I recently purchased an Aladdin Garage Door Controller. I would like to incorporate it into OpenHAB, but haven’t found a way to do it. Has anyone else looked into this controller?
Thanks.
Thanks.
Somebody would need to volunteer to write a binding. I see Home Assistant has a binding. Perhaps somebody could get hints from their Python based binding.
It looks like the HA integration depends on this Python library and a quick perusal of the code it looks like it uses an cloud based API. If a binding is beyond what you think you can manage, there are other alternatives.
set it up as an external script that you access using the Exec binding, executeCommandLine, or if it needs to stay running, using something like MQTT (see GitHub - rkoshak/sensorReporter: A python based service that receives sensor inputs and publishes them in various ways. for a platform that would be easier to integrate with than an OH binding).
Import the library and use it from JSR223 Jython rules. This assumes it isn’t doing anything Python 3 specific.
See if there is support in some other system that OH can integrate with like NodeRed.
I recently bought a house with one of these garage door openers already installed.
I just got around to configuring it in the Aladdin Connect app and confirmed that it works as it should.
I then took a look at the aladdin-connect python library. Despite it not having been updated for a while, I was able to use the example code without issue to query my garage door status.
I will spend some time in the near future working up a more functional script and integrating it with my OpenHAB system and will post some updates when I get it working.
I got this working yesterday, I had to modify a couple of scripts to do this. This is what I came up with:
Go to this site and follow the instructions to get the necessary information:
I will let you know that I could not find the portal key (cik) by using these instructions, but I was able to find it when I logged into my Genie Aladdin Connect account.
These are what I use for my items:
Switch Sh_Garage_Door_Open "Garage Door Open" <garagedoor-open> [ "Switchable" ] // proxy item to control rule for garage door.
Switch Sh_Garage_Door_Close "Garage Door Close" <garagedoor-close> [ "Switchable" ] // proxy item to control rule for garage door.
These are my Rules:
rule "open garage door"
Item Sh_Garage_Door_Open changed from OFF to ON
val telegramAction = getActions("telegram","telegram:telegramBot:23707ee5")
executeCommandLine=("/etc/openhab2/scripts/garage-open.sh")
Sh_Garage_Door_Close.sendCommand(OFF)
telegramAction.sendTelegram(XXXXXXXXXL,"Garage door has been opened")
logInfo("doors","garage door has been opened")
rule "close garage door"
Item Sh_Garage_Door_Close changed from OFF to ON
executeCommandLine=("/etc/openhab2/scripts/garage-closed.sh")
Sh_Garage_Door_Open.sendCommand(OFF)
telegramAction.sendTelegram(XXXXXXXXXL,"Garage door has been closed")
logInfo("doors","garage door has been closed")
Here are the scripts, you will need to change your [YOUR TOKEN HERE], [YOUR CIK], [YOUR DEVICE ID] and [YOUR ACCOUNT EMAIL ADDRESS].
garagedoorOpen.sh:
#!/bin/bash
curl --location --request POST 'https://genie.m2.exosite.com/onep:v1/rpc/process' \
--header 'AppVersion: 2.10.1' \
--header 'BundleName: com.geniecompany.AladdinConnect' \
--header 'User-Agent: Aladdin Connect Android v2.10.1'\''' \
--header 'BuildVersion: 131' \
--header 'Authorization: Token: [YOUR TOKEN HERE]' \
--header 'Content-Type: application/json' \
--data '{
"auth": {
"cik": "[YOUR CIK]",
"client_id": "[YOUR DEVICE ID]"
"calls": [
"arguments": [
"alias": "dps1.desired_status"
"1"
"id": 1,
"procedure": "write"
"arguments": [
"alias": "dps1.desired_status_user"
"[YOUR ACCOUNT EMAIL ADDRESS]"
"id": 2,
garageDoorClose.sh:
#!/bin/bash
--data '{
"auth": {
"calls": [
"arguments": [
"0"
"id": 1,
"arguments": [
"id": 2,
If you notice, the only difference between the two scripts is the value of the number in “arguments”, close = 0, open = 1.
Sitemap looks like this:
Switch item=Sh_Garage_Door_Open visibility=[Sh_Garage_Door_Close==ON]
Switch item=Sh_Garage_Door_Close visibility=[Sh_Garage_Door_Open==ON]
I am sure that there is a more elegant way to do this, but like I said, I just started yesterday and this is what I came up with. I did put Alexa tags in my items file, but it’s a little awkward to tell Alexa to “turn on garage door open”. I look forward to see what you came up with.
~John
Hi John,
Just thought I’d ask, were you ever able to “refine” your process? If not, no biggie. Sometimes, just getting it to work is enough… ![]()
Todd
Hey @T.Hutchins,
No refinement, once I got it working, I let it be… probably should test it to see if it still works… I’m not a fan of the syntax to get Alexa to open the garage.
~John
Hi John,
Probably not a bad idea. It seems whenever one little thing is changed, the whole system blows up. ![]()
I don’t suppose there is a way to get it working without having to use “the cloud”?
