After Reboot some Labels are gone....HELP
Hi, i’m on the latest snapshot v2.2…started from scatch with a blank system. Did setup everything and for a few days now i rebooted the first time…now i have a classic ui gui where some labels are gone…like in SWITCH group i only see switch as a label for all items…some items have no more icons, some do have not the label but the “item name” itself…
I read somehwhere to stop the service and clear cache and tmp…
but nothing changed…what is going on, any idea what i need to do to get my system back to life…Many Thanks Norbert
Hi Norbert,
I was having a similar issue, eventually found it was caused by restoring persisted items at startup using JDBC MySQL.
Disabling that made them problem go away, but I haven’t had a chance to fix it yet.
Maybe someone else has some ideas?
Regards,
Josh
i was able to fix it via removal of all data in cache and tmp…however after reboot it is the same situation as before. hm, anyone experience with solution to handle this…
The first place to look for any problem even remotely like this is the logs. Errors in the logs?
Rich, here is the log from STOP and START of service. Some items look not too good, but hard for me to understand where it comes from…
2017-10-03 21:26:23.607 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-10-03 21:26:37.695 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2017-10-03 21:26:37.923 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Deleting weatherJob-myhome
2017-10-03 21:26:37.947 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mosquitto'
2017-10-03 21:26:38.146 [INFO ] [assic.internal.servlet.WebAppServlet] - Stopped Classic UI
2017-10-03 21:26:38.182 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2017-10-03 21:26:38.365 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ThingRemovedEvent'.
2017-10-03 21:26:38.368 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ThingRemovedEvent'.
2017-10-03 21:26:38.458 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.460 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.461 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.462 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.464 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.465 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been shut down
2017-10-03 21:26:38.467 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.468 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.470 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.472 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.474 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.475 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.477 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.478 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.480 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.481 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.483 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.484 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.486 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.487 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.489 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.490 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.492 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.493 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.495 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.497 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.498 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.499 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.500 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.501 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.502 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.503 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.505 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.506 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.508 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.509 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.510 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.512 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.514 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.516 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.518 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.519 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.521 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.522 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.524 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.525 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.527 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.528 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.530 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.531 [WARN ] [ore.internal.events.OSGiEventManager] - Could not find an Event Factory for the event type 'ItemChannelLinkRemovedEvent'.
2017-10-03 21:26:38.820 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-10-03 21:26:38.838 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2017-10-03 21:26:38.848 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
^C
odroid@SmartDroid:~$
odroid@SmartDroid:~$ tail -f /var/log/openhab2/openhab.log
2017-10-03 21:28:38.006 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to en_AT, Location set to 48.5673,16.5728
2017-10-03 21:28:39.238 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.11:8080
2017-10-03 21:28:39.241 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.11:8443
2017-10-03 21:28:46.120 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
2017-10-03 21:28:46.835 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2017-10-03 21:28:52.108 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'presence.rules'
2017-10-03 21:28:53.767 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'timer.rules'
2017-10-03 21:28:54.240 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'keyfob.rules'
2017-10-03 21:28:58.645 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'default.rules', using it anyway:
The operator '==' should be replaced by '===' when null is one of the arguments.
The operator '!=' should be replaced by '!==' when null is one of the arguments.
2017-10-03 21:28:58.651 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2017-10-03 21:28:59.574 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'micasa.sitemap'
2017-10-03 21:29:00.499 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2017-10-03 21:29:00.721 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2017-10-03 21:29:01.183 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'WellWater_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.185 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'PVng4_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.187 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Devolo3_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.188 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Devolo1_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.190 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'LRMotionSensor_Temperature' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.191 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'HouseNr_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.193 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Router_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.194 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'LC13Thermostat_Setpoint' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.196 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'FRISTAR_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.198 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'DriveInRelay_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.200 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'LivingRoom_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.202 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Devolo3_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.204 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'FibaroFlood_Batt' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.205 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'RH_Basement' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.206 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'FibaroFlood_Temp' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.208 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'LivingRoom_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.209 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Router_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.210 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'SmartDroid_Cpu_Load' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.212 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'EntryEGMotionSensor_Luminance' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.213 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Fibaro_FloodAlarm' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.214 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'PVng4_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.216 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'LRMotionSensor_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.217 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'PVisland_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.219 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'DevoloKeyFOB_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.221 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Air_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.222 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Solar_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.224 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'HomeOffice_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.226 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'PVng5Poly_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.227 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'LocalTime_Date' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.229 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'PVisland_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.230 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'EntryEGMotionSensor_MotionAlarm' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.231 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'KitchenFlood_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.233 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'LC13Thermostat_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.234 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'MaxKalk_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.236 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'EntryEGMotionSensor_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.238 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'DriveInRelay_Switch2' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.240 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'LRMotionSensor_Luminance' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.241 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Solar_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.242 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'FRISTAR_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.243 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ZWaveNode52DevoloKeyFOB_SceneNumber' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.245 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'AxisVideo_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.247 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'KitchenFlood_Alarm' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.248 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Gas_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.250 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'LocalSun_Set_StartTime' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.251 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'DBlight_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.252 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'PVng5Mono_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.254 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'MyMinimote_SceneNumber' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.255 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Air_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.256 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'ST814_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.258 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'DBlight_Switch2' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.260 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'DBlight_Switch1' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.264 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'WellWater_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.266 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'MaxKalk_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.268 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'FibaroKeyFOB_BatteryLevel' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.269 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Gas_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.271 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.DateTimeItem with key'LocalSun_Rise_StartTime' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.272 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'AxisVideo_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.274 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'PVng5Mono_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.275 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'LRMotionSensor_MotionAlarm' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.276 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Devolo1_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.278 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'PVng5Poly_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.279 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'HouseNr_Power' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.281 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'FibaroKeyFOB_SceneNumber' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.282 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'HomeOffice_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.284 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'Temp_Basement' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.285 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'Everspring_Switch' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:01.286 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'EntryEGMotionSensor_Temperature' already exists! Failed to add a second with the same UID!
