Hi All, it’s strange, but Eclipse MarketPlace has not been updated with 1.1 version. It probably requires some time to get the update through… So please wait a bit.
Hi @druciak, I’ve added “units” support in the binding in the latest release. The screenshot shows no units, e.g. °C for temperature and % for humidity. You are probably still running the old version of the binding OR you have some custom GATT specs (XML files) configured in your OH. Could you please double check:
Login in the karaf console and check what version your are running:
openhab> bundle:list | grep bluetooth
217 │ Active │ 80 │ 1.1.0 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth.transport.bluegiga
218 │ Active │ 80 │ 1.1.0 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth
219 │ Active │ 80 │ 1.1.0 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth.transport.tinyb
openhab>
You should see 1.1.0 for each component.
Remove custom GATT spec files that you may had to add before or configure the binding to use a different folder.
Let me know what information you would need and I will try to get it to you.
Also, I get this error when I start openhab
Native code library failed to load.
java.lang.UnsatisfiedLinkError: no tinyb in java.library.path
java.lang.UnsatisfiedLinkError: no javatinyb in java.library.path
Hi @Pim_Verschueren, good to know that MiScales is also working that’s the power of BT4 and Java Bluetooth Manager. There is not any special logic in the binding (and in the BluetoothManager) for any device. There are only some standard and customs XML GATT spec files that incapsulate all the logic in a declarative manner. GattParser takes all the hard work to process/convert bluetooth data according to GATT XML files.
Re the errors you see, those are some internal errors of the TinyB library which can be ignored.
PS. I wonder if MiScale advertises something… Can you do an experiment? Remove the thing for your scales in OH, then enable “discover unknown attributes” and then add it back again. Please do not enable “Connection control”. If it advertises something, you will see some “binary” channels get created. If there are some, it might be better to use them instead of constantly keeping connection to the scales.
Re MiKettle, could you please create a ticket here? https://github.com/sputnikdev/bluetooth-manager/issues. If you know any details about GATT characteristics or an opensource project that already support it, please post some references as well.
Thanks, Vlad
Update: could you also please post a screenshot of the MiScale thing? I would use it in the readme file for a reference. It will also probably require some tweaks for units (to display them in OH/PaperUI), e.g. kg, lb etc…
Please find the screenshots below. You can see that it does advertise the values so I think that’s what you were asking? Let me know if you want me to test anything else. I will happily do so.
Also, is there anyway we can send a command to it?
2018-03-01 15:50:02.101 [WARN ] [ace.internal.BindingExtensionHandler] - Installed bundle, but failed to start it: Could not resolve module: org.sputnikdev.org.eclipse.smarthome.binding.bluetooth.transport.bluegiga [203]
Unresolved requirement: Import-Package: org.sputnikdev.bluetooth
2018-03-01 15:50:07.814 [ERROR] [.eclipse.smarthome.binding.bluetooth] - [binding.bluetooth(184)] The activate method has thrown an exception
java.lang.IllegalStateException: GATT spec registry file is missing
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.readRegistryFromClassPath(BluetoothGattSpecificationReader.java:426) ~[?:?]
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.readServicesRegistryFromClassPath(BluetoothGattSpecificationReader.java:257) ~[?:?]
at org.sputnikdev.bluetooth.gattparser.spec.BluetoothGattSpecificationReader.(BluetoothGattSpecificationReader.java:96) ~[?:?]
at org.sputnikdev.bluetooth.gattparser.BluetoothGattParserFactory.getSpecificationReader(BluetoothGattParserFactory.java:59) ~[?:?]
at org.sputnikdev.bluetooth.gattparser.BluetoothGattParserFactory.getDefault(BluetoothGattParserFactory.java:74) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.getGattParser(BluetoothHandlerFactory.java:131) ~[?:?]
at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.activate(BluetoothHandlerFactory.java:58) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) ~[?:?]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
at org.eclipse.smarthome.extensionservice.marketplace.internal.BindingExtensionHandler.install(BindingExtensionHandler.java:82) ~[?:?]
at org.eclipse.smarthome.extensionservice.marketplace.internal.MarketplaceExtensionService.install(MarketplaceExtensionService.java:222) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.extensions.ExtensionResource.lambda$0(ExtensionResource.java:157) ~[?:?]
2018-03-01 15:50:08.051 [WARN ] [.eclipse.smarthome.binding.bluetooth] - FrameworkEvent WARNING - org.sputnikdev.org.eclipse.smarthome.binding.bluetooth
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
2018-03-01 15:50:08.062 [ERROR] [.eclipse.smarthome.binding.bluetooth] - [binding.bluetooth(184)] The activate method has thrown an exception
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) ~[?:?]
at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1714) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
2018-03-01 15:50:08.381 [WARN ] [.eclipse.smarthome.binding.bluetooth] - FrameworkEvent WARNING - org.sputnikdev.org.eclipse.smarthome.binding.bluetooth
Hi, now start watching, can you tell is there any option to turn off discovering new BT devices? Also have one question, i have Electric kettle Redmond RK-G200S, it can be operated by BT, but can’t turn it on\off via openhab, maybe you can help with it?
Hi @Pim_Verschueren, good stuff, thanks for that, but looks like this is not exactly what I wanted to see. The “Connection control” is not disabled here:
The Connection control when enabled makes the binding establish a connection to your device. When connected, it automatically discovers ALL services/characteristics of the device (basically it asks your device what services and characteristics it has, and then, the device responds on that request with a list). This is not what I meant by “advertisement”. When the device IS NOT connected, the device periodically broadcasts advertisement packets with some data (like MiFlora and Xiaomi temp and hum sensor). In other words, you don’t have to be connected to get some data from the device if the device broadcasts its data ← this is a preferable way as it requires less physical resources and does not keep connection always open make it available for other devices. Please read some details here why it is preferable not to connect to Xiaomi devices: eclipse-smarthome-bluetooth-binding/xiaomi.md at master · sputnikdev/eclipse-smarthome-bluetooth-binding · GitHub
What your screens show is not the advertisement channels, these are the channels that have been discovered by the binding when it was connected to your device. Also, I see from the screens that it is in “disconnected” state (“Connected” control is disabled), this probably means that your scales (like all other Xiaomi devices) requires the client (the binding) to do authentication first to keep connection always ON. Unfortunately Xiaomi uses a proprietary authentication protocol which is not possible at the moment to emulate with the binding. Therefore your device probably always connects and disconnects, am I right?
So if we want to find out what channels it advertises, please do this:
