- Platform information:
- Hardware: Raspberry Pi 4 8GB
- OS: Official docker image
- openHAB version: 3.1.0 M3
- Issue of the topic:
A few months back I excluded a bunch of GE zwave switches and replaced them with Inovelli and I just recently started playing with some of the more advanced capabilities like setting default local level on the dimmers at different times (example 50% at night, 99% at sunrise) and the scene functionality and i’ve noticed a few things. Mainly these:
Default level doesn’t always change on the switch even though it’s changed in the thing channel and device configuration
I put all the “scene” items for dimmers into a group and set up this rule to start using the same base name with a different suffix (example BathroomSwitch_Scene, BathroomSwitch_Dimmer)
UPx1 = "2.0"
UPRELEASE = "2.1"
UPHOLD = "2.2"
UPx2 = "2.3"
UPx3 = "2.4"
UPx4 = "2.5"
DOWNx1 = "1.0"
DOWNRELEASE = "1.1"
DOWNHOLD = "1.2"
DOWNx2 = "1.3"
DOWNx3 = "1.4"
DOWNx4 = "1.5"
if str(ir.getItem(event.itemName).type) != "Group":
item = event.itemName
dimmer = event.itemName.split("_")[0] + "_Dimmer"
sceneNumber = str(ir.getItem(event.itemName).state)
if (sceneNumber == UPx2):
events.sendCommand(dimmer,"100")
# Reset scene to 0
events.sendCommand(item,"0")
I’ve noticed that the rule fires right away and sends the 100 right away on the dimmer up double click as I would expect but for the actual light to change there’s a delay of anywhere from about a second to 5 or more seconds
I also have a “goodnight” rule that’s pretty simple, but again some lights sometimes take several seconds to respond.
events.sendCommand('MasterBathroomLight_DefaultLevelLocal', '50');
events.sendCommand('MasterToiletLight_DefaultLevelLocal', '50');
events.sendCommand('MasterDoorMotion_Armed','OFF');
events.sendCommand('MasterGlassDoorMotion_Armed','OFF');
events.sendCommand('BedLamps_Toggle','OFF')
events.sendCommand('MasterBathroomLight_Dimmer','OFF')
events.sendCommand('MasterToiletLight_Dimmer','OFF')
events.sendCommand('MasterToiletFan_Switch','OFF')
events.sendCommand('MasterClosetLight_Switch','OFF')
events.sendCommand('AlarmStatus','ARMED_HOME')
events.sendCommand('GAllOff', 'OFF');
events.sendCommand('GuestBathroomFan_Switch', 'OFF');
events.sendCommand('GuestBathroomLight_Dimmer', 'OFF');
events.sendCommand('GuestBathroomLight_DefaultLevelLocal', '50');
events.sendCommand('HallBathLights_DefaultLevelLocal', '50');
events.sendCommand('HallBathLights_Dimmer', 'OFF');
Looking at debug logs (attached), I see for example in my scene test this in the zwave log viewer on opensmarthouse when testing on node 89
09:16:23.055 89 RX REQ SendData 113 ACK RECEIVED from device in 4084ms
and similar long “ack received” messages in my “goodnight” rule run as well for some devices. I’m thinking this can’t be normal behavior but I don’t know if it’s the switches that are slow in responding or if there is a wider network issue that I need to address. I seem to recall maybe having slow responding issues in the “goodnight” rule for long before the switch to Inovelli so I think it might be a wider network issue but I am not sure where it could be.
Here are the shortened logs for those two times, but I have also posted extensive debug logs starting from when I turned on debug and restarted the binding yesterday morning until now here if anyone needs a bigger picture.
zwave_goodnight.log (887.8 KB)
zwave_scene.log (533.4 KB)
Any ideas?
