Dear openHAB and solar “comrades-in-arms”,
I got the described widget working on my system and was able to adapt it quite well to my needs.
My primary solar system is a “Fronius Symo Gen24 Plus 10” + 16.6kWh battery + solar panels 5.58kW on the garage roof in 285° west orientation, 15° inclination).
In addition, I currently have ONE PV system (600W) and soon TWO more small PV systems (960W + 1920W) mounted in the stairwell in south orientation on smaller partial areas (195° south orientation, 80° inclination for winter optimization).
Unfortunately, I am just too stupid to understand this f7 programming at the crucial points to adapt this representation for me now. I just can’t manage to rebuild/extend the widget in the code in a meaningful way, as I can’t really find any catchy complex examples. I’m still having a lot of trouble getting a handle on the syntax and incorporating additional representations so that they end up where I want them.
LINEUP is still at the moment…
a.) EITHER make the current flow representation layered so that all three small mini PVs (APSys, DEYE 1k and DEYE 2k) show their current flow directly to the consumer grid without messing up the existing diagram (icons of battery and battery level on top).
b.) OR I put another wide green strip at the very bottom behind the consumer symbol, so to speak as a collective line of all my consumers and let the mini PV animations of the current flow only straight down.
Do you have tips for me to solve this?
uid: FRONIUS_widget
tags: []
props:
parameters:
- context: item
label: Netzeinspeisung
required: true
type: TEXT
- context: item
label: Netzbezug
required: true
type: TEXT
- context: item
label: Gesamtverbrauch
required: true
type: TEXT
- context: item
label: PV Leistung
required: true
type: TEXT
- context: item
label: PV Leistung APSys
required: false
type: TEXT
- context: item
label: PV Leistung DEYE1k
required: false
type: TEXT
- context: item
label: PV Leistung DEYE2k
required: false
type: TEXT
- context: item
label: Batterieleistung
required: true
type: TEXT
- context: item
label: Batterie Ladezustand
required: true
type: TEXT
parameterGroups: []
timestamp: May 20, 2023, 11:54:36 AM
component: f7-card
class:
- display-flex
- flex-direction-column
- align-items-center
style:
height: 512px
slots:
content:
- component: f7-block
style:
--f7-theme-color: var(--f7-text-color)
display: flex
justify-content: space-between
padding: 0
slots:
default:
- component: f7-col
style:
align-items: center
display: flex
flex-direction: row
slots:
default:
style:
align-items: center
display: flex
flex-direction: column
height: 110px
justify-content: center
margin-top: 0
width: 110px
slots:
default:
- component: oh-icon
height: 110px
icon: INVERTER_grid_2
style:
margin-top: -130px
- component: Label
style:
color: red
font-size: 20px
font-weight: bold
margin-top: -16px
text-align: center
white-space: nowrap
width: 100px
text: =(Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) - Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0])) + " W"
visible: '=(Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) - Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0) ? true : false'
- component: Label
style:
color: green
font-size: 20px
font-weight: bold
margin-top: -16px
text-align: center
white-space: nowrap
width: 100px
text: =((Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) - Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0])) * -1) + " W"
visible: '=(Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) - Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) < 0) ? true : false'
- component: f7-col
style:
align-items: center
display: flex
flex-grow: 1
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: 0
width: 110px
slots:
default:
- component: Label
style:
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: ="Fronius"
- component: Label
style:
color: orange
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: =items[props.pv_leistung].displayState
height: 110px
icon: INVERTER_pv_2
style:
margin-top: -30px
style:
display: flex
margin: 0
padding: 0
width: 100%
slots:
default:
- component: f7-row
preserveAspectRatio: xMidYMid slice
style:
height: auto
width: auto
tag: svg
viewBox: 0 0 100 100
xmlns: http://www.w3.org/2000/svg
slots:
default:
- component: f7-row
d: M60 -5 v10 c0 30 10 35 30 35 h20
fill: none
stroke: rgba(100, 150, 200, 0.8)
stroke-width: 2
tag: path
vector-effect: non-scaling-stroke
visible: '=(items[props.batterieleistung].state.split(" ")[0]) < 0 ? true : false'
- component: f7-row
fill: rgba(100, 150, 200, 0.8)
r: 6
style:
stroke-width: 4
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
repeatCount: indefinite
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path1"
- component: f7-row
d: M40 -5 v10 c0 40 -10 35 -30 35 h-20
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0 && Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) == 0) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
vectorEffect: non-scaling-stroke
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path2"
- component: f7-row
d: M50, 0 v100
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0])) > 1 ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path3"
- component: f7-row
d: M-5 50 l10 0 c40 0 35 10 35 50 l 0 20
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) > 0) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path4"
- component: f7-row
d: M 105 50 l -10 0 c -40 0 -35 10 -35 50 l 0 20
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) > 0) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path5"
style:
align-items: center
display: flex
height: 110px
margin-top: -10px
width: 110px
slots:
default:
height: 90px
icon: inverter_fronius_gen_24
- component: Label
style:
display: flex
margin: 0
padding: 0
width: 100%
slots:
default:
- component: f7-row
style:
height: auto
width: auto
tag: svg
slots:
default:
- component: f7-row
d: M50, 0 v100
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0])) < 1 ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path9"
