I’m back and will try to find some time to work on this binding.
To sum up what issues we have at the moment:
Serial ports get stolen. This is something to do with the library we use to discover serial ports. Unfortunately there is not much we can do apart from introducing a new setting that can disable autodiscovery of adapters. Once all adapters are added, this setting can be disabled so that the binding won’t interact with that library.
Connection management. Some devices drop connection on purpose, e.g. if there are a lot of them, they try to release connection when not needed. There must be a setting that controls the way how we manage connections, e.g. it should be possible to establish connection only when needed (e.g. to read some info etc).
Stale object recovery management. Again, due to Bluez/TinyB, some native objects get stale. Therefore the binding looks after TinyB objects and in case if they do not report any activity for some time, the binding releases/re-initialises them. This is a workaround, however this workaround sometimes causes some issues as well. When native objects get released, Bluez removes bonding info, which is not something we expect. Also, this causes some other issues with battery-less devices (Dolphin/EnOcean PTM 215B etc).
Anything else, let me know. This will keep me busy for some time.
I am using debian Buster testing in a virtual machine and running Bluez 5.50. So far it works with local connected and using usbip conneted bluetooth dongles
Hi @Nanna_Agesen, unfortunately, if it is a virtual environment, it is not going to work as the binding (transport pieces) tries to load some native libraries that can only work with native hardware. Some users use usb over IP or serial over IP solutions. Please search/read in this thread how to do this.
Impossible to remove Bluetooth things, even if the binding is uninstalled
I am using an apt-get installed version of OpenHAB 2.4 on a raspberry pi v3 B with Stretch. I compiled the version 5.47 of bluez, following instructions in this thread.
I installed the binding and I succesfully found the internal radio (BlueZ 5.47) and a Xiaomi temperature sensor. By mistake I also added two generic bluetooth thing. Now I am unable to delete bluetooth things, even if the bluetooth bindings are uninstalled.
I tried installing and uninstalling the bluetooth bindings (the market on, of course).
I tried stopping openhab, clearing cache and I even tried removing the things from the Json text files.
This bluetooth things always reappear: where are they located?
In events.log I only find
2019-01-28 13:27:42.576 [hingStatusInfoChangedEvent] - 'bluetooth:ble:4C65A8D05ECE' changed from UNINITIALIZED to REMOVING
but the things always remains in place.
How can I clean my OpenHAB installation (without completely reinstalling from scratch)?
Thank you
I bought a BT dongle compatible with my Qnap x86_64 NAS and tried to run the plugin.
I managed to install the bluez version 5.47 and compiled myself tinyb library from git.
I use an Openhab 2.4 from Qnapclub.eu that works pretty well.
The BT adapter discovery job fails…
> 7 2019-02-01 16:21:42.277 [DEBUG] [th.manager.impl.BluetoothManagerImpl] - Starting bluetooth manager: 8b095b9
8 2019-02-01 16:21:42.343 [WARN ] [oth.internal.BluetoothHandlerFactory] - Extension folder does not exist, ignoring it: /home/pi/.bluetooth_smart
9 2019-02-01 16:21:42.356 [DEBUG] [th.manager.impl.BluetoothManagerImpl] - Register tinyb transport
10 2019-02-01 16:21:42.375 [WARN ] [th.manager.impl.BluetoothManagerImpl] - Adapter discovery job error
11 java.lang.RuntimeException: Error getting object manager client: Could not connect: No such file or directory
12 at tinyb.BluetoothManager.getNativeAPIVersion(Native Method) ~[?:?]
13 at tinyb.BluetoothManager.getBluetoothManager(BluetoothManager.java:304) ~[?:?]
14 at org.sputnikdev.bluetooth.manager.transport.tinyb.TinyBFactory.getDiscoveredAdapters(TinyBFactory.java:162) ~[?:?]
15 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl$AdapterDiscoveryJob.discoverAdapters(BluetoothManagerImpl.java:817) ~[?:?]
16 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl$AdapterDiscoveryJob.run(BluetoothManagerImpl.java:810) ~[?:?]
