Hi All,
I upgraded from OpenHABian 2.2.0-1 (Stable) to 2.3.0-1 (Stable) today (RasPI 3) and used the chance to transfer the 2.2.0 installation before on a brand new SD card.
Still it was quite a challenge as it took me like 4 times with restoring backup images repeatedly as every time some other issue (logs full of various errors, no openhab logs anymore, problems with the ‘openhab-binding-weather1’ binding) occured and efforts to fix (like eg. deleting the cache and temp) always messed up even more… so back to start again and again.
But while by now things finally don’t look so bad there is one thing that worries me:
Every time I close (=terminate) the iOS App (running iOS 11.4.1) the following error is logged in openhab.log.
I tried from different devices and the behaviour can clearly be reproduced (it doesn’t matter if I did connect locally or through myopenhab.org / the cloud connector ).
2018-07-15 19:54:34.240 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:731) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:745) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:496) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at java.io.OutputStream.write(OutputStream.java:75) ~[?:?]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:320) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:218) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:294) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.GsonProvider.writeTo(GsonProvider.java:71) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
… 46 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
… 46 more
Would anybody have any good idea about this behaviour and how to fix this?
As said my experience with generally deleting the Cache and the Temp folders content was more than frightening - so I would really like to avoid to do this.
Is there maybe a more specific approach (one that a simple user could perform) or would it make sense to remove and reinstall the openHAB Cloud Connector (which would surprise me though…)…
Thanks to everybody taking the effort to help or contribute with own experiences in this regards!
Chris
