I have no text file at all referencing rest docs but get this error constantly through all the versions since over a month (since I took notice of it).
Can that be any relic from an old version? I am using OpenHAB on this instance since 2.1.
I have the same problem, although with openhab-action-mail.
This is different from the original issue. You probably didn‘t notice that the mail-Action has Been moved to the legacy addons and is replaced by a new mail binding. You need to enable „legacy addons“ to use it.
Yes, I know. Is there a way to remove ‘mail-Action’? I have not found a way yet, neither in Paper UI nor in the carafe console. I cannot find ‘mail-Action’ in bundle:list.
How did you install it originally? Probably in addons.cfg?
Nope, neither 'services\addons.cfg nor ‘addons.config’ was not used.
I had the same problem with 2.5.0.M2 and Mail-Action.
I got the problem solved after enabling Legacy v1.x Binding Support.
Then I could UNINSTALL the old Mail-Action Bindings.
I have this same issue. Can’t find a 1.X version to install to remove, it was never in my addons.cfg. On 2.4M4.
You meen 2.5M4? I just did as described above with great success, remove the line misc=“restdocs” from addons.conf:
solved it! Thx
Worked for me - much appreciated!
Same situation here. addons.cfg is fully commented. Can’t find the Legacy version to remove the old openhab-misc-restdocs. On 2.5_M5
I bet you have addons.config in folder
/var/lib/openhab2/config/org/openhab/
or
/userdata/config/org/openhab/
Please check the misc and legacy entries inside this file.
And it does not exist a legacy version of restdocs. In above mentioned post the author said, that he could not install or uninstall a legacy binding or action, because it was set legacy=false in addons.config.
Thanks for the suggestions @Celaeno1
I got this fixed.
The only copy is under conf/services:
openhab@pi-openhab> find . -name “addons.cfg”
./conf/services/addons.cfg
The file is essentially empty, as every line is commented:
# See https://www.openhab.org/docs/configuration/packages.html for a detailed explanation of these packages.
#package = minimal
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
#remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
#legacy = true
# A comma-separated list of bindings to install (e.g. "binding = sonos,knx,zwave")
#binding =
# A comma-separated list of UIs to install (e.g. "ui = basic,paper")
#ui =
# A comma-separated list of persistence services to install (e.g. "persistence = rrd4j,jpa")
#persistence =
# A comma-separated list of actions to install (e.g. "action = mail,pushover")
#action =
# A comma-separated list of transformation services to install (e.g. "transformation = map,jsonpath")
#transformation =
# A comma-separated list of voice services to install (e.g. "voice = marytts,freetts")
#voice =
# A comma-separated list of miscellaneous services to install (e.g. "misc = myopenhab")
#misc =
The solution was to uncomment the misc line and add the misc bindings I want to keep (I only use openhabcloud), like this:
misc = openhabcloud
Then restart. No more openhab-misc-restdoc errors after that
Perhaps this is what was being suggested all along and I just didn’t interpret it correctly.
Thanks for the help!
Dave
Thank you! I spent hours on this annoyance.
BUT it’s kludgey. I too added a redundant binding to misc= to “solve” the problem. I think it’s only a matter of time before this “fix” comes back to bite me.
You probably shouldn’t add any add-ons to services/addons.cfg if you’ve installed them all using the UI. If you do it will probably uninstall all add-ons that were previously installed using the UI.
The best way to prevent this for users that install add-ons using the UI is to uninstall the REST docs before updating. See Breaking Changes in the 2.5.0 release notes.
Thanks.
I followed a tutorial that recommended specifying bindings within addons.cfg rather than using paper UI, with a caveat about paper UI-installed bindings being removed.
I added misc = market to addons.cfg and haven’t seen any adverse effects in Paper UI.
Remembering to uninstall the REST docs before updating is something I would certainly forget to do. I’d guess that most people would not uninstall the docs either.
Yes this shouldn’t be standard procedure so that’s why it’s added to the release notes. It’s the first item in the breaking changes list so it should have a lot of exposure to users that read it. Let’s hope many users doing the upgrade don’t end up here. ![]()
So, here I am, getting the same error
2019-12-30 18:29:18.836 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs’
just after upgrading to 2.5 5 minutes ago.
Just the short version: what do I have to do now?
PS here is my addons.config file:
:org.apache.felix.configadmin.revision:=L"1"
binding="http1,mqtt1,homematic,hue,samsungtv,astro,amazonechocontrol,miio"
felix.fileinstall.filename="file:/var/lib/openhab2/etc/org.openhab.addons.cfg"
legacy=B"true"
misc="restdocs,openhabcloud,market,ruleengine"
package="standard"
persistence="influxdb"
remote=B"true"
service.pid="org.openhab.addons"
transformation="jsonpath,map,exec"
ui="basic,paper,habpanel,homebuilder,restdocs"
Just removing the “restdocs” from the “misc” line should do it
