@laursen
Explored the log using TRACE. Don’t see too much but it might tell you more:
2022-11-24 15:45:41.003 [TRACE] [.MieleGatewayCommunicationController] - The request '{"jsonrpc":"2.0","id":91534805,"method":"HDAccess/getDeviceClassObjects","params":["hdm:LAN:000178022763#0",true]}' yields '{"id":91534805,"result":[{"DeviceClassType":"Actuator","Operations":[{"Name":"start","Metadata":{"Filter":"false","description":"Start operation which must force the protocol adapter implementation to send Start command to the appliance.","LocalizedID":"Start"}},{"Name":"stop","Metadata":{"Filter":"true","description":"Stop operation which must force the protocol adapter implementation to send Stop command to the appliance.","LocalizedID":"Stop"}}],"DeviceClass":"com.miele.xgw3000.gateway.hdm.deviceclasses.MieleTumbleDryer","Properties":[{"Name":"companyId","Value":"MI","Polling":0,"Metadata":{"Filter":"false","description":"Company ID","access":"R"}},{"Name":"brandId","Value":"MI","Polling":0,"Metadata":{"Filter":"false","description":"Brand ID","access":"R"}},{"Name":"productTypeId","Value":22018,"Polling":0,"Metadata":{"Filter":"false","description":"Company ID","access":"R"}},{"Name":"mieleDeviceType","Value":2,"Polling":0,"Metadata":{"Filter":"false","description":"Miele Device Type","LocalizedValue":"Wäschetrockner","access":"R"}},{"Name":"extendedDeviceState","Polling":0,"Metadata":{"Filter":"false","description":"Extended Device State","access":"RE"}},{"Name":"specificationVersion","Value":0,"Polling":0,"Metadata":{"Filter":"false","description":"Specification Version","access":"R"}},{"Name":"state","Value":5,"Polling":0,"Metadata":{"Filter":"true","description":"Property name for the appliance's current state.","LocalizedID":"Gerätestatus","enum":{"End":"7","Abort":"9","Service":"12","Off":"1","Stand-By":"2","Programmed":"3","Paused":"6","Unknown":"0","Running":"5","Failure":"8","Locked":"145","Not Connected":"255","Waiting to Start":"4"},"LocalizedValue":"In Betrieb","access":"RE"}},{"Name":"internalDeviceState","Value":0,"Polling":0,"Metadata":{"Filter":"false","description":"Internal Device State","access":"RE"}},{"Name":"mieleName","Value":"TWH780WP","Polling":0,"Metadata":{"Filter":"false","description":"User Appliance Name","access":"RWE"}},{"Name":"remoteEnabledFlag","Value":15,"Polling":0,"Metadata":{"Filter":"false","description":"Remote Enabled Flag","access":"RE"}},{"Name":"smartGridEnabledFlag","Value":0,"Polling":0,"Metadata":{"Filter":"false","description":"SmartGrid Enabled Flag","access":"RE"}},{"Name":"programSelectionEnabledFlag","Value":0,"Polling":0,"Metadata":{"Filter":"false","description":"Program Selection Enabled Flag","access":"RE"}},{"Name":"tunnelingVersion","Value":4,"Polling":0,"Metadata":{"Filter":"false","description":"Tunneling Version","access":"R"}},{"Name":"programType","Value":3,"Polling":0,"Metadata":{"Filter":"false","description":"Program Type","access":"RE"}},{"Name":"programId","Value":2,"Polling":0,"Metadata":{"Filter":"false","description":"Property name for the currently selected program on the appliance.","access":"RE"}},{"Name":"phase","Value":2,"Polling":0,"Metadata":{"Filter":"true","description":"Property name for the current phase of a running program on the appliance.","LocalizedID":"Phase","LocalizedValue":"Trocknen","access":"RE"}},{"Name":"rawPhase","Value":514,"Polling":0,"Metadata":{"Filter":"false","description":"Program Phase Raw Value","access":"RE"}},{"Name":"dryingStep","Value":2,"Polling":0,"Metadata":{"Filter":"true","description":"Property name for the current drying step of a running program on the appliance.","LocalizedID":"Trockenstufe","LocalizedValue":"Schranktrocken","access":"RE"}},{"Name":"startTime","Value":0,"Polling":0,"Metadata":{"unit":"min","Filter":"false","description":"Property name for the selected start time of the appliance.","LocalizedID":"Startzeit","access":"RWE"}},{"Name":"duration","Value":131,"Polling":0,"Metadata":{"unit":"min","Filter":"true","description":"Property name for the current duration of the selected program of the appliance.","LocalizedID":"Restzeit","LocalizedValue":"2:11","access":"RE"}},{"Name":"elapsedTime","Value":0,"Polling":0,"Metadata":{"Filter":"false","description":"Total elapsed time of a program running process in minutes","LocalizedID":"Laufzeit","access":"RE"}},{"Name":"finishTime","Value":131,"Polling":0,"Metadata":{"Filter":"false","description":"Finish Time (Relative) in minutes","LocalizedID":"Endzeit","access":"RE"}},{"Name":"signalFailure","Value":false,"Polling":0,"Metadata":{"Filter":"false","description":"Signal Failure","LocalizedID":"Fehler!","access":"RE"}},{"Name":"signalInfo","Value":false,"Polling":0,"Metadata":{"Filter":"false","description":"Signal Info","LocalizedID":"Hinweis","access":"RE"}},{"Name":"signalDoor","Value":false,"Polling":0,"Metadata":{"Filter":"false","description":"Signal Door","LocalizedID":"Tür ist offen!","access":"RE"}},{"Name":"processAction","Polling":0,"Metadata":{"Filter":"false","description":"Process Action","enum":{"":"0","Disable Gas":"8","Enable Gas":"9","Start":"1","Stop Superfreezing":"5","Start Supercooling":"6","Stop Supercooling":"7","Pause":"3","Start Superfreezing":"4","Stop":"2"},"access":"W"}}]}],"jsonrpc":"2.0"}
This contains the strings “ExtendedDeviceState” and “SmartGrid”.
Also see the following lines:
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - internalDeviceState is not a valid channel for a TumbleDryer
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - mieleName is not a valid channel for a TumbleDryer
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - remoteEnabledFlag is not a valid channel for a TumbleDryer
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - smartGridEnabledFlag is not a valid channel for a TumbleDryer
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - programSelectionEnabledFlag is not a valid channel for a TumbleDryer
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - tunnelingVersion is not a valid channel for a TumbleDryer
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - signalFailure is not a valid channel for a TumbleDryer
2022-11-24 15:38:49.394 [TRACE] [ternal.handler.MieleApplianceHandler] - signalInfo is not a valid channel for a TumbleDryer
Don’t see any data which correlates with actually 0.3 kWh visible in the Miele app. Think that it has to do with SmartGrid?
Detected another issue. Elapsed time remains 00:00 h and is not updated during the dryer run:
