trumee
(trumee)
September 26, 2017, 1:08am
1
@chris I have a Zooz Zen23 switch which unfortunately isnt recognized by Openhab. PaperUI reports it as
zwave_class_basic ROUTING_SLAVE
zwave_class_generic BINARY_SWITCH
zwave_frequent false
zwave_neighbours
zwave_version 20.15
zwave_listening false
zwave_plus_devicetype UNKNOWN_TYPE
zwave_deviceid 9500
zwave_nodeid 13
zwave_routing false
zwave_beaming false
zwave_class_specific POWER_SWITCH_BINARY
zwave_manufacturer 634
zwave_devicetype 45329
Is there any way to make it to work?
chris
(Chris Jackson)
September 26, 2017, 6:50am
2
I’ve added it to the database - I’m assuming it’s the same as already included and not something new…
Chris
trumee
(trumee)
September 26, 2017, 12:55pm
3
Thank. Do i need to download the nightly zwave bindings file?
chris
(Chris Jackson)
September 26, 2017, 1:11pm
4
You will, but I first need to do a database export which I probably won’t do until tomorrow as I’m travelling tonight .
Sorry for my ignorance, I’m still learning at a snails pace. When you do the data export, what do I need to do from my pi running 2.4 snapshot to get the database in with the switch you put in, I just got one as well.
Thanks!
trumee
(trumee)
September 29, 2017, 12:14pm
6
@chris is this in the nightly build now?
chris
(Chris Jackson)
September 29, 2017, 12:46pm
7
I have not had a chance to update the database over the past few days as I’ve been travelling. I’ll take a look tonight hopefully.
trumee
(trumee)
September 30, 2017, 1:29pm
8
@chris instead of polling you , is it possible to look into the jar file to see whether the device is in there ?
chris
(Chris Jackson)
September 30, 2017, 1:39pm
9
Probably not easily. You can get a list of the devices, but it doesn’t give you the device IDs in this list.
In any case, it was been added, so no need to poll .
trumee
(trumee)
September 30, 2017, 3:13pm
10
I updated the Zwave binding,
216 | Active | 80 | 2.2.0.201709301118 | ZWave Binding
But still the device is not in the database?
chris
(Chris Jackson)
September 30, 2017, 3:15pm
11
I’ve just kicked off a rebuild - try again in 30 minutes or so.
trumee
(trumee)
September 30, 2017, 4:11pm
12
Thanks it is working well now. The Zooz documentation mentions the following:
Toggle Control
Parameter 1: Choose if you want the to
turn the light on by clicking the toggle up
or down
Values: 0 – Toggle up turns the light on,
toggle down turns the light off (default);
1 – Toggle up turns the light off, toggle
down turns the light on
Size: 1 byte dec.
I dont see this in the settings of the device. Is this something which is not supported right now?
chris
(Chris Jackson)
September 30, 2017, 4:13pm
13
It looks like there are no parameters currently in the database, so yes, at the moment it’s not supported .
