I just added the lifx binding via the binding search in paper ui and the binding was installed. But after that there were pop-ups saying that all my other bindings were uninstalled.
This is the log:
10:08:24.579 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'lifx:colorlight:D073D5XXXXXX' to inbox.
10:08:24.878 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'lifx:colorlight:D073D5XXXXXX' to inbox.
10:08:24.880 [INFO ] [smarthome.event.InboxAddedEvent ] - Discovery Result with UID 'lifx:colorlight:D073D5XXXXXX' has been added.
10:08:33.290 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:chromecast:XXXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from ONLINE to UNINITIALIZED
10:08:33.297 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
java.net.SocketException: Socket closed
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) [?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:171) [?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) [?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) [?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) [?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) [?:?]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) [?:?]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) [?:?]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:71) [?:?]
at su.litvak.chromecast.api.v2.Channel.read(Channel.java:411) [203:org.openhab.binding.chromecast:2.2.0]
at su.litvak.chromecast.api.v2.Channel.access$200(Channel.java:50) [203:org.openhab.binding.chromecast:2.2.0]
at su.litvak.chromecast.api.v2.Channel$ReadThread.run(Channel.java:132) [203:org.openhab.binding.chromecast:2.2.0]
10:08:33.326 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
10:08:33.319 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:chromecast:XXXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:33.469 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - <-- null payload in message
10:08:33.428 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-chromecast'
10:08:33.394 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - <-- null payload in message
10:08:33.488 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while closing channel
10:08:33.482 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:audio:XXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from ONLINE to UNINITIALIZED
10:08:33.510 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while closing channel
10:08:33.610 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:audio:XXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:33.687 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-chromecast' has been uninstalled.
10:08:39.075 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.103 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.134 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.146 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.167 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-wifiled'
10:08:39.186 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.199 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.214 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:F0FE6BXXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.228 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:F0FE6BXXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.242 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-wifiled' has been uninstalled.
10:08:47.763 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:50-f5-da-XX-XX-XX' changed from INITIALIZING to UNINITIALIZED
10:08:48.172 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:50-f5-da-XX-XX-XX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:56.598 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-amazondashbutton'
10:08:56.610 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-amazondashbutton' has been uninstalled.
10:09:03.026 [INFO ] [smarthome.event.ItemStateChangedEvent] - jeelink_lacrosse_21_temperature changed from 4.8 to 4.9
10:09:03.037 [INFO ] [smarthome.event.ItemStateChangedEvent] - Temperature_Outdoor changed from 4.8 to 4.9
10:09:03.692 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-dmx'
10:09:03.708 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-dmx' has been uninstalled.
10:09:10.980 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:3' changed from ONLINE to UNINITIALIZED
10:09:11.005 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:11.018 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:21' changed from ONLINE to UNINITIALIZED
10:09:11.028 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:21' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:11.041 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:xxxxxxxx' changed from ONLINE to UNINITIALIZED
10:09:11.093 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:xxxxxxxx' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:11.139 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-jeelink'
10:09:11.150 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-jeelink' has been uninstalled.
10:09:18.493 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node2' changed from ONLINE to UNINITIALIZED
10:09:18.678 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:18.712 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node3' changed from ONLINE to UNINITIALIZED
10:09:18.787 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:18.803 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:xxxxxxxx' changed from ONLINE to UNINITIALIZED
10:09:21.894 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
10:09:21.928 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:xxxxxxxx' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:22.016 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-zwave'
10:09:22.027 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-zwave' has been uninstalled.
Can someone tell me why this might happened?
