I came past this post in 2021. So funny and recognisable ![]()
Pretty much everyone is because itâs a major concern. I prefer CAF (Cohabitants Acceptance Factor) since its more inclusive. Not all home automation developers have wives and the concern extends beyond just the spouse or significant other to include all users of the home which includes children, room mates, house guests, etc.
LOL
The WAF (commonly Wife Acceptance Factor) is a fundamental design parameter in home automation. It is a necessary goal of any married or co-habiting automator to achieve a high WAF in any control system. Please let me apologise in advance to any female automators, programmers and hobbyist tinkerers out there because I do understand this is a stereotype but then if you look at these forums, you can see why.
In simple terms, if it needs (ever) to be rebooted, programmed, coded or otherwise âtinkered withâ to get it to work or to adjust its settings for day to day use then this lowers your WAF. It needs to just âworkâ⊠all the time. She doesnât care if youâve given it all sorts of extra functionality, she needs it to work.
Furthermore it needs to work like a household appliance. In other words, if a switch has an obvious function then it should perform that function, simply, when it is pressed. You can program all sorts of extra functionality - double clicks, long presses etc into that switch if you like, but if you have something that looks like a light switch on the wall then, when pressed, that switch absolutely must switch on the lights like light switches have done for a hundred years and like you would intuitively expect it to. It must not do something you would not expect it to like render your lights inoperable.
It works the other way around too. Whatever wonderful tricks your lighting or heating might be able to do with your fancy bit of code, you still need a switch on the wall that works like a switch should.
See also the similar GOF (Guest Operability Factor) - no guest is going to want to install the Philips Hue app just to turn on the lights in the guest room.
So, for example, my dining room lights are hue bulbs. Those bulbs need to be permanently live in order to work, which means you canât use regular light switches or you, or your wife, or some guest will switch them off. No-one wants to have to choose which one is the âcorrectâ light switch to use and besides the Hue switches are horrible. So I have very elegant momentary switches where the old light switches were and they are connected to a re-jigged two-way switching circuit. The switches operate a Fibaro z-wave double controller in the wall, which gives me all sorts of extra control possibilities. The Fibaro unit is not directly connected to the (always live) lights at all but just sends messages to OpenHAB where all the clever stuff happens. Apart from on/off, I have dimming and colour temperature functionality built in to the double and long press functions, which I never actually use because the lights come on at different colour temperatures automatically depending on the time of day / sunrise / sunset times because breakfast needs a whiter light, lunch less so and an evening meal needs a warmer light. All my wife needs to know is how to switch the lights on (press the switch) and off again (press it again) and how to select the âsewing sceneâ which gives her a 6,500K âdaylight whiteâ when sheâs using the dining room table to design a quilt, which sheâs delighted with. Switch 1 operates the overhead lights, switch 2 the table lamps - done. She does not need to know (and is absolutely not interested in) how anything else works.
Donât forget âHappy Wife - Happy Lifeâ
PS - she has made me write out a complete description and plans of all the rewiring in our 300 year old house so that, God forbid, if I get hit by a bus, she can get an electrician in for a day and put it all back to normal.
blasphemy!
Again - cohabitant. Not wife. As @rlkoshak said above - cohabitant is much more inclusive and thus accurate. You yourself mentioned that using wife is a stereotype so why laugh and perpetuate it?
Thatâs even not enough, I found out! I use Friends of Hue and Homematic switches in the design of our Gira equipment and installed them the way all the classic switches are installed, meaning that tipping the top switches light off, tipping the lower part switches the light on (as long as there is no special situation with several switches for one light). The only difference is, that these switches do not indicate a concrete position of the switch (like all the buttons for the relays) but show a middle position and return to that). And the FoH switches sound different as they use energy harvesting. Even these little differences causes confusion here and my wife prefers to use lights that have classical switches over the ones with automated switches and demands that there always at least one classical switch has to survive in every room. And no question: She never uses the dimmer option for the Hue-Lights and normally does not tough one of the touchpanels in the house running HABPanel in a very simple and reduced form.