2017-10-03 21:29:02.444 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2017-10-03 21:29:02.484 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-10-03 21:29:02.488 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2017-10-03 21:29:03.521 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-10-03 21:29:03.975 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2017-10-03 21:29:04.026 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-10-03 21:29:05.678 [INFO ] [eather.internal.common.WeatherConfig] - ProviderConfig[providerName=OPENWEATHERMAP,apiKey=ddddddddddd]
2017-10-03 21:29:05.680 [INFO ] [eather.internal.common.WeatherConfig] - ProviderConfig[providerName=WUNDERGROUND,apiKey=2ddddddddd12ff5]
2017-10-03 21:29:05.682 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=WUNDERGROUND,language=en,updateInterval=5,latitude=48.5701,longitude=16.5715,woeid=<null>,locationId=myhome,name=Mistelbach]
2017-10-03 21:29:06.069 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-10-03 21:29:06.167 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-10-03 21:29:06.819 [ERROR] [org.openhab.io.net.http.HttpUtil    ] - Fatal transport error: java.net.NoRouteToHostException: No route to host (Host unreachable)
2017-10-03 21:29:06.822 [ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'http://192.168.1.10:8080/user/var/120/10251/0/0/12528'
2017-10-03 21:29:09.480 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-myhome with interval of 5 minutes
2017-10-03 21:29:10.459 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2017-10-03 21:29:10.585 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-10-03 21:29:10.602 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-10-03 21:29:10.622 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-10-03 21:29:10.624 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
The first problem is unrelated to your current issue. But the syntax of your keyfob.rules file is incorrect. Load the config into ESH Designer and correct any errors.
There does indeed appear to be something significantly wrong with the Items registry. You only define your Items in one place? For example, you are not defining Items in PaperUI and then defining the same Items again in a .items file?
Did this start right after upgrading to the latest snapshot?
Once we rule out your having messed something up in the configs, which can be easy to do as you well know, I think this will warrant filing an Issue.
I have experienced this problem for some time now. It seems to be a problem with discovered things when the item linked to a thing-channel was created using one of the admin UIs, PaperUI or HABmin. In other words, items linked to thing-channels without text configuration in *.things or *.items. See this topic for more:
https://community.openhab.org/t/item-issues-after-upgrade-to-snapshot-2-2-1004/32927
After a reboot I always have to delete the thing-item links with default item labels (Switch, Dimmer, …) using HABmin, then recreate them with my item labels and re-add tags and group info for those items.
hm…
where do you see an issue in keyfob rules?
I only see, whatever validation issue may mean…
2017-10-03 21:28:54.240 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'keyfob.rules’
2017-10-03 21:28:58.645 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘default.rules’, using it anyway:
Items are placed in .items files (non zwave ones) + items/things from paperUI (mostly zwave). Is this a problem, i thought it would be flexible in that you can mix it up?
YES, nothing helped like cache/tmp clear, restart…and after snapshot upgrade it was working proberly. today restart of service, same issue again…
You are right, I miss read the log lines and swapped the files. Yes, default.rules is the one with the issues.
You can mix it up but you cannot define the SAME Item in both places. If you define one in PaperUI, you cannot define an Item with the same name in a .items file. Since the logs were complaining about duplicate Items I wanted to rule out a config problem like that.
I’ve no other ideas but search the forum. Someone else may have recently posted a problem like this. There have been numerous similar problems posted over the past week or so. There might already be an issue open.
