I removed the interval still the same thing. It looks to me as if it can see the node it just isn’t giving any data back.
[DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 74 00 00 00 00 00 00 00 00 00 00 81 2016-04-05 19:49:07.256 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0 2016-04-05 19:49:07.256 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=1 2016-04-05 19:49:07.261 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 05 0E 32 02 21 74 00 00 00 00 00 00 00 00 00 00 81 2016-04-05 19:49:07.267 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 14 00 04 00 05 0E 32 02 21 74 00 00 00 00 00 00 00 00 00 00 81 2016-04-05 19:49:07.279 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 05 0E 32 02 21 74 00 00 00 00 00 00 00 00 00 00 2016-04-05 19:49:07.283 [DEBUG] [ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE) 2016-04-05 19:49:07.286 [DEBUG] [ApplicationCommandMessageClass] - NODE 5: Incoming command class METER 2016-04-05 19:49:07.289 [DEBUG] [z.i.p.c.ZWaveMeterCommandClass] - NODE 5: Received Meter Request 2016-04-05 19:49:07.290 [DEBUG] [z.i.p.c.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=0E+1 2016-04-05 19:49:07.292 [DEBUG] [b.z.i.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent 2016-04-05 19:49:07.292 [DEBUG] [.z.internal.ZWaveActiveBinding] - ZwaveIncomingEvent 2016-04-05 19:49:07.293 [DEBUG] [.z.internal.ZWaveActiveBinding] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 0E+1 2016-04-05 19:49:07.298 [DEBUG] [ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent. 2016-04-05 19:49:07.346 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 64 00 00 00 00 00 3C 00 00 00 00 AD 2016-04-05 19:49:07.355 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0 2016-04-05 19:49:07.354 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=1 2016-04-05 19:49:07.366 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 05 0E 32 02 21 64 00 00 00 00 00 3C 00 00 00 00 AD 2016-04-05 19:49:07.370 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 14 00 04 00 05 0E 32 02 21 64 00 00 00 00 00 3C 00 00 00 00 AD 2016-04-05 19:49:07.374 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 05 0E 32 02 21 64 00 00 00 00 00 3C 00 00 00 00 2016-04-05 19:49:07.376 [DEBUG] [ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE) 2016-04-05 19:49:07.377 [DEBUG] [ApplicationCommandMessageClass] - NODE 5: Incoming command class METER 2016-04-05 19:49:07.378 [DEBUG] [z.i.p.c.ZWaveMeterCommandClass] - NODE 5: Received Meter Request 2016-04-05 19:49:07.379 [DEBUG] [z.i.p.c.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=kWh(0), Value=0E+1 2016-04-05 19:49:07.381 [DEBUG] [b.z.i.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent 2016-04-05 19:49:07.382 [DEBUG] [.z.internal.ZWaveActiveBinding] - ZwaveIncomingEvent 2016-04-05 19:49:07.383 [DEBUG] [.z.internal.ZWaveActiveBinding] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 0E+1 2016-04-05 19:49:07.386 [DEBUG] [ApplicationCommandMessageClass] - Transaction not completed: node address inconsistent. 2016-04-05 19:49:07.587 [DEBUG] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Room for widget org.openhab.model.sitemap.Group 2016-04-05 19:49:07.627 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:07.628 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - Servlet request received! 2016-04-05 19:49:07.629 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - reading sitemap home 2016-04-05 19:49:08.308 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:08.311 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - Servlet request received! 2016-04-05 19:49:08.314 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - reading sitemap home 2016-04-05 19:49:08.792 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:10.582 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:10.585 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - Servlet request received! 2016-04-05 19:49:10.588 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - reading sitemap home 2016-04-05 19:49:12.680 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:12.681 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - Servlet request received! 2016-04-05 19:49:12.683 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - reading sitemap home 2016-04-05 19:49:12.685 [DEBUG] [o.u.i.items.ItemUIRegistryImpl] - Cannot retrieve item Room for widget org.openhab.model.sitemap.Group 2016-04-05 19:49:12.976 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'sitemaps' 2016-04-05 19:49:12.980 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'persistence' 2016-04-05 19:49:12.983 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'rules' 2016-04-05 19:49:12.985 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'scripts' 2016-04-05 19:49:12.987 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'items' 2016-04-05 19:49:13.127 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:13.129 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - Servlet request received! 