Thanks Ole
Sliding needs to be added to OH2. This is basic functionality in my view thats fundamental!
Click, Touch, Slide, Swipe etc etc etc all its all core of an IPhone which always wins in usability.
Thanks Ole
I want to use this device in a rule – is this possible. I have set up Items for each of the 4 buttons and the “scene” and tried to set a rule for “received command” event. But that doesn’t work. Any ideas?
Commands are sent from UIs and rules. Bindings update the state of linked Items… use ‘received update’.
Do I have to set the device association?
I want to use a rule like this:
Item QuadScene received update
where QuadScene is defined in items as:
Number QuadScene {channel=“zwave:device:a412db75:node13:scene_number”}
Your rule should look like this. Other than the Lifeline, you shouldn’t need to set any other associations.
ule "Wallmote"
var double sceneNumber = (QuadScene.state as Number).doubleValue
switch (sceneNumber) {
case 1.0 : { // Button 1 short press
case 1.1 : { // Button 1 long press
case 1.2 : { // Button 1 hold
case 2.0 : { // Button 2 short press
case 2.1 : { // Button 2 long press
case 2.2 : { // Button 2 hold
case 3.0 : { // Button 3 short press
case 3.1 : { // Button 3 long press
case 3.2 : { // Button 3 hold
case 4.0 : { // Button 4 short press
case 4.1 : { // Button 4 long press
case 4.2 : { // Button 4 hold
default : { // Unknown
Ohhhhh I got it! =) Thanks @mhilbush his rule works perfectly! Be sure to use 1.0 and not 1,0 or simply 1!
