Hi Vlad thanks! ordring and testing
what about apple watch and iphones are thay supprted here also?
do we have some sheet the can tell what hardware i can use from around the home?
Apple watches and iPhones support is being implemented and delayed (very busy at the moment). However, this not as easy as you may think. If your watch is always connected to your phone, then the binding (and any other BT devices) won’t see your watch at all as it stops advertising once connected. So if you keep the watch always connected to your phone, you won’t be able to use it with the binding. As per iPhones support - it will be possible to track you phone (with an app running that keeps BT always on, e.g. a beacon app) as soon as I resolve some issues with this new functionality and release a new version of the binding.
Good luck and thanks for great contribute !
Hi will the 2$ on ali work, this NUT ,is out of my budget i am want to put it on all my family members and dogs
can anyone give me link to cheap ones?
The problem with cheap “iTag” trackers is that although they look all the same, but there are actually two different hardware/firmware they use. One of them is bad, you cannot use it at all as it just goes off after some time if not connected (effectively if you leave your house and come back, it will be off). Another version is good, but you never know what you are ordering on ali… I suggest you to order different ones from different stores just to try and then do a bulk order Or maybe people here can recommend a good one here?
I ordered the most “popular” iTag on ali, the item has like around 2000 orders, but it turned out it is a bad unit. And then I ordered another one with only ~200 orders - and it worked great.
It was quite long time ago so I do not remember which one was good, try that one: https://www.aliexpress.com/item/2017-Sensor-Smart-Tag-Wireless-Bluetooth-4-0-Tracker-Wallet-Key-Keychain-Finder-GPS-Locator-Anti/32822394312.html?spm=a2g0s.9042311.0.0.27424c4dyKo61k
thanks i orderd lets try it out!
all of these cheap tags have worked for me:
https://www.amazon.co.uk/gp/product/B07G73PK46/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1&tag=efestivals-21
https://www.amazon.co.uk/gp/product/B0749F7WPS/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1&tag=efestivals-21
https://www.amazon.co.uk/gp/product/B01MCWPSL1/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1&tag=efestivals-21
https://www.amazon.co.uk/gp/product/B01DYVD2HO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1&tag=efestivals-21
thanks man!
but i dont have access to amazon where i am from
I would like to use beacons/tags in my cars to track them leaving/arriving. How would that work when the garage is too far away from my PI to get a signal? Are they BT extenders/repeaters? Add another PI?
Hi @mjcumming, you may use usb extenders (active extenders - up to 25 meter long) or you may set up “serial/usb-over-ip” link as described here: Forwarding of serial and USB ports over the network to openHAB
Currently i have some problems with Bluegiga adapters. MAybe has someone a hint for me. My setup: Latest nightly on a raspberry with openhabian. I bound two remote bluegiga adapters using socat to /dev/ttyNET1 and 2 and i am able to start the bluegiga toll and receive data over these ports.
Unfortunaltey the binding only finds the NET1 adapter Net2 is ignored. The regex entry is ((/dev/ttyNET1)|(/dev/ttyNET2))
Has anyone an idea?
@Dibbler42, maybe permissions? Compare file permissions ttyNET1 and NET2.
Permissions are the same. i have checked that more than one time
I have a problem with accuracy. I have 2 BT dongles, 1 in my OH Rpi B3+ (waskamer) and 1 in my desktop (woonkamer), forwarded with usbip. I’m sitting at my desktop, less then 1m away from the dongle. My OH is on the first floor, concrete between us. Why am I (bluetooth_ble_C868319C9F8E) jumping around between the 2 adapters?
I tried with different settings in the BT dongle and Mii band.