2016-04-05 19:49:13.132 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - reading sitemap home 2016-04-05 19:49:13.793 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:18.794 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:22.989 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'sitemaps' 2016-04-05 19:49:22.992 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'persistence' 2016-04-05 19:49:22.995 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'rules' 2016-04-05 19:49:22.997 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'scripts' 2016-04-05 19:49:22.999 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'items' 2016-04-05 19:49:23.644 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:23.646 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - Servlet request received! 2016-04-05 19:49:23.648 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - reading sitemap home 2016-04-05 19:49:23.793 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:28.794 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:29.262 [DEBUG] [ZWaveMultiLevelSwitchConverter] - NODE 3: Generating poll message for SWITCH_MULTILEVEL for node 0 endpoint {} 2016-04-05 19:49:29.267 [DEBUG] [veMultiLevelSwitchCommandClass] - NODE 3: Creating new message for command SWITCH_MULTILEVEL_GET 2016-04-05 19:49:29.271 [DEBUG] [o.b.z.i.protocol.SerialMessage] - NODE 3: Creating empty message of class = SendData (0x13), type = Request (0x00) 2016-04-05 19:49:29.273 [DEBUG] [b.z.i.protocol.ZWaveController] - Callback ID = 6 2016-04-05 19:49:29.274 [DEBUG] [b.z.i.protocol.ZWaveController] - Enqueueing message. Queue length = 1 2016-04-05 19:49:29.274 [DEBUG] [WaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0 2016-04-05 19:49:29.282 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 03 02 26 02 25 06 E3 2016-04-05 19:49:29.286 [DEBUG] [WaveController$ZWaveSendThread] - NODE 3: Sending REQUEST Message = 01 09 00 13 03 02 26 02 25 06 E3 2016-04-05 19:49:29.297 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8 2016-04-05 19:49:29.301 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=1 2016-04-05 19:49:29.301 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0 2016-04-05 19:49:29.303 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8 2016-04-05 19:49:29.306 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8 2016-04-05 19:49:29.308 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01 2016-04-05 19:49:29.310 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Sent Data successfully placed on stack. 2016-04-05 19:49:29.315 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 07 00 13 06 00 00 02 EF 2016-04-05 19:49:29.320 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=1 2016-04-05 19:49:29.320 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0 2016-04-05 19:49:29.323 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 06 00 00 02 00 00 E1 2016-04-05 19:49:29.327 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 09 00 13 06 00 00 02 00 00 E1 2016-04-05 19:49:29.329 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 06 00 00 02 2016-04-05 19:49:29.331 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 6, Status = Transmission complete and ACK received(0) 2016-04-05 19:49:29.334 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 03 02 26 02 2016-04-05 19:49:29.340 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 06 00 00 02 2016-04-05 19:49:29.342 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=ApplicationCommandHandler, cancelled=false 2016-04-05 19:49:29.347 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 03 03 26 03 00 D7 2016-04-05 19:49:29.352 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=1 2016-04-05 19:49:29.352 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0 2016-04-05 19:49:29.357 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 03 03 26 03 00 D7 2016-04-05 19:49:29.362 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 09 00 04 00 03 03 26 03 00 D7 2016-04-05 19:49:29.366 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 03 03 26 03 00 2016-04-05 19:49:29.368 [DEBUG] [ApplicationCommandMessageClass] - NODE 3: Application Command Request (ALIVE:DONE) 2016-04-05 19:49:29.370 [DEBUG] [ApplicationCommandMessageClass] - NODE 3: Incoming command class SWITCH_MULTILEVEL 2016-04-05 19:49:29.371 [DEBUG] [veMultiLevelSwitchCommandClass] - NODE 3: Received Switch Multi Level Request 2016-04-05 19:49:29.374 [DEBUG] [veMultiLevelSwitchCommandClass] - NODE 3: Switch Multi Level report, value = 0 2016-04-05 19:49:29.375 [DEBUG] [b.z.i.