I installed zigbee2mqtt using this tutorial: Running Zigbee2MQTT | zigbee2mqtt.io
It’s working fine, but I don’t know how to add a new device (thing) to my openhab 3 UI.
I reset my zigbee device and it was found my the mqtt broker:
Successfully interviewd '0x842e.....79e1' device has successfully been paired.
Whnn I turn the Switch ON/OFF, I see the values in the topic (zigbee2mqtt/0x842e.....79e1
But how can I configure the thing in my Openhab UI?
I configured all my things with the UI and I don’t want to configure the MQTT things with an config file.
My MQTT Broker is up and running (ONLINE in the thing overview).
BTW: How can I change to topic name to a more readable name instead of zigbee2mqtt/0x842e.....79e1
Thanks!