2018-09-22 19:45:28.465 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -72 to -71
2018-09-22 19:45:41.685 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -71 to -72
2018-09-22 19:45:54.390 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -72 to -71
2018-09-22 19:46:16.422 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -71 to -84
2018-09-22 19:46:16.463 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Woonkamer to Waskamer
2018-09-22 19:46:26.907 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -84 to -83
2018-09-22 19:47:12.096 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -83 to -84
2018-09-22 19:49:26.190 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -84 to -75
2018-09-22 19:49:26.222 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Waskamer to Woonkamer
2018-09-22 19:49:41.500 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -75 to -73
2018-09-22 19:50:06.151 [temChannelLinkRemovedEvent] - Link ‘bluetooth_ble_C868319C9F8E_tx_power => bluetooth:ble:C868319C9F8E:tx-power’ has been removed.
2018-09-22 19:50:07.964 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -73 to -85
2018-09-22 19:50:07.976 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Woonkamer to Waskamer
2018-09-22 19:50:29.480 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -85 to -73
2018-09-22 19:50:29.496 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Waskamer to Woonkamer
2018-09-22 19:50:40.497 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -73 to -86
2018-09-22 19:50:40.516 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Woonkamer to Waskamer
2018-09-22 19:50:51.540 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -86 to -87
2018-09-22 19:51:47.751 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -87 to -72
2018-09-22 19:51:47.769 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Waskamer to Woonkamer
2018-09-22 19:52:52.810 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -72 to -88
2018-09-22 19:52:52.826 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Woonkamer to Waskamer
2018-09-22 19:53:12.667 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -88 to -74
2018-09-22 19:53:12.706 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Waskamer to Woonkamer
2018-09-22 19:53:57.155 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -74 to -75
2018-09-22 19:54:19.915 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -75 to -88
2018-09-22 19:54:19.944 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Woonkamer to Waskamer
2018-09-22 19:54:56.244 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -88 to -72
2018-09-22 19:54:56.261 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Waskamer to Woonkamer
2018-09-22 19:55:13.954 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -72 to -78
2018-09-22 19:55:32.688 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -78 to -79
2018-09-22 19:55:43.159 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -79 to -80
2018-09-22 19:56:24.659 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -80 to -91
2018-09-22 19:56:24.674 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Woonkamer to Waskamer
2018-09-22 19:57:06.345 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -91 to -81
2018-09-22 19:57:06.357 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Waskamer to Woonkamer
2018-09-22 19:57:12.471 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -81 to -79
2018-09-22 19:57:37.826 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -79 to -89
2018-09-22 19:57:37.839 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_location changed from Woonkamer to Waskamer
2018-09-22 19:58:12.011 [vent.ItemStateChangedEvent] - bluetooth_ble_C868319C9F8E_rssi changed from -89 to -87
Any suggestions?
Hello everybody,
I have installed the binding and it works so far. I use a Gigaset G-tag to show my presence.
The question is, does the Discovery have to be constantly on, that the G-tag is recognized?
Sorry if I missed an answer in that direction
/Update
When I turn “ON” the discovering, G-Tag is recognized directly, I make it “OFF”, it does not work anymore.
The problem is when I turn it “ON”, I have about 30 items in the inbox after a short time. The signal is so strong that all devices that pass the house are detected
A new version of the binding and transport layers have been released. The following changes are included in this release:
You will have to uninstall existing plugins via PaperUI, restart OH and install them again. Make sure you have the following versions in your karaf console:
openhab> bundle:list | grep bluetooth
230 │ Active │ 80 │ 1.1.6 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth
232 │ Active │ 80 │ 1.2.3 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth.transport.bluegiga
233 │ Active │ 80 │ 1.1.3 │ org.sputnikdev:org.eclipse.smarthome.binding.bluetooth.transport.tinyb
PS> Regarding iphone and android support, I’ll update the binding documentation with some steps on how to use it.
@Nognog, you may stop adding BT devices into your inbox in the binding settings now:
Hi @stfn82, have you tried to play with device settings?
For your device:
For your adapters:
How are you adapters located? How far they are from each other?
@ [vkolotov]
For my understanding:
BTAdapter_Discovering “ON” ?
and Background Discovery “OFF” !
hi @Nognog, yes, if you want to stop adding discovered devices into your inbox but still want presence detection to be on, then as you mentioned: Background discover is OFF and adapters DiscoveryControl is ON.
