Animated Energy Widget
very nice widjet !
Would it possible to use this in Habpanel ?
If yes, how ?
Many thanks
Can you pls share your solution for removing battery state and format the items to float. I have the same issue with the lines (don’t show up) and can’t solve it :see_no_evil:
Thank you for this nice widget.
I updated the code from @Sebastian_Neu (V0.1) with the color changes by @jlikonen. So if ok, I would call it V0.2
It’s my first post so sorry if formatting goes wrong
please see widget code below:
uid: Energiefluss
tags: []
props:
  parameters:
    - context: item
      label: Netzeinspeisung
      required: true
      type: TEXT
    - context: item
      label: Netzbezug
      required: true
      type: TEXT
    - context: item
      label: Gesamtverbrauch
      required: true
      type: TEXT
    - context: item
      label: PV Leistung
      required: true
      type: TEXT
    - context: item
      label: Batterieleistung
      required: true
      type: TEXT
    - context: item
      label: Batterie Ladezustand
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Oct 29, 2022, 9:57:14 PM
component: f7-card
  class:
    - display-flex
    - flex-direction-column
    - align-items-center
  style:
    height: 383px
slots:
  content:
    - component: f7-block
        style:
          --f7-theme-color: var(--f7-text-color)
          display: flex
          justify-content: space-between
          padding: 0
      slots:
        default:
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      flex-direction: column
                      height: 110px
                      justify-content: center
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: oh-icon
                          height: 110px
                          icon: sma_grid_2
                      - component: Label
                          style:
                            color: red
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          text: =items[props.netzbezug].displayState
                          visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) == 0) ? true : false'
                      - component: Label
                          style:
                            color: green
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          text: =items[props.netzeinspeisung].displayState
                          visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0) ? true : false'
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-grow: 1
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            color: green
                            font-size: 25px
                            font-weight: bold
                            text-align: center
                            width: 100px
                          text: =items[props.pv_leistung].displayState
                          height: 110px
                          icon: sma_pv_2
                          style:
                            margin-top: -20px
                    style:
                      display: flex
                      margin: 0
                      padding: 0
                      width: 100%
                  slots:
                    default:
                      - component: f7-row
                          preserveAspectRatio: xMidYMid slice
                          style:
                            height: auto
                            width: auto
                          tag: svg
                          viewBox: 0 0 100 100
                          xmlns: http://www.w3.org/2000/svg
                        slots:
                          default:
                            - component: f7-row
                                d: M60 -5 v10 c0 30 10 35 30 35 h20
                                fill: none
                                stroke: rgba(243, 156, 18, 0.8)
                                stroke-width: 2
                                tag: path
                                vector-effect: non-scaling-stroke
                                visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) < 0) ? true : false'
                            - component: f7-row
                                fill: rgba(243, 156, 18, 0.8)
                                r: 6
                                style:
                                  stroke-width: 4
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      repeatCount: indefinite
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path1"
                            - component: f7-row
                                d: M40 -5 v10 c0 40 -10 35 -30 35 h-20
                                fill: none
                                stroke: rgba(22, 160, 133, 0.8)
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0 && Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) == 0) ? true : false'
                            - component: f7-row
                                fill: rgba(22, 160, 133, 0.8)
                                r: 6
                                strokeWidth: 10
                                tag: circle
                                vectorEffect: non-scaling-stroke
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path2"
                            - component: f7-row
                                d: M50, 0 v100
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0]) - (Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) + Math.abs(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]))) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path3"
                            - component: f7-row
                                d: M-5 50 l10 0 c40 0 35 10 35 50 l 0 20
                                fill: none
                                stroke: rgba(255, 0, 0, 0.8)
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) > 0) ? true : false'
                            - component: f7-row
                                fill: rgba(255, 0, 0, 0.8)
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path4"
                            - component: f7-row
                                d: M 105 50 l -10 0 c -40 0 -35 10 -35 50 l 0 20
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path5"
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -10px
                      width: 110px
                  slots:
                    default:
                          color: orange
                          height: 110px
                          icon: sma_consumption_2
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          text: =items[props.gesamtverbrauch].displayState
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -40px
                      width: 110px
                  slots:
                    default:
                      - component: oh-link
                          iconColor: red
                          iconF7: battery_0
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          text: =items[props.batterylevel].state
                          visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 10) ? true : false'
                          iconColor: orange
                          iconF7: battery_25
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 10 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 75) ? true : false'
                          iconColor: green
                          iconF7: battery_100
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 75) ? true : false'
                          height: 110px
                          icon: sma_battery_2
                          style:
                            margin-top: -20px
                      - component: Label
                          style:
                            color: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) > 0) ? "red" : "green"'
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            white-space: nowrap
                            width: 100px
                          text: =Math.abs(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0])) + ' ᵂ'
                          visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) !== 0) ? true : false'
Thanks for the great widget!
I implemented it in my openHAB and came across some questions:
  1. I miss the PV power, which I did configure correctly, but it doesn’t show.
  2. also, for some reason my battery power gets not formatted correctly to .2f at first, it does take a while (like 1 second) to get formatted?
  3. sometimes, the “0.00 W” grid power gets completely deleted and then the grid-icon “jumps” a bit.
  4. I don’t have seperate items for grid purchase and grid feed-in (its the same, becoming positive and negative), so I put in both configurations the same item, is this “the way”?
I think, I have to configure the items to a certain pattern?
Hi!
I have the same problem, the lines from panel to consumer don’t show up
Can’t help you in this case as I have no PV. For tests I just used another “Watt-Item”
Formatting could be a problem as the “.displayState” can not be used in the calculations/figuring.
If you want to have decimals, you should go this way (“.toFixed”):
 text: =Math.abs(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0])).toFixed(2) + ' ᵂ'
Otherwise you can use “parseInt” instead of “parseFloat”.
That’s my guess too. But my test seems to work ??!!
Have look here in the german forum with similar problems.
I just added some more items, which contain the feed-in and purchase seperately and now it works (sort of).
I do get the correct values, but the animation does not always tell my, where the power goes to. I’ll have to take a look, perhaps that’s some operator issue (+/-).
Thanks for this great widget!
If you don´t use a battery then don´t assign any items to it and edit the code. I had the same problem that there was no connection from solar to my house consumption.
Im new on this platform, maybe can anyone explain me how to use this custom widget with openhab habpanel? create a custom widget and inser the code. But this wont work? Maybe i done some mistakes?
It’s a Main UI widget, not for habpanel.
Hi @Sebastian_Neu
Thanks for your gread widget. I adopted it sucessfully to my system.
There is only one Edge Case Missing in your diagram:
  • Load Battery (partially) from Grid
(How) Could this be added?
Regards,
Jens
I have not taken this use case into account because it happens very rarely for me. You would still have to insert a straight path somehow. Trail & Error…
I created my own widget:
I have no battery. but I integrated some energy figures.
Thanks for this nice widget coding!
uid: SMA_widget3
tags: []
props:
  parameters:
    - context: item
      required: true
      type: TEXT
    - context: item
      label: Netzbezug
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      label: PV Leistung
      required: true
      type: TEXT
    - context: item
      label: Stromzähler
      required: true
      type: TEXT
    - context: item
      label: Strombezug
      required: true
      type: TEXT
    - context: item
      label: Gesamtproduktion
      required: true
      type: TEXT
    - context: item
      label: Tagesproduktion
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Dec 30, 2022, 11:22:12 AM
component: f7-card
  class:
    - display-flex
  style:
    height: 365px
slots:
  content:
        style:
          display: flex
          padding: 0
      slots:
        default:
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
                text-align: left
            slots:
              default:
                    style:
                      align-items: left
                      display: flex
                      height: 140px
                      justify-content: left
                      margin-right: -10px
                      width: 140px
                      text-align: left
                      top: -25px
                  slots:
                    default:
                      - component: Label
                          style:
                            color: red
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 110px
                          text: =Math.abs(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0])).toFixed(0) + ' ᵂ'
                          visible: '= Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0 ? true : false'
                      - component: Label
                          style:
                            color: green
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 110px
                          text: = '-' + Math.abs(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0])).toFixed(0) + ' ᵂ'
                          visible: '= Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) <= 0 ? true : false'
                          height: 110px
                          icon: sma_grid_2
                          width: 110px
                          iconColor: green
                          iconF7: arrow_turn_up_left
                          iconSize: 20px
                          style:
                            font-size: 15px
                            font-weight: bold
                            left: 0px
                            margin-top: -10px
                            align: left
                            top: 0px
                            white-space: nowrap
                          text: =Math.abs(Number.parseFloat(items[props.stromeinspeisung].state.split(" ")[0])).toFixed(0) + ' kWh'
                          visible: "true"
                          iconColor: red
                          iconF7: arrow_turn_down_right
                          iconSize: 20px
                          style:
                            font-size: 15px
                            font-weight: bold
                            align: left
                            left: 0px
                            top: 0px
                            white-space: nowrap
                          text: =Math.abs(Number.parseFloat(items[props.strombezug].state.split(" ")[0])).toFixed(0) + ' kWh'
                          visible: "true"
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-grow: 1
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            text-align: center
                            width: 100px
                          text: =Math.abs(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0])).toFixed(0) + ' ᵂ'
                          height: 110px
                          icon: sma_pv_2
                          style:
                            margin-top: -20px
                    style:
                      display: flex
                      margin: 0
                      padding: 0
                      width: 100%
                  slots:
                    default:
                      - component: f7-row
                          style:
                            height: 100px
                            width: 100px
                          tag: svg
                        slots:
                          default:
                            - component: f7-row
                                fill: none
                                stroke: rgba(100, 150, 200, 0.8)
                                stroke-width: 2
                                tag: path
                                visible: "false"
                            - component: f7-row
                                fill: rgba(100, 150, 200, 0.8)
                                r: 6
                                style:
                                  stroke-width: 4
                                tag: circle
                                visible: "false"
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '= Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) < 0  ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                d: M50, 0 v100
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=Number.parseFloat(items[props.pv_leistung].state.split(" ")[0])  > 0 ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: "false"
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                                visible: "false"
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -10px
                      width: 110px
                  slots:
                    default:
                          color: orange
                          height: 110px
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          text: =Math.abs(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0])).toFixed(0) + ' ᵂ'
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: left
                      display: flex
                      height: 110px
                      margin-top: -100px
                      width: 110px
                  slots:
                    default:
                          iconAlign: left
                          iconColor: black
                          iconF7: sum
                          iconSize: 15px
                          style:
                            font-size: 15px
                            font-weight: bold
                            left: 25px
                            margin-left: -50px
                            position: absolute
                            text-align: right
                            top: 40px
                            white-space: nowrap
                          text: =Math.abs(Number.parseFloat(items[props.gesamtproduktion].state.split(" ")[0])).toFixed(0) + ' kWh'
                          visible: "true"
                          iconAlign: left
                          iconColor: black
                          iconF7: calendar_today
                          iconSize: 15px
                          style:
                            font-size: 15px
                            font-weight: bold
                            left: 25px
                            margin-left: -50px
                            position: absolute
                            text-align: right
                            top: 60px
                            white-space: nowrap
                          text: =Math.abs(Number.parseFloat(items[props.tagesproduktion].state.split(" ")[0])).toFixed(0) + ' kWh'
                          visible: "true"
And would you mind to share your changes to the existing widget?
Thx!
Hi guys,
can you please help me to fix the following problem:
When my solar system isn´t providing any energy I still see the green line from the solar panel icon to the consumer icon.
Any idea how to fix this?
