if the operating system is changing the port idsâŠ
Symlinks are the solution under linux at least, but I agree - they arenât easy to configure, and in my experience, arenât always successful.
I appreciate the message and I donât want to get off topic or a tangent. When I cat sudo cat USB_zwave and move in front of a zwave motion sensor, I see output coming through to the console. So, it seems the OS and symlink are directing output properly? My guess is that some property/configuration/?? in openhab isnât properly reading from this symlink.
I added -Dgnu.io.rxtx.SerialPorts=/dev/USB_zwave but it seems that kind of property isnât enough/workingâŠ
Iâm not an expert in this, so sorry if this is a stupid statement - if you are using âcat USB_zwaveâ, rather than /dev/USB_zwave, then maybe the command line arg shouldnât have the /dev on the front?
At the end of the day, thereâs not much that we can change in OH. The zwave binding uses a serial driver, and the serial driver is reading the command line parameters directly, so all you can change in OH is the command line parameter, and the port setting in the config file.
Having just dealt with this issue, I wanted to post my solution which seems missing in this thread. In addition to the udev rule to add a symlink to whatever the node gets named you need to convince openhab that the new serial link is a valid port. By default it only wants to see tty* nodes. So add it to the extra java opts:
