Announcing OpenWeatherMap binding for Eclipse SmartHome / openHAB
The free API does not provide daily forecasts, so you must set forecastDays to 0. In order to get a 5 day forecast (24 * 5 = 120), you will need to set forecastHours to 120 and aggregate the hourly forecast, which comes in 3h chunks. See…
This is not correct. You can configure your location to be any valid coordinates and get reports. After making a change to the Thing, you will not notice a change until the next poll interval. The openweathermap binding will also pull the coordinates from your OH system settings (Configuration> System> Regional Settings).
