I removed this bluetoothbinding + TinyB libraries, installed it again but the same error;
2018-09-02 10:40:35.933 [WARN ] [th.manager.impl.BluetoothManagerImpl] - Disposing Bluetooth manager: 798879
2018-09-02 10:40:35.986 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Loading native libraries from the bundle. Environment: linux : arm
2018-09-02 10:40:35.988 [DEBUG] [anager.transport.tinyb.NativesLoader] - OS name: linux; OS arch: arm
2018-09-02 10:40:35.991 [DEBUG] [anager.transport.tinyb.NativesLoader] - isLinux: true; isARM6: true; isX86_64: false; isX86_32: false
2018-09-02 10:40:35.993 [DEBUG] [manager.transport.tinyb.TinyBFactory] - The environment is supported.
2018-09-02 10:40:35.995 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Preparing libtinyb.so native library
2018-09-02 10:40:35.997 [DEBUG] [anager.transport.tinyb.NativesLoader] - Preparing libtinyb.so native library
2018-09-02 10:40:35.999 [DEBUG] [anager.transport.tinyb.NativesLoader] - Library path: /native/arm/armv6/libtinyb.so
2018-09-02 10:40:36.002 [DEBUG] [anager.transport.tinyb.NativesLoader] - Creating a temporary file: /var/lib/openhab2/tmp/tinyb1140987271407000815libs/libtinyb.so
2018-09-02 10:40:36.005 [DEBUG] [anager.transport.tinyb.NativesLoader] - Temporary file has been created. Copying the library to that file.
2018-09-02 10:40:36.025 [DEBUG] [anager.transport.tinyb.NativesLoader] - The library has been prepared to be loaded: /var/lib/openhab2/tmp/tinyb1140987271407000815libs/libtinyb.so
2018-09-02 10:40:36.027 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Loading libtinyb.so native library: /var/lib/openhab2/tmp/tinyb1140987271407000815libs/libtinyb.so
2018-09-02 10:40:36.033 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Could not load bundled TinyB native libraries.
java.lang.UnsatisfiedLinkError: /var/lib/openhab2/tmp/tinyb1140987271407000815libs/libtinyb.so: libglib-2.0.so.0: cannot open shared object file: No such file or directory
2018-09-02 10:40:36.042 [INFO ] [manager.transport.tinyb.TinyBFactory] - TinyB: environment is not supported out of the box. Attempting to load system libs.
2018-09-02 10:40:36.044 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Loading native library from class path: tinyb
2018-09-02 10:40:36.048 [DEBUG] [manager.transport.tinyb.TinyBFactory] - TinyB: Could not load system libraries. Thus, environemnt is not supported. Only Linux OS; x86, x86_64 and arm6 architectures are supported out of the box. Consider providing own tinyb. in one of :/var/lib/openhab2/lib:/usr/share/openhab2/runtime/lib:/usr/java/packages/lib/aarch32:/lib:/usr/lib
Update: Issue resolved by installing libglib2.0-0:armhf:
2018-09-02 10:47:26.716 [WARN ] [th.manager.impl.BluetoothManagerImpl] - Disposing Bluetooth manager: 1c286e3
2018-09-02 10:47:26.792 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Loading native libraries from the bundle. Environment: linux : arm
2018-09-02 10:47:26.794 [DEBUG] [anager.transport.tinyb.NativesLoader] - OS name: linux; OS arch: arm
2018-09-02 10:47:26.797 [DEBUG] [anager.transport.tinyb.NativesLoader] - isLinux: true; isARM6: true; isX86_64: false; isX86_32: false
2018-09-02 10:47:26.800 [DEBUG] [manager.transport.tinyb.TinyBFactory] - The environment is supported.
2018-09-02 10:47:26.802 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Preparing libtinyb.so native library
2018-09-02 10:47:26.805 [DEBUG] [anager.transport.tinyb.NativesLoader] - Preparing libtinyb.so native library
2018-09-02 10:47:26.807 [DEBUG] [anager.transport.tinyb.NativesLoader] - Library path: /native/arm/armv6/libtinyb.so
2018-09-02 10:47:26.811 [DEBUG] [anager.transport.tinyb.NativesLoader] - Creating a temporary file: /var/lib/openhab2/tmp/tinyb1496159064945801838libs/libtinyb.so
2018-09-02 10:47:26.813 [DEBUG] [anager.transport.tinyb.NativesLoader] - Temporary file has been created. Copying the library to that file.
