my update also stops with signature invalid as reported by the last posts.
Updated the repo-list as mentioned by Burkart before that.
Using RPi with rasbian stretch
Do not want to switch off security by [trusted=yes]
Hope someone can help here!
Thanks.
Christian
The issue with the stable repo has been resolved now. Iâd reccomend using the bintray server for the stable releases.
So you recommend me and others who changed the file openhab2.list according to @mstormiâs
solution should change it back to the original âhttps://dl.bintray.com/openhab/apt-repo2 stable mainâ?
Both repositories will continue to work fine, but the Bintray server is better suited to distribution-time releases than the jfrog (artifactory) server.
I could try whatever I want - I always got GPG errors for the OpenHAB repos, both jfrog and bintray. This is what worked for me in the end:
Delete apt status information:
sudo rm -rf /var/lib/apt/lists/*
Load bintray key again:
wget -qO - 'https://bintray.com/user/downloadSubjectPublicKey?username=openhab' | sudo apt-key add -
After that, apt-get update started working again.
Any idea why I am getting an error when running the command?
Gives me:
curl: option -: is unknown
curl: try 'curl --help' or 'curl --manual' for more information
gpg: no valid OpenPGP data found.
You probably have messed up your installation or are using some exotic OS, but âcurlâ is not part of the apt-key script (at least not on Raspbian). Eventually you have created an misdirected alias, too.
And please follow community guidelines when posting from now on.
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
Same problem here with a rpi4, raspbian (buster): stable release is not signed.
Tried removing all files under/var/lib/apt/lists, but did not workâŠ
Anybody having the same problem?
Thanks so much.
I might have accidentially destroyed the signature last night⊠Will see to get it working asap again, sorry!
The repo should be working now!
Doesnât work for me.
Just tried on Debian 9.9 for the stable release with the bintray server.
Hi @matzR
Could you send a copy of the error youâre getting? Iâve just checked and the repo is working for me.
Hei Guys,
can somebody tell me where i can find the Home UUID for the camera thing in the Paper UI
Please open a new thread. In that thread, please include:
- version of OH you are running
- what binding you are talking about (IP Camera binding?)
- what you have done thus far to solve the problem.
This question is not related in any way to this thread.
Kai, itâs working fine now, thanks a lot!
Sorry, I have been out for a while, could not have tried earlier.
Cheers!
E: The repository âhttp://dl.bintray.com/openhab/apt-repo stable Releaseâ is no longer signed.
N: Updating from such a repository canât be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Tried:
wget -qO - âService End for Bintray, JCenter, GoCenter, and ChartCenter | JFrogâ | sudo apt-key add -
But same result.
Can I ask which instructions youâre following?
The sources file (e.g. /etc/apt/sources.list.d/openhab2.list
) should contain:
deb https://dl.bintray.com/openhab/apt-repo2 stable main
Your file currently misses the âsâ in âhttpsâ and the â2â in âapt-repo2â so is currenly pointing to an old repo.
Thanks!
My openhab2.list file was correct, but I had still the openhab.list file there as well.
Removed this now and the update worked.
Thanks a lost for your help!
Thanks to a clue from @matzR I figured out my problem. The openhab2 repo is signed but not the openhab (1.8) repository. Is this intentional?
I know youâre encouraging people to move to openhab2 but until thereâs an insteon binding for openhab2 Iâm stuck (but very happy with) with openhab 1.8. I want to upgrade my server to buster but Iâm not keen to use the [trusted=yes] workaround.
Cheers from a long-time happy openhab user,
Chris