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent 2016-04-05 19:49:29.377 [DEBUG] [.z.internal.ZWaveActiveBinding] - ZwaveIncomingEvent 2016-04-05 19:49:29.379 [DEBUG] [.z.internal.ZWaveActiveBinding] - NODE 3: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 0 2016-04-05 19:49:29.384 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 03 02 26 02 2016-04-05 19:49:29.388 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 03 03 26 03 00 2016-04-05 19:49:29.390 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false 2016-04-05 19:49:29.391 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - transaction complete! 2016-04-05 19:49:29.394 [DEBUG] [b.z.i.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent 2016-04-05 19:49:29.396 [DEBUG] [.z.internal.ZWaveActiveBinding] - ZwaveIncomingEvent 2016-04-05 19:49:29.397 [DEBUG] [WaveController$ZWaveSendThread] - NODE 3: Response processed after 110ms/214ms. 2016-04-05 19:49:33.001 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'sitemaps' 2016-04-05 19:49:33.004 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'persistence' 2016-04-05 19:49:33.007 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'rules' 2016-04-05 19:49:33.010 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'scripts' 2016-04-05 19:49:33.012 [DEBUG] [.o.m.c.i.folder.FolderObserver] - Refreshing folder 'items' 2016-04-05 19:49:33.805 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:34.162 [DEBUG] [.io.net.http.SecureHttpContext] - security is disabled - processing aborted! 2016-04-05 19:49:34.164 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - Servlet request received! 2016-04-05 19:49:34.169 [DEBUG] [.o.u.w.i.servlet.WebAppServlet] - reading sitemap home 2016-04-05 19:49:34.276 [DEBUG] [z.internal.ZWaveNetworkMonitor] - NODE 3: Sending periodic PING. 2016-04-05 19:49:34.277 [DEBUG] [c.ZWaveNoOperationCommandClass] - NODE 3: Creating new message for command No Operation 2016-04-05 19:49:34.279 [DEBUG] [o.b.z.i.protocol.SerialMessage] - NODE 3: Creating empty message of class = SendData (0x13), type = Request (0x00) 2016-04-05 19:49:34.280 [DEBUG] [b.z.i.protocol.ZWaveController] - Callback ID = 7 2016-04-05 19:49:34.282 [DEBUG] [b.z.i.protocol.ZWaveController] - Enqueueing message. Queue length = 1 2016-04-05 19:49:34.282 [DEBUG] [WaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0 2016-04-05 19:49:34.285 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 08 00 13 03 01 00 25 07 C4 2016-04-05 19:49:34.289 [DEBUG] [WaveController$ZWaveSendThread] - NODE 3: Sending REQUEST Message = 01 08 00 13 03 01 00 25 07 C4 2016-04-05 19:49:34.300 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8 2016-04-05 19:49:34.304 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=1 2016-04-05 19:49:34.304 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0 2016-04-05 19:49:34.307 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8 2016-04-05 19:49:34.309 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8 2016-04-05 19:49:34.311 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Response (0x01), payload = 01 2016-04-05 19:49:34.312 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: Sent Data successfully placed on stack. 2016-04-05 19:49:34.317 [DEBUG] [eController$ZWaveReceiveThread] - Receive Message = 01 07 00 13 07 00 00 02 EE 2016-04-05 19:49:34.323 [DEBUG] [eController$ZWaveReceiveThread] - Receive queue ADD: Length=1 2016-04-05 19:49:34.323 [DEBUG] [b.z.i.protocol.ZWaveController] - Receive queue TAKE: Length=0 2016-04-05 19:49:34.328 [DEBUG] [o.b.z.i.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 07 00 00 02 00 00 E0 2016-04-05 19:49:34.331 [DEBUG] [b.z.i.protocol.ZWaveController] - Process Message = 01 09 00 13 07 00 00 02 00 00 E0 2016-04-05 19:49:34.341 [DEBUG] [b.z.i.protocol.ZWaveController] - Message: class = SendData (0x13), type = Request (0x00), payload = 07 00 00 02 2016-04-05 19:49:34.343 [DEBUG] [b.z.i.p.s.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 7, Status = Transmission complete and ACK received(0) 2016-04-05 19:49:34.346 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 03 01 00 2016-04-05 19:49:34.350 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 07 00 00 02 2016-04-05 19:49:34.351 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, expected=SendData, cancelled=false 2016-04-05 19:49:34.354 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor] - transaction complete! 2016-04-05 19:49:34.355 [DEBUG] [b.z.i.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
