- Platform information:
- Hardware: Intel(R) Core™ i7-4785T CPU @ 2.20GHz, 32 GB RAM, 13 TB storage
- OS: OS Name: Microsoft Windows Server Core Datacenter 10.0.18362 N/A Build 18362
- Java Runtime Environment: Zulu 8.48.0.53-CA-win64) (build 1.8.0_265-b11)
- openHAB version: 2.5.7
- Issue of the topic: After firmware update of AEOTEC Trisensor to 1.21 not reporting either temp/motion/illumination information. I cannot set Accotiation Groups, log says Configuration update ignored.
- If logs where generated please post these here using code fences:
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update received
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_30_2 to 0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_31_2 to 0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored binding_cmdrepollperiod to 1500 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_11_1 to 2 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_10_1 to 1 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update set group_1 to null (null)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Association 1 consolidated to
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Unknown association group 1
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update set group_3 to null (null)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Association 3 consolidated to
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Unknown association group 3
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update set group_2 to null (null)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Association 2 consolidated to
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Unknown association group 2
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored wakeup_node to 0.0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_12_1 to 0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_13_1 to 0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_15_1 to 0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_20_1 to 0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_21_2 to 25 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored action_failed to false (Boolean)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored wakeup_interval to 28800.0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored action_remove to false (Boolean)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored binding_pollperiod to 86400 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored action_heal to false (Boolean)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_1_2 to 30 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_100_2 to 1024 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_7_2 to 239 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_2_2 to 240 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_3_1 to 11 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_22_2 to 100 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_4_1 to 0 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_23_2 to 3600 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_5_1 to 3 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_24_2 to 3600 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored node_id to 4 (BigDecimal)
2020-08-20 12:23:19.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Configuration update ignored config_6_1 to 0 (BigDecimal)
