It seems the current database entry for the Radio Thermostat CT80 is the CT30 entry. There are several items missing that would be very helpful. The documentation for the conmfiguration can be found at http://products.z-wavealliance.org/MarketCertification/File?folder=&filename=MarketCertificationFiles/1046/RTZW-02_module_IB_9jun14.pdf
Most significantly I am looking to be able to toggle simple mode(parameter 11).
I also suspect there are issues with the transmitting of humidity based on the association configuration. The manual discusses the need for the association commands to be encapsulated in order for the humidity sensor reports to be transmitted.