2018-09-02 10:47:26.836 [DEBUG] [anager.transport.tinyb.NativesLoader] - The library has been prepared to be loaded: /var/lib/openhab2/tmp/tinyb1496159064945801838libs/libtinyb.so
2018-09-02 10:47:26.839 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Loading libtinyb.so native library: /var/lib/openhab2/tmp/tinyb1496159064945801838libs/libtinyb.so
2018-09-02 10:47:26.881 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Preparing libjavatinyb.so native library
2018-09-02 10:47:26.883 [DEBUG] [anager.transport.tinyb.NativesLoader] - Preparing libjavatinyb.so native library
2018-09-02 10:47:26.886 [DEBUG] [anager.transport.tinyb.NativesLoader] - Library path: /native/arm/armv6/libjavatinyb.so
2018-09-02 10:47:26.889 [DEBUG] [anager.transport.tinyb.NativesLoader] - Creating a temporary file: /var/lib/openhab2/tmp/tinyb7205049595900343527libs/libjavatinyb.so
2018-09-02 10:47:26.891 [DEBUG] [anager.transport.tinyb.NativesLoader] - Temporary file has been created. Copying the library to that file.
2018-09-02 10:47:26.902 [DEBUG] [anager.transport.tinyb.NativesLoader] - The library has been prepared to be loaded: /var/lib/openhab2/tmp/tinyb7205049595900343527libs/libjavatinyb.so
2018-09-02 10:47:26.905 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Loading libjavatinyb.so native library: /var/lib/openhab2/tmp/tinyb7205049595900343527libs/libjavatinyb.so
2018-09-02 10:47:26.909 [DEBUG] [manager.transport.tinyb.TinyBFactory] - Native libraries has been successfully loaded from the bundle.
2018-09-02 10:47:37.101 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'bluetooth:adapter:001A7DDA7113' to inbox.
BT was only working when I had bluetoothctl running in a different terminal. As soon as I exited it, BT stopped working.
It turns out that the Odroid C2 runs a too old kernel. Same issue as here. A newer kernel only exists for Ubuntu 18.04 and isn’t compatible with 16.04. There is no upgrade path from Odroid’s Ubuntu 16.04 to 18.04. So I took the opportunity to reinstall OH on a Pi 3b+ using openHABian.
Sorry for the delay… I was out for a vacation.
Yes I think this is more of a RPi issue than an issue with @vkolotov 's binding.
I’m using the on-board Wifi and BLE functionalities and as I wrote as soon as I use the binding to scan for BLE devices my complete wireless infrastructure (2.4GHz) breaks down. I wasn’t sure if this also could be related to the scan frequency or some other settings of the binding so I thought I ask the community if anyone has seen the same behaviour.
I guess I should test combination of an USB-Ethernet adapter + RPi ZeroW + on-board Bluetooth chip. So far I could not find a good USB-Ethernet adapter which can be selfpowered by the ZeroW.
Could someone help with the gatt files? The binding is picking up the Soma Blinds but does not seem to be using the gatt files and showing the rest of the characteristics
I’ve got it in a folder which has access by openhab user. Folder is alongside the items and things folders.
org.bluetooth.characteristic.blind_position.xml
<?xml version="1.0" encoding="utf-8"?><!--Copyright 2011 Bluetooth SIG, Inc. All rights reserved.-->
<Characteristic xsi:noNamespaceSchemaLocation="http://schemas.bluetooth.org/Documents/characteristic.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="Blind Position"
type="org.bluetooth.characteristic.blind_position" uuid="1525" last-modified="2011-12-05"
approved="No">
<InformativeText>
<Abstract>
Position of blinds
</Abstract>
</InformativeText>
<Value>
<Field name="Position">
<Requirement>Mandatory</Requirement>
<Format>uint8</Format>
<Unit>org.bluetooth.unit.percentage</Unit>
<Minimum>0</Minimum>
<Maximum>100</Maximum>
<Enumerations>
<Reserved start="101" end="255"/>
</Enumerations>
</Field>
</Value>
</Characteristic>
org.bluetooth.service.blind_position.xml
<Service xsi:noNamespaceSchemaLocation="http://schemas.bluetooth.org/Documents/service.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="Soma Blinds"
type="org.bluetooth.service.blind_position" uuid="1861" last-modified="2018-09-06">
<InformativeText>
<Abstract>
Soma Blinds control
</Abstract>
<Summary>
Controller for Soma Blinds
</Summary>
</InformativeText>
<Dependencies>
<Dependency>This service has no dependencies on other GATT-based services.</Dependency>
</Dependencies>
<GATTRequirements>
<Requirement subProcedure="Write Characteristic Value">Mandatory</Requirement>
<Requirement subProcedure="Notification">Mandatory</Requirement>
<Requirement subProcedure="Read Characteristic Descriptors">Mandatory</Requirement>
<Requirement subProcedure="Write Characteristic Descriptors">Mandatory</Requirement>
</GATTRequirements>
<Transports>
<Classic>false</Classic>
<LowEnergy>true</LowEnergy>
</Transports>
<ErrorCodes>
</ErrorCodes>
<Characteristics>
<Characteristic name="Blind Position"
type="org.bluetooth.characteristic.blind_position">
<InformativeText>Blind control
</InformativeText>
<Properties>
<Read>Excluded</Read>
<Write>Excluded</Write>
<WriteWithoutResponse>Excluded</WriteWithoutResponse>
<SignedWrite>Excluded</SignedWrite>
<ReliableWrite>Excluded</ReliableWrite>
<Notify>Excluded</Notify>
<Indicate>Mandatory</Indicate>
<WritableAuxiliaries>Excluded</WritableAuxiliaries>
<Broadcast>Excluded</Broadcast>
</Properties>
</Characteristic>
</Characteristics>
</Service>
The blinds have 4 characteristics - I’ve just tried to get the one working thus far.