Please see attached my code:
uid: SMA_widget_w_o_battery
tags: []
props:
  parameters:
    - context: item
      required: true
      type: TEXT
    - context: item
      label: Netzbezug
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      label: PV Leistung
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Nov 17, 2022, 11:17:48 AM
component: f7-card
  class:
    - display-flex
  style:
    height: 383px
slots:
  content:
        style:
          display: flex
          padding: 0
      slots:
        default:
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                          height: 110px
                          icon: sma_grid_2
                      - component: Label
                          style:
                            color: red
                            font-size: 20px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                      - component: Label
                          style:
                            color: green
                            font-size: 20px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-grow: 1
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            color: green
                            font-size: 20px
                            font-weight: bold
                            text-align: center
                            width: 100px
                          height: 110px
                          icon: sma_pv_2
                          style:
                            margin-top: -5px
                    style:
                      display: flex
                      margin: 0
                      padding: 0
                      width: 100%
                  slots:
                    default:
                      - component: f7-row
                          style:
                            height: auto
                            width: auto
                          tag: svg
                        slots:
                          default:
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 4
                                style:
                                  stroke-width: 4
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 4
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                d: M50, 0 v100
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0]) - (Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0])  ? true : false'
                            - component: f7-row
                                fill: rgba(60, 160, 133, 0.8)
                                r: 4
                                strokeWidth: 2
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 4
                                strokeWidth: 5
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 4
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -10px
                      width: 110px
                  slots:
                    default:
                          color: orange
                          height: 110px
                      - component: Label
                          style:
                            font-size: 20px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -40px
                      width: 110px
                  slots: {}
Do you know if there is a online service passing as request the needed parameter generating the image, could be amazing in the sitemap?
Could anybody help me with edit this widget? I have solax inverter with battery. And there I have just one number for feed in enegry and it’s starting with - when consumtion is higher than production for example -633W,and without - when my production is higher than consumption for example 633W.
Thank you.
I’ve solved it by myself. If anybody have a Solax inverter. With this it should works without any problem
uid: SMA_widget
tags: []
props:
  parameters:
    - context: item
      required: true
      type: TEXT
    - context: item
      label: Netzbezug
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      label: PV Leistung
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Mar 10, 2023, 2:42:30 PM
component: f7-card
  class:
    - display-flex
  style:
    height: 383px
slots:
  content:
        style:
          display: flex
          padding: 0
      slots:
        default:
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                          height: 110px
                          icon: sma_grid_2
                      - component: Label
                          style:
                            color: red
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          visible: '=(Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) < 0) ? true : false'
                      - component: Label
                          style:
                            color: green
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0 || Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) == 0) ? true : false'
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-grow: 1
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            text-align: center
                            width: 100px
                          height: 110px
                          icon: sma_pv_2
                          style:
                            margin-top: -20px
                    style:
                      display: flex
                      margin: 0
                      padding: 0
                      width: 100%
                  slots:
                    default:
                      - component: f7-row
                          style:
                            height: auto
                            width: auto
                          tag: svg
                        slots:
                          default:
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                style:
                                  stroke-width: 4
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                d: M50, 0 v100
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -10px
                      width: 110px
                  slots:
                    default:
                          color: orange
                          height: 110px
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -40px
                      width: 110px
                  slots:
                    default:
                          iconColor: red
                          iconF7: battery_0
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          iconColor: orange
                          iconF7: battery_25
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          iconColor: green
                          iconF7: battery_100
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          height: 110px
                          icon: sma_battery_2
                          style:
                            margin-top: -20px
                      - component: Label
                          style:
                            color: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) < 0) ? "red" : "green"'
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            white-space: nowrap
                            width: 100px
I like and use this widget and customized it.
But to be frank, I’m not good at UI design, I’m struggling with the CSS part particularly to properly align stuff and would like to ask the author to extend the widget rather than continue trying my own customizations. This would obviously be of benefit to others than just me, too.
Below’s my current version for your benefit, the main change is the display addition of the current power tariff including a hint as to whether that’s currently cheap or not (useful if you have a variable power tariff).
Additionally, I’d like to ask adding these features:
  • there’s a flow missing: grid ↔ battery.
