Maybe It’s necessary to change endpoints IDs in zwave database ( endpoint 0 renamed to 1 , 1 to 2 and 2 to 3).
Please do not do this as it’s likely to cause (big!) problems.
@chris Ok, Bad idea about changing endpoints ids.![]()
Because I don’t have any relay i can’t see the behaviors explined by @Alexus1211
In reference to the status updates for our qubino smartmeter, maybe the problem is related to this post
As Allen explains, in the channel settings of the device, Association group field generally is blank, and if I try to add the controller to Group 1 / Lifeline it vanishes again at some point.
With no lifeline association with controller, updates are not going to work…??