style:
align-items: center
display: flex
height: 110px
margin-top: -80px
width: 110px
slots:
default:
height: 110px
icon: consumption
- component: Label
style:
color: '=(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0]) > 0) ? "green" : "red"'
font-size: 20px
font-weight: bold
margin-top: -18px
text-align: center
white-space: nowrap
width: 100px
text: =(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0])).toFixed(0) + " W"
visible: '=(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0]) > 0) ? true : false'
- component: Label
style:
color: '=(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0]) < 0) ? "red" : "green"'
font-size: 20px
font-weight: bold
margin-top: -18px
text-align: center
white-space: nowrap
width: 100px
text: =(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0]) * -1).toFixed(0) + " W"
visible: '=(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0]) < 0) ? true : false'
- component: f7-col
style:
align-items: center
display: flex
flex-direction: row
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: -40px
width: 110px
slots:
default:
height: 40em
icon: akku_0
style:
margin-top: -160px
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) <= 12) ? true : false'
- component: oh-link
style:
font-size: 20px
font-weight: bold
white-space: nowrap
text: =items[props.batterylevel].state
height: 40em
icon: akku_12
style:
margin-top: -160px
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) > 12 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 25) ? true : false'
style:
font-size: 20px
font-weight: bold
white-space: nowrap
height: 40em
icon: akku_25
style:
margin-top: -130px
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 25 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 50) ? true : false'
style:
font-size: 20px
font-weight: bold
white-space: nowrap
height: 40em
icon: akku_50
style:
margin-top: -160px
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 50 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 75) ? true : false'
style:
font-size: 20px
font-weight: bold
white-space: nowrap
height: 40em
icon: akku_75
style:
margin-top: -160px
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 75 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 90) ? true : false'
style:
font-size: 20px
font-weight: bold
white-space: nowrap
height: 40em
icon: akku_90
style:
margin-top: -160px
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 90 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 99) ? true : false'
style:
font-size: 20px
font-weight: bold
white-space: nowrap
height: 40em
icon: akku_100
style:
margin-top: -160px
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) > 99) ? true : false'
style:
font-size: 20px
font-weight: bold
white-space: nowrap
height: 110px
icon: BATTERY_pv
style:
margin-top: -10px
- component: Label
style:
color: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) > 0) ? "red" : "green"'
font-size: 20px
font-weight: bold
margin-top: 0
text-align: center
white-space: nowrap
width: 100px
text: =(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0])).toFixed(0) + " W"
- component: Label
style:
color: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) < 0) ? "green" : "red"'
font-size: 20px
font-weight: bold
margin-top: 0
text-align: center
white-space: nowrap
width: 100px
text: =(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) * -1).toFixed(0) + " W"
visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) < 0) ? true : false'
- component: f7-col
style:
align-items: center
display: flex
flex-grow: 1
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: 0
width: 110px
slots:
default:
- component: Label
style:
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: ="APSys"
- component: Label
style:
color: orange
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: =items[props.pv_leistungapsys].displayState
height: 110px
icon: INVERTER_pv_2
style:
margin-top: -30px
style:
display: flex
margin: 0
padding: 0
width: 100%
slots:
default:
- component: f7-row
style:
height: auto
width: auto
tag: svg
viewBox: 0 0 100 300
slots:
default:
- component: f7-row
d: M40 -5 v230 c0 40 -10 35 -30 35 h-20
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.pv_leistungapsys].state.split(" ")[0]) > 0 ) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path6"
- component: f7-col
style:
align-items: center
display: flex
flex-grow: 1
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: 0
width: 110px
slots:
default:
- component: Label
style:
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: ="DEYE 1K"
- component: Label
style:
color: orange
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: =items[props.pv_leistungdeye1k].displayState
height: 110px
icon: INVERTER_pv_2
style:
margin-top: -30px
style:
display: flex
margin: 0
padding: 0
width: 100%
slots:
default:
- component: f7-row
style:
height: auto
width: auto
tag: svg
slots:
default:
- component: f7-row
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.pv_leistungdeye1k].state.split(" ")[0]) > 0 ) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path7"
- component: f7-col
style:
align-items: center
display: flex
flex-grow: 1
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: 0
width: 110px
slots:
default:
- component: Label
style:
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: ="DEYE 2k"
- component: Label
style:
color: orange
font-size: 20px
font-weight: bold
text-align: center
white-space: wrap
width: 100px
text: =items[props.pv_leistungdeye2k].displayState
height: 110px
icon: INVERTER_pv_2
style:
margin-top: -30px
style:
display: flex
margin: 0
padding: 0
width: 100%
slots:
default:
- component: f7-row
style:
height: auto
width: auto
tag: svg
slots:
default:
- component: f7-row
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.pv_leistungdeye2k].state.split(" ")[0]) > 0 ) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path8"
kind regards
Tommy / openHAB-Rookie
