very interesting and nice device, cheap…like 30 euro. it broadcasts data via BLE, you could sniff it and send via mqtt to openhab
only problem, its sold only in russia…
but still, interesting article I came accross
if someone finds a chinese copy of it, please post
Just had another look, seems like the reflective version is out of stock, only the hall version available right now.
But correct, even trying to add the hall version doesn’t fill the basket. Probably best to contact them by email to see what might be their issue. Apologies for linking to a non-functioning shop - thought it would be a good alternative to the one you mentioned in your post
Hall registers magnetic pulses vs. reflective registering the light/dark changes, probably of the rotating cogwheel on the water meter. I assume it depends on the water meter versions you have.
Ah ok, sorry, my misunderstanding. I assumed you had a water meter already, or will need to have one installed by the water company, then with the possibility to add this sensor on top.
All the best with finding a complete version somewhere else.
I don’t want to spam with opening new topics, but I found an interesting and relatively cheap smart valve
it comes in 3 pipe sizes…
it seems its tuya (smart life) platform, which means it could potentially be flashed with Tasmota.
Thoughts? does it look good enough for main house valve (We noticed that there are many kinds of water pipe sizes, we choose 4 mainstream size of DN15, DN20, DN25, DN32.)
or is it more like a toy for sprinklers?
edit: i read the amazon reviews, people use it as a mains shut off valve…
Are you in the Netherlands by any chance? If so, which meter (model) do you have? I tried to make a solution like yours but isn’t working.
Is it a DIY-project or ready made one?
