i’m just trying to implement “homekit:HeatingCoolingMode” for my Thermostates which are already working with alexa. (MAX! with Homegear and Homematic Binding)
My Thermostates Heating Cooling String doesn’t fit the homekit mapping, so i wanted do make my own an fire the needed commands by rules.
I’ve created a new Item and added it to my Thermostat-group:
Any idea on that meanwhile? I am not able to switch that string via Alexa. What would be the command (… in German…)?
“Alexa, turn the heating to 22 degrees” - > “Thermostat heating is set to 22 degrees”
“Alexa, switch the heating off” → “Thermostat heating does not support this”
(from German)
