Thanks for the advice @chris. I have completed the steps and have the same symptoms. I did notice this which might help troubleshoot… I first enabled “inclusion” and added the device and it worked fine (went past STATIC_VALUES) and was “online”. When restarting the binding, it is now stuck where it was before not moving beyond STATIC_VALUES. the new log here includes both situations. First inclusion and after restarting the binding.
the device in question is now “node5”
This is a ZIP FILE - plz rename extension to .zip - it was too big to upload (just over 1024k
zwave.log.xml (68.4 KB)
Applicable last lines:
2017-04-07 16:22:20.098 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Found 1 instances of MULTI_INSTANCE_ASSOCIATION
2017-04-07 16:22:20.098 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 5: Creating new message for command MULTI_ASSOCIATIONCMD_GROUPINGSGET
2017-04-07 16:22:20.098 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3D 00 00 02
2017-04-07 16:22:20.098 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=61, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2017-04-07 16:22:20.098 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking CLOCK
2017-04-07 16:22:20.098 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking CONFIGURATION
2017-04-07 16:22:20.098 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking DEVICE_RESET_LOCALLY
2017-04-07 16:22:20.098 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking SWITCH_ALL
2017-04-07 16:22:20.098 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - found SWITCH_ALL
2017-04-07 16:22:20.098 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Found 1 instances of SWITCH_ALL
2017-04-07 16:22:20.098 [DEBUG] [mandclass.ZWaveSwitchAllCommandClass] - NODE 5: Creating new message for command SWITCH_ALL_GET
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking METER
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - found METER
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Found 1 instances of METER
2017-04-07 16:22:20.099 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Creating new message for application command METER_SUPPORTED_GET
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking ASSOCIATION_GROUP_INFO
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - found ASSOCIATION_GROUP_INFO
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Found 1 instances of ASSOCIATION_GROUP_INFO
2017-04-07 16:22:20.099 [DEBUG] [WaveAssociationGroupInfoCommandClass] - NODE 5: Initialising association group info - 1 groups known
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking COLOR
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - found COLOR
2017-04-07 16:22:20.099 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Found 1 instances of COLOR
2017-04-07 16:22:20.099 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 5: Creating new message for application command SWITCH_COLOR_SUPPORTED_GET
2017-04-07 16:22:20.100 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking VERSION
2017-04-07 16:22:20.100 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking BASIC
2017-04-07 16:22:20.100 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - checking ASSOCIATION
2017-04-07 16:22:20.100 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - found ASSOCIATION
2017-04-07 16:22:20.100 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Found 1 instances of ASSOCIATION
2017-04-07 16:22:20.100 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 5: Creating new message for application command ASSOCIATIONCMD_GROUPINGSGET
2017-04-07 16:22:20.100 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: STATIC_VALUES - queued 13 frames
2017-04-07 16:22:25.006 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 2 attempts left!
2017-04-07 16:22:25.007 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Got an error while sending data. Resending message.
2017-04-07 16:22:25.007 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-04-07 16:22:25.007 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-04-07 16:22:25.007 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 05 06 60 0D 01 01 33 01 25 3E A6
2017-04-07 16:22:25.007 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0D 00 13 05 06 60 0D 01 01 33 01 25 3E A6
2017-04-07 16:22:25.015 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-04-07 16:22:25.015 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-04-07 16:22:25.016 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-04-07 16:22:25.016 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-04-07 16:22:25.016 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-04-07 16:22:25.016 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
2017-04-07 16:22:25.031 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 3E 00 00 02 D7
2017-04-07 16:22:25.032 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-04-07 16:22:25.032 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 3E 00 00 02 00 00 D9
2017-04-07 16:22:25.032 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 3E 00 00 02 00 00 D9
2017-04-07 16:22:25.032 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3E 00 00 02
2017-04-07 16:22:25.032 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 62, Status = Transmission complete and ACK received(0)
2017-04-07 16:22:25.033 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, callback=62, payload=05 06 60 0D 01 01 33 01
2017-04-07 16:22:25.033 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3E 00 00 02
2017-04-07 16:22:25.033 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=62, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2017-04-07 16:22:30.008 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 1 attempts left!
2017-04-07 16:22:30.008 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Got an error while sending data. Resending message.
2017-04-07 16:22:30.008 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-04-07 16:22:30.008 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-04-07 16:22:30.008 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 05 06 60 0D 01 01 33 01 25 3F A7
2017-04-07 16:22:30.008 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0D 00 13 05 06 60 0D 01 01 33 01 25 3F A7
2017-04-07 16:22:30.016 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-04-07 16:22:30.017 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-04-07 16:22:30.017 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-04-07 16:22:30.017 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-04-07 16:22:30.017 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-04-07 16:22:30.017 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
2017-04-07 16:22:30.033 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 3F 00 00 03 D7
2017-04-07 16:22:30.033 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-04-07 16:22:30.033 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 3F 00 00 03 00 00 D9
2017-04-07 16:22:30.034 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 3F 00 00 03 00 00 D9
2017-04-07 16:22:30.034 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3F 00 00 03
2017-04-07 16:22:30.034 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 63, Status = Transmission complete and ACK received(0)
2017-04-07 16:22:30.034 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, callback=63, payload=05 06 60 0D 01 01 33 01
2017-04-07 16:22:30.034 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3F 00 00 03
2017-04-07 16:22:30.034 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=63, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2017-04-07 16:22:35.009 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 0 attempts left!
2017-04-07 16:22:35.009 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Got an error while sending data. Resending message.
2017-04-07 16:22:35.009 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-04-07 16:22:35.009 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-04-07 16:22:35.010 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 05 06 60 0D 01 01 33 01 25 40 D8
2017-04-07 16:22:35.010 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0D 00 13 05 06 60 0D 01 01 33 01 25 40 D8
2017-04-07 16:22:35.018 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-04-07 16:22:35.018 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-04-07 16:22:35.018 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-04-07 16:22:35.018 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-04-07 16:22:35.019 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-04-07 16:22:35.019 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
2017-04-07 16:22:35.034 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 40 00 00 02 A9
2017-04-07 16:22:35.035 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-04-07 16:22:35.035 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 40 00 00 02 00 00 A7
2017-04-07 16:22:35.035 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 40 00 00 02 00 00 A7
2017-04-07 16:22:35.035 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=40 00 00 02
2017-04-07 16:22:35.035 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 64, Status = Transmission complete and ACK received(0)
2017-04-07 16:22:35.035 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, callback=64, payload=05 06 60 0D 01 01 33 01
2017-04-07 16:22:35.035 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=40 00 00 02
2017-04-07 16:22:35.035 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=64, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2017-04-07 16:22:40.010 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, callback=64, payload=05 06 60 0D 01 01 33 01
