Buy z-stick Gen 5 of Aeon, insert it into a USB port but not what is his / tty because if I can help. Try this on Windows and knew which was the port COM port but habmin not recognize the z-stick GEN 5 Aeon.
Its hard to tell what you are asking but I’m going to guess that you can’t figure out which /dev/tty the stick is showing up on.
In all likelihood it is /dev/ttyUSB0 but you can tell by doing an ls /dev/tty*
before plugging it in and then a /dev/tty*
after plugging it in and see what’s new.
I think the Gen 5 ends up on /dev/ttyACMx.
is /dev/ttyACM0.
thanks
