HI Guys
Does anyone know if OH2 can somehow play a sound on an Android tablet when an Item switches on?
Ie: turn the tablet into an audiosink?
Thanks!
Kris
HI Guys
Thanks!
Kris
There is an app that you can run that turns your tablet into a squeezebox client which you can then send audio to…
I have been using this little program for years now. Works perfectly:
Note that you need to have a TTS engine installed on the tablet.
Cheers,
Matt
WebAudio is a generic audio sink for browsers, or are you looking to push specific audio to specific devices?
Well, i just changed a rule to play a sound and it just played on the tablet without any changes! It runs HabPanel. Works just fine now for my purpose until the Amazon Echos turn up
Old post…
Using app suggested by @mstehle . You’ll find it as APK on F-Droid. then using exec action with this
echo "whatever you want to say" | ncat <YOUR TABLET IP> 4444
Make sure the TTS and your preferred language is installed. Language can be set in the app, which could start also automatically and runs in background.
Cheers
