Hi
Is there a way to add a new attribute to an item?
I need to store the blind last direction (if it was going down or up) and don’t want to use global vars for that because I have tens of blinds around the house.
Hi
Why don’t you use the state that tells you if the Item is ON(Open) or OFF(Closed)
this automatically implies the last direction.
"link": "http://xxx.xxx.xxx.188:8080/rest/items/Shutter",
"state": "ON",
"editable": false,
"type": "Switch",
"name": "Shutter",
"label": "Shutter Living",
"category": "blinds",
"tags": [],
"groupNames": []
Through the rest API you could check all attributes on the item
Thank Charley for prompt response.
The blind is controlled by a dimmer and the state is never on or off, it’s just a number.
Today I check if the previousState > currentState to identify the direction.
"link":"http://10.0.0.10:8080/rest/items/GF_LivingRoom_Window_Patio_Blind",
"state":"1",
"editable":false,
"type":"Dimmer",
"name":"GF_LivingRoom_Window_Patio_Blind",
"label":"Blind",
"category":"blinds",
"tags":[
"Switchable",
"Blinds"
"groupNames":[
"GF_LivingRoom"
In that case you use this item
Rollershutter ShutterControl "Shutter living [%d %%]" (gBlinds) ["Blinds"] {channel="zwave:device:xxxxxxxxx:node32:blinds_control" }
Here are all attributes you can check the state again
"link": "http://xxx.xxx.xxx.xxx:8080/rest/items/ShutterControl",
"state": "0",
"stateDescription": {
"pattern": "%d %%",
"readOnly": false,
"options": []
"editable": false,
"type": "Rollershutter",
"name": "ShutterControl",
"label": "Shutter living",
"tags": [
"Blinds"
"groupNames": [
"gBlinds"
Not sure how I identify the blind last direction in this case, can you please let me know what am I missing?
If you are using persistence you could after the position change write a rule that finds the previous state.
<item>.previousState()
Find more info on persistence extensions here
This might be easier than you think, you can use a global “array” (actually a Map object) to store values keyed by Item name.
Usage shown here
You could also use metadata of the item.
Here is a tutorial for Item Metadata.