17 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl.scheduleDiscovery(BluetoothManagerImpl.java:853) ~[?:?]
18 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl.lambda$registerFactory$1(BluetoothManagerImpl.java:126) ~[?:?]
19 at java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1660) ~[?:?]
20 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl.registerFactory(BluetoothManagerImpl.java:124) ~[?:?]
21 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.registerBluetoothObjectFactory(BluetoothHandlerFactory.java:112) ~[?:?]
22 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.lambda$registerBluetoothObjectFactories$0(BluetoothHandlerFactory.java:174) ~[?:?]
23 at java.util.ArrayList.forEach(ArrayList.java:1257) [?:?]
24 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.registerBluetoothObjectFactories(BluetoothHandlerFactory.java:174) [215:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.6]
25 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.activate(BluetoothHandlerFactory.java:69) [215:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.6]
26 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
27 at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
28 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
29 at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
30 at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [39:org.apache.felix.scr:2.1.2]
31 at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [39:org.apache.felix.scr:2.1.2]
32 at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [39:org.apache.felix.scr:2.1.2]
33 at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
34 at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [39:org.apache.felix.scr:2.1.2]
35 at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.1.2]
36 at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:334) [39:org.apache.felix.scr:2.1.2]
37 at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.2]
38 at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) [39:org.apache.felix.scr:2.1.2]
39 at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) [39:org.apache.felix.scr:2.1.2]
40 at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) [39:org.apache.felix.scr:2.1.2]
41 at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
42 at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
43 at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
44 at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
45 at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
46 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
47 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
48 at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
49 at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) [39:org.apache.felix.scr:2.1.2]
50 at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [39:org.apache.felix.scr:2.1.2]
51 at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) [39:org.apache.felix.scr:2.1.2]
52 at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) [39:org.apache.felix.scr:2.1.2]
53 at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1801) [39:org.apache.felix.scr:2.1.2]
54 at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1784) [39:org.apache.felix.scr:2.1.2]
55 at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:409) [39:org.apache.felix.scr:2.1.2]
56 at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [39:org.apache.felix.scr:2.1.2]
57 at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) [39:org.apache.felix.scr:2.1.2]
58 at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.2]
59 at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [39:org.apache.felix.scr:2.1.2]
60 at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [39:org.apache.felix.scr:2.1.2]
61 at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [39:org.apache.felix.scr:2.1.2]
62 at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [39:org.apache.felix.scr:2.1.2]
63 at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [39:org.apache.felix.scr:2.1.2]
64 at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
65 at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
66 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
67 at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
68 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
69 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
70 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
71 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
72 at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
73 at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
74 at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
75 at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
76 at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
77 at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
78 at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
79 at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
80 at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
81 at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
82 at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
83 at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
84 at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
85 at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
86 at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
87 at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
88 at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
89 at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
90 at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
91 at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
92 at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
93 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
94 at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
95 at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
96 at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
97 at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
98 at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
99 at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
100 at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
101 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
102 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
103 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
104 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
105 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
106 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
107 at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
108 2019-02-01 16:21:42.442 [WARN ] [th.manager.impl.BluetoothManagerImpl] - Device discovery job error
109 java.lang.RuntimeException: Error getting object manager client: Could not connect: No such file or directory
110 at tinyb.BluetoothManager.getNativeAPIVersion(Native Method) ~[?:?]
111 at tinyb.BluetoothManager.getBluetoothManager(BluetoothManager.java:304) ~[?:?]
112 at org.sputnikdev.bluetooth.manager.transport.tinyb.TinyBFactory.getDiscoveredDevices(TinyBFactory.java:175) ~[?:?]
113 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl$DeviceDiscoveryJob.discoverDevices(BluetoothManagerImpl.java:723) ~[?:?]
114 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl$DeviceDiscoveryJob.run(BluetoothManagerImpl.java:716) ~[?:?]
115 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl.scheduleDiscovery(BluetoothManagerImpl.java:858) ~[?:?]
116 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl.lambda$registerFactory$1(BluetoothManagerImpl.java:126) ~[?:?]
