restarted, it still does not work
Have you configured your com port in the binding settings?
Could you also please double check what versions are you running?
In the karaf console runs this:
bundle:list | grep bluetooth
openhab>
openhab> bundle:list | grep bluetooth
203 | Active | 80 | 1.1.0 | org.sputnikdev:org.eclipse.smarthome.binding.bluetooth.transport.bluegi
204 | Waiting | 80 | 1.1.0 | org.sputnikdev:org.eclipse.smarthome.binding.bluetooth
openhab>
openhab>
openhab>
Do you still see that error in the log after restarting your OH?
2018-03-01 15:50:02.101 [WARN ] [ace.internal.BindingExtensionHandler] - Installed bundle, but failed to start it: Could not resolve module: org.sputnikdev.org.eclipse.smarthome.binding.bluetooth.transport.bluegiga [203]
Unresolved requirement: Import-Package: org.sputnikdev.bluetooth
installed on another computer with a clean openHab - the same effect
I installed version 1.1 of your binding today.
I have the same problems!
2018-03-01 19:29:38.733 [ERROR] [.eclipse.smarthome.binding.bluetooth] - [binding.bluetooth(274)] The activate method has thrown an exception
java.lang.IllegalStateException: GATT spec registry file is missing
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.readRegistryFromClassPath(BluetoothGattSpecificationReader.java:426) [260:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.0]
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.readServicesRegistryFromClassPath(BluetoothGattSpecificationReader.java:257) [260:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.0]
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.<init>(BluetoothGattSpecificationReader.java:96) [260:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.0]
at org.sputnikdev.bluetooth.gattparser.BluetoothGattParserFactory.getSpecificationReader(BluetoothGattParserFactory.java:59) [260:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.0]
at org.sputnikdev.bluetooth.gattparser.BluetoothGattParserFactory.getDefault(BluetoothGattParserFactory.java:74) [260:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.0]
at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.getGattParser(BluetoothHandlerFactory.java:131) [260:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.0]
at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.activate(BluetoothHandlerFactory.java:58) [260:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.0]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [44:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1829) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:395) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:375) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:291) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1241) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1136) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:996) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1175) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [44:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:909) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:874) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:139) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:951) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:806) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:788) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:658) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:609) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:426) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:284) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$1.configurationEvent(RegionConfigurationSupport.java:89) [44:org.apache.felix.scr:2.0.12]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:2090) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:2058) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
2018-03-01 19:29:38.740 [WARN ] [.eclipse.smarthome.binding.bluetooth] - FrameworkEvent WARNING - org.sputnikdev.org.eclipse.smarthome.binding.bluetooth
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
2018-03-01 19:29:38.751 [ERROR] [.eclipse.smarthome.binding.bluetooth] - [binding.bluetooth(274)] The activate method has thrown an exception
2018-03-01 19:29:38.757 [WARN ] [.eclipse.smarthome.binding.bluetooth] - FrameworkEvent WARNING - org.sputnikdev.org.eclipse.smarthome.binding.bluetooth
at
Hi @druciak, it is time for log files. Could you please attach log files there?
Please enable DEBUG level like that:
log:set DEBUG org.sputnikdev.bluetooth.manager.transport.tinyb
log:set DEBUG org.sputnikdev.bluetooth.manager.impl
Right… @Celaeno1 and @vizras looks like we’ve got some issues with Windows. Give me some time to try to reproduce this.
Just updated and wanted to test out my miflora sensors! Great! But the values are very high and dont seem accurate even if divide it. Is this normal? Maybe it will get better values after some time?
@Fredrik_Andersson, also from the screen I can see that your MiFlora is running an old version of firmware that does not advertise meaningful data. You will have to upgrade it via the official app.
Sorry I should have been more carefully to read the documents! It’s all explained then, thank you for that note on the firmware, I wasnt aware of that.
I want to thank you so much for this binding, this is fantastic. So much potential! It made me switch back to openhab, device tracking made easy. And all the other features! Bluetooth is on the rising!
Hi @Celaeno1 and @vizras, I think I found an issue in the binding for Windows OS. I’ll cut a new release shortly. Sorry about that guys
Hi @Celaeno1 and @vizras, I’ve cut a new release with a fix for Windows issue, could you please test it?
You will have to uninstall and install the binding. Also, it looks like the MarketPlace plugin in OpenHab does not refresh metadata often. I recommend to restart your OH so that it will refresh version number from MarketPlace.
Please make sure you are running the version with the fix:
217 │ Active │ 80 │ 1.1.0 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth.transport.bluegiga
219 │ Active │ 80 │ 1.1.0 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth.transport.tinyb
221 │ Active │ 80 │ 1.1.1 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth
Please note “1.1.1” for the binding.
Hi @vizras, I’m sorry I didn’t get that. What do you mean by “all the same” and by the screen above?
Are you saying that after an update it rests to “Nothing” for the com port?
I set the port number, click apply. When I re-enter the settings, the Regular expression for BlueGiga adapters autodiscovery (serial ports) field - NOTHING
Ok. This seems to me a different issue. How about the error you saw before? Did it go away?
Also please let me know what do you enter there?