  • I’d like to have a generic picture (of the inverter or whatever) somewhere central in the background, maybe half-transparent. (But I failed several times trying to do that myself)
Thanks for looking into this again.
uid: EnergyFlowWidget
tags: []
props:
  parameters:
    - context: item
      label: Netz
      required: false
      type: TEXT
    - context: item
      required: false
      type: TEXT
    - context: item
      label: PV Leistung
      required: false
      type: TEXT
    - context: item
      label: Strompreis
      required: false
    - context: item
      label: Preisniveau
      required: false
    - context: item
      label: Batterie laden
      required: false
      type: TEXT
    - context: item
      label: Wallbox
      required: false
      type: TEXT
    - context: item
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Mar 17, 2023, 10:43:25 PM
component: f7-card
  class:
    - display-flex
  style:
    background: url(/static/home.png)
    background-position: center
    background-size: cover
    height: 400px
slots:
  content:
        style:
          display: flex
      slots:
        default:
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 150px
                      margin-top: -20px
                  slots:
                    default:
                          height: 60
                          icon: iconify:icon-park-outline:electric-wave
                          style:
                            margin-top: 50px
                          action: popup
                          actionModal: page:netz
                          height: 75
                          icon: clickable
                          style:
                            margin-top: -75px
                      - component: Label
                          action: popup
                          actionModal: page:stromRechnung
                          style:
                            color: '=(Number.parseFloat(items[props.netz].displayState.split(" ")[0]) < 0) ? "red" : "green"'
                            font-size: 16px
                            font-weight: bold
                            margin-top: 0px
                            text-align: center
                            white-space: nowrap
                            width: 100px
                          text: =@props.netz
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-grow: 1
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 130px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 16px
                            font-weight: bold
                            text-align: center
                            width: 100px
                          text: =@props.pv_leistung
                          height: 75px
                          icon: iconify:ic:outline-solar-power
                          style:
                            margin-top: 5px
                          action: popup
                          actionModal: page:wr
                          height: 75px
                          icon: clickable
                          style:
                            margin-top: -75px
                          height: 120px
                          icon: icon_bg_red
                          style:
                            margin-top: -100px
                    style:
                      display: flex
                      margin: 0
                      padding: 0
                      width: 100%
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 0.9em
                            font-weight: bold
                            margin-left: -115px
                            margin-top: -25px
                            text-align: center
                            white-space: nowrap
                          text: "=@props.strompreis + ' ' + ((items[props.preisniveau].state == 4) ? '💸' : ((items[props.preisniveau].state == 1) ? '👍' : ((items[props.preisniveau].state == 2) ? '✓' : 'Ø'))) + ' '"
                      - component: f7-row
                          style:
                            height: auto
                            width: auto
                          tag: svg
                        slots:
                          default:
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.batterieladen].state.split(" ")[0]) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                style:
                                  stroke-width: 4
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.netz].state.split(" ")[0]) > 0 && Number.parseFloat(items[props.pv_leistung].state.split(" ")[0]) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                d: M50, 0 v100
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0]) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.netz].state.split(" ")[0]) < 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.batterieladen].state.split(" ")[0]) < 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -10px
                      width: 110px
                  slots:
                    default:
                          height: 50px
                          icon: iconify:fa6-solid:house-chimney-user
                          action: popup
                          actionModal: page:house
                          height: 60
                          icon: clickable
                          style:
                            margin-top: -60px
                      - component: Label
                          style:
                            font-size: 16px
                            font-weight: bold
                            margin-top: 10px
                            text-align: center
                            width: 100px
                          text: =@props.gesamtverbrauch
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 150px
                      margin-top: -20px
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 20px
                            font-weight: bold
                            margin-bottom: 20px
                          text: =@props.batterylevel
                          height: 75px
                          icon: iconify:bi:battery-charging
                          style:
                            margin-top: -20px
                          action: popup
                          actionModal: page:bat
                          height: 75px
                          icon: clickable
                          style:
                            margin-top: -75px
                      - component: Label
                          action: popup
                          style:
                            color: '=(Number.parseFloat(items[props.batterieladen].state.split(" ")[0]) < 0) ? "red" : "green"'
                            font-size: 16px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            white-space: nowrap
                            width: 100px
                          text: =@props.batterieladen
how you added upper index W
or special icons ?
ctrl+c / ctrl+v not working for me
