- * Copyright (c) 2010-2019 Contributors to the openHAB project
- * See the NOTICE file(s) distributed with this work for additional
- * information.
- * This program and the accompanying materials are made available under the
- * terms of the Eclipse Public License 2.0 which is available at
- * http://www.eclipse.org/legal/epl-2.0
- * SPDX-License-Identifier: EPL-2.0
- * This is the main application of the openHAB-cloud service
- * @author Victor Belov - Initial contribution
- * @author Dan Cunningham - Extended Features
- * @author Mehmet Arziman - Extended Features
- // Main Logging setup
- var logger = require('./logger.js'),
- system = require('./system'),
- config;
- //load and set our configuration, delete any cache first
- var loadConfig = function () {
- delete require.cache[require.resolve('./config.json')];
- config = require('./config.json');
- system.setConfiguration(config);
- loadConfig();
- module.exports.config = config;
- logger.info('Backend service is starting up...');
- process.on('uncaughtException', function (err) {
- console.log(JSON.stringify(err))
- logger.error(err);
- process.on('SIGHUP', function () {
- logger.info('Reloading config...');
- loadConfig();
- logger.info('Backend logging initialized...');
- // Setup all homepage
- var flash = require('connect-flash'),
- express = require('express'),
- bodyParser = require('body-parser'),
- errorHandler = require('errorhandler'),
- cookieParser = require('cookie-parser'),
- session = require('express-session'),
- favicon = require('serve-favicon'),
- csurf = require('csurf'),
- serveStatic = require('serve-static'),
- path = require('path'),
- passport = require('passport'),
- RedisStore = require('connect-redis')(session),
- redis = require('./redis-helper'),
- date_util = require('./date_util.js'),
- auth = require('./auth.js'),
- routes = require('./routes'),
- MongoConnect = require('./system/mongoconnect'),
- mongoose = require('mongoose'),
- cachegoose = require('recachegoose'),
- mongooseTypes = require('mongoose-types'),
- SocketIO = require('./socket-io');
- cachegoose(mongoose, {
- engine: 'redis',
- port: config.redis.port,
- host: config.redis.host,
- password: config.redis.password,
- // Try to setup a mongodb connection, otherwise stopping
- var mongoConnect = new MongoConnect(system);
- mongoConnect.connect(mongoose);
- mongooseTypes.loadTypes(mongoose);
- var app = express();
- var every5MinStatJob = require('./jobs/every5minstat');
- every5MinStatJob.start();
- // Configurable support for cross subdomain cookies
- var cookie = {};
- if (config.system.subDomainCookies) {
- cookie.path = '/';
- cookie.domain = '.' + system.getHost();
- logger.info('Cross sub domain cookie support is configured for domain: ' + cookie.domain);
- // Configure the openHAB-cloud for development mode, if in development
- if (app.get('env') === 'development') {
- app.use(errorHandler());
- if (system.getLoggerMorganOption()) {
- app.use(system.getLoggerMorganOption());
- // App configuration for all environments
- app.set('port', process.env.PORT || 3000);
- app.set('views', __dirname + '/views');
- app.set('view engine', 'ejs');
- app.use(favicon(__dirname + '/public/img/favicon.ico'));
- app.use(bodyParser.json({ verify: function (req, res, buf) { req.rawBody = buf } }))
- app.use(bodyParser.urlencoded({
- verify: function (req, res, buf) { req.rawBody = buf },
- extended: true
- app.use(cookieParser(config.express.key));
- app.use(session({
- secret: config.express.key,
- store: new RedisStore({
- host: 'localhost',
- port: 6379,
- client: redis,
- logErrors: true
- cookie: cookie,
- resave: false,
- saveUninitialized: false
- app.use(flash());
- app.use(passport.initialize());
- app.use(passport.session());
- //TODO we need to remove this hack, its leftover from long ago.
- //we need to know if this is a proxy connection or not (home/remote), other middleware depends on it.
- app.use(function (req, res, next) {
- var host = req.headers.host;
- // console.log(host);
- if (!host) {
- next(); // No host in header, just go ahead
- // If host matches names for full /* proxying, go ahead and just proxy it.
- if (host.indexOf('remote.') === 0 || host === system.getProxyHost()) {
- //make sure this was not set by another server
- if (req.url.indexOf('/remote') != 0) {
- req.url = '/remote' + req.url;
- next();
- var csrf = csurf();
- // Check if url needs csrf, remote connections and REST connections are excluded from CSRF
- if (!req.path.match('/api/*') && !req.path.match('/rest*') && !req.path.match('/oauth2/token') && !req.path.match('/ifttt/*') && !req.path.match('/remote/*'))
- csrf(req, res, next);
- else
- next();
- if (typeof req.csrfToken === 'function') {
- res.locals.token = req.csrfToken();
- next();
- // Add global usable locals for templates
- res.locals.baseurl = system.getBaseURL();
- res.locals.proxyUrl = system.getProxyURL();
- if (req.session.timezone) {
- res.locals.timeZone = req.session.timezone;
- } else {
- res.locals.timeZone = 'undefined';
- res.locals.date_util = date_util;
- res.locals.legal = false;
- if (config.legal) {
- res.locals.legal = true;
- res.locals.terms = config.legal.terms;
- res.locals.policy = config.legal.policy;
- res.locals.registration_enabled = system.isUserRegistrationEnabled();
- next();
- app.use(serveStatic(path.join(__dirname, 'public')));
- var server = app.listen(system.getNodeProcessPort(), config.system.listenIp, function () {
- logger.info('express server listening on port ' + system.getNodeProcessPort());
- // setup socket.io connections from openHABs
- var socketIO = new SocketIO(server, system);
- // setup the routes for the app
- var rt = new routes(logger);
- rt.setSocketIO(socketIO);
- rt.setupRoutes(app);
- function shutdown() {
- // Stop accepting new requests
- socketIO.shutDown().then(() => {
- server.close((err) => {
- if (err) {
- console.error('Error while shutting down:', err);
- process.exit(1);
- process.exit(0);
- logger.info('will wait up to 5 seconds to shut down');
- setTimeout(() => {
- process.exit(0);
- }, 5000);
- logger.info('Stopping every5min statistics job');
- every5MinStatJob.stop();
- process.on('SIGINT', function () {
- logger.info('frontend is shutting down from SIGINT');
- shutdown();
- process.on('SIGTERM', function () {
- logger.info('frontend is shutting down from SIGTERM');
- shutdown();
This file has been truncated. show original