from a python file I currently use control.py -
This will be a cool feature. is there any overlap / synergy you have with Find3?
I had that working with APs and it worked quite well but it needed a client to report position rather than statics working it out.
Hi there. I also HAD this problem, I found a fix for it (cant find it now unfortunally). It’s a problem with the firmware of the wifi/bt chip. Make sure you have the latest update and kernel on your raspbian. (The issue might be solved officially)
[10:16:44] openhabian@openHABianPi:~$ sudo systemctl status bluetooth
[sudo] password for openhabian:
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-09-11 09:32:06 CDT; 44min ago
Docs: man:bluetoothd(8)
Main PID: 7787 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─7787 /usr/local/libexec/bluetooth/bluetoothd --experimental
Sep 11 09:32:06 openHABianPi systemd[1]: Stopped Bluetooth service.
Sep 11 09:32:06 openHABianPi systemd[1]: Starting Bluetooth service...
Sep 11 09:32:06 openHABianPi bluetoothd[7787]: Bluetooth daemon 5.50
Sep 11 09:32:06 openHABianPi systemd[1]: Started Bluetooth service.
Sep 11 09:32:06 openHABianPi bluetoothd[7787]: Starting SDP server
Sep 11 09:32:06 openHABianPi bluetoothd[7787]: Bluetooth management interface 1.14 initialized
In the log I am seeing:
2018-09-11 10:17:46.554 [WARN ] [ace.internal.BindingExtensionHandler] - Installed bundle, but failed to start it: Could not resolve module: org.sputnikdev.org.eclipse.smarthome.binding.bluetooth.transport.bluegiga [269]
Unresolved requirement: Import-Package: org.sputnikdev.bluetooth
2018-09-11 10:17:46.560 [thome.event.ExtensionEvent] - Extension 'market:binding-3769228' has been installed.
2018-09-11 10:18:02.259 [thome.event.ExtensionEvent] - Extension 'market:binding-3694484' has been installed.
2018-09-11 10:18:02.411 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler AdapterHandler of thing bluetooth:adapter:d561f45b tried checking if channel discovering is linked although the handler was already disposed.
2018-09-11 10:18:02.414 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler AdapterHandler of thing bluetooth:adapter:d561f45b tried checking if channel discovering-control is linked although the handler was already disposed.
2018-09-11 10:18:02.446 [hingStatusInfoChangedEvent] - 'bluetooth:adapter:d561f45b' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2018-09-11 10:18:02.481 [WARN ] [.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
2018-09-11 10:18:02.487 [hingStatusInfoChangedEvent] - 'bluetooth:adapter:d561f45b' changed from INITIALIZING to ONLINE
2018-09-11 10:18:02.508 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler AdapterHandler of thing bluetooth:adapter:395a54bd tried checking if channel discovering is linked although the handler was already disposed.
2018-09-11 10:18:02.509 [hingStatusInfoChangedEvent] - 'bluetooth:adapter:d561f45b' changed from ONLINE to OFFLINE
2018-09-11 10:18:02.511 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler AdapterHandler of thing bluetooth:adapter:395a54bd tried checking if channel discovering-control is linked although the handler was already disposed.
2018-09-11 10:18:02.526 [WARN ] [.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
2018-09-11 10:18:02.528 [hingStatusInfoChangedEvent] - 'bluetooth:adapter:395a54bd' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2018-09-11 10:18:02.535 [hingStatusInfoChangedEvent] - 'bluetooth:adapter:395a54bd' changed from INITIALIZING to ONLINE
2018-09-11 10:18:02.601 [hingStatusInfoChangedEvent] - 'bluetooth:adapter:395a54bd' changed from ONLINE to OFFLINE
