Add a meteogram to your sitemap
I like meteograms for weather forecasts - I think they’re great to get the most information at a glance.
I’ve been looking into services which provide them and found two, so just thought I’d share my findings:
meteograms.com
I just made an HABPanel widget for this one, but if you want it in a sitemap, just right click on the image and copy its URL to include it in your sitemap. They can be a little slow to render though, but you can customize them extensively.
yr.no
This great service from Norway which I found very accurate offers meteograms as SVG or PNG files. Just search for a location and you’ll arrive to a page with an URL in the format place/(country)/(region or state)/(city) like this: https://www.yr.no/place/United_States/District_of_Columbia/Washington_D.C_/
Then, just append meteogram.png to the URL and you’ll get this image:
You can also append advanced_meteogram.png to get a more detailed meteogram with cloud cover and pressure:
Note: the SVG versions are at meteogram.svg and advanced_meteogram.svg respectively, but they can’t be displayed in sitemaps.
AFAIK you can’t customize the 48-hour forecast or the layout.
Example snippet to include in sitemaps
  Frame label=Meteogram {
    Image url="https://www.yr.no/place/United_States/District_of_Columbia/Washington_D.C_/meteogram.png" label="Meteogram" refresh=3600000
This is brilliant - thank you.
I’ve looked through the settings document and the settings gallery, but cannot find an answer. Does anyone know if there’s a setting to use freedom units (aka imperial - Fahrenheit/mph)?
This example has temperatures in °F and wind speeds in mph:
Looking at the attached JSON (https://trello-attachments.s3.amazonaws.com/55b9cbc60372879b15d71751/571f19ec072991d2a5f6889f/c86fbbd07f0e7f18f15c6c0a757bcdea/1515840e3a16c8c1259711424ad487bc7caa4029.json) that would be:
provider: "wunderground.com",
temperatureUnit: "fahrenheit",
windSpeedUnit: "mph",
(Note the provider - the default one, met.no, probably only supports celsius and metric)
You have a link on the Trello board above to import this design into their website.
Thank’s for the tip, I am going to use it with other meteo sites as well.
Shouldn’t be this “3600000”?
Yes :slight_smile:
That’s it! Thank you.
