Hi, I just installed version 2.2.0.006-SNAPSHOT-WIP spk on a DS3617xs. I selected the third option for the configuration files (I cannot check now what it was) as I had a previous installation there and it completely deleted my Disk. The OS partition I mean. I cannot access even the disk via http or ssh, even after a hard reboot. I will have to contact Synology on how to recover from this.
Please remove this package from the web page until you find out what is causing this.
I recommend that you open up an issue on the project’s github page (along with any additional debug info that you may have and the response from Synology support)
It is unfortunate that you had this problem… I hope that you will be able to recover your DSM partition…
I know that this may sound silly but… the package is marked as WIP and I would never put it on massive production machine (DS3617xs) with my live NAS data…
I did noticed the WIP, but “in my defense” I tried to install the oficial 2.1 when it came out and that broke the installation. I could not go back to 2.0 because it was also broken or it did not wroked after having installed 2.1, so I went to a 2.2 patch 2 WIP which worked. When a saw a newer version (closer to a final release) I installed it because I was not happy being in a beta version and I assumed that patch 6 was closer to a final version than patch 2.
I learned my leason though. I will move to another automation software. openHAB clearly does not put enough interest in the Synology release.