117 at java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1660) ~[?:?]
118 at org.sputnikdev.bluetooth.manager.impl.BluetoothManagerImpl.registerFactory(BluetoothManagerImpl.java:124) ~[?:?]
119 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.registerBluetoothObjectFactory(BluetoothHandlerFactory.java:112) ~[?:?]
120 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.lambda$registerBluetoothObjectFactories$0(BluetoothHandlerFactory.java:174) ~[?:?]
121 at java.util.ArrayList.forEach(ArrayList.java:1257) [?:?]
122 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.registerBluetoothObjectFactories(BluetoothHandlerFactory.java:174) [215:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.6]
123 at org.sputnikdev.esh.binding.bluetooth.internal.BluetoothHandlerFactory.activate(BluetoothHandlerFactory.java:69) [215:org.sputnikdev.org.eclipse.smarthome.binding.bluetooth:1.1.6]
124 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
125 at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
126 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
127 at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
128 at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [39:org.apache.felix.scr:2.1.2]
129 at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [39:org.apache.felix.scr:2.1.2]
130 at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [39:org.apache.felix.scr:2.1.2]
131 at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
132 at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [39:org.apache.felix.scr:2.1.2]
133 at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.1.2]
134 at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:334) [39:org.apache.felix.scr:2.1.2]
135 at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.2]
136 at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) [39:org.apache.felix.scr:2.1.2]
137 at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) [39:org.apache.felix.scr:2.1.2]
138 at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) [39:org.apache.felix.scr:2.1.2]
139 at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
140 at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
141 at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
142 at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
143 at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
144 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
145 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
146 at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
147 at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) [39:org.apache.felix.scr:2.1.2]
148 at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [39:org.apache.felix.scr:2.1.2]
149 at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) [39:org.apache.felix.scr:2.1.2]
150 at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) [39:org.apache.felix.scr:2.1.2]
151 at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1801) [39:org.apache.felix.scr:2.1.2]
152 at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1784) [39:org.apache.felix.scr:2.1.2]
153 at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:409) [39:org.apache.felix.scr:2.1.2]
154 at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [39:org.apache.felix.scr:2.1.2]
155 at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) [39:org.apache.felix.scr:2.1.2]
156 at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.2]
157 at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [39:org.apache.felix.scr:2.1.2]
158 at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [39:org.apache.felix.scr:2.1.2]
159 at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [39:org.apache.felix.scr:2.1.2]
160 at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [39:org.apache.felix.scr:2.1.2]
161 at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [39:org.apache.felix.scr:2.1.2]
162 at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
163 at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
164 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
165 at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
166 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
167 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
168 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
169 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
170 at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
171 at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
172 at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
173 at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
174 at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
175 at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
176 at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
177 at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
178 at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
179 at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
180 at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
181 at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
182 at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
183 at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
184 at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
185 at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
186 at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
187 at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
188 at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
189 at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
190 at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
191 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
192 at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
193 at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
194 at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
195 at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
196 at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
197 at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
198 at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
199 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
200 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
201 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
202 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
203 at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
204 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
205 at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]`Preformatted text`
Openhab runs with admin user, so everything seems to be ok…
Modern mobile phones change their Bluetooth MAC Address very often for anonymization purposes. So it does not make sense to set up your mobile phone as a device as it will not be rediscovered after a very short time (couple of minutes). This only makes sense with devices like sensors and alike. I am using the binding and it works great, but not with the temporary Mac addresses from mobile phones.
My TV with bluetooth shows up constantly, also my Xiaomi Mijia Bluetooth Temperature Smart Humidity Sensors. I do not have any experiences with bluetooth enabled smart waches.
Most Bluetooth devices flood the environment with messages, so every couple of seconds would be normal. The update interval of the binding seems to be 5 to 10 seconds as I can see from my persistence data:
Yes, looks like it is not working. But do you really use the 3rd party binding (only installable by Eclipse marketplace) or the official one? I had the same problems like you with the so called official one (but which indeed is just scrap).
