APT Repo Public Key Expiration & Update
Also !
+1
same issue
The repo moved. The APT/RPM 'testing' (Milestone) repository has moved
okay, but how do we fix that? can we still stay on release (stable) version or do we have to testing version?
I was able to install by disabling signature check in the file /etc/apt/source.list.d/openhab2.list with deb [trusted=yes] https://dl.bintray.com/openhab/apt-repo2 stable main.
The option [trusted=yes] disable the check of the signature and has to be removed as soon as the signing problem is fixed.
Thanks for this advice!
The note of jclugeon helping me for the moment! THX
I’m working on Raspberry 4, both getting new key and disabling signature check didn’t work. I’m on stable release.
Any ideas?
That worked for me with:
`deb [trusted=yes] https://dl.bintray.com/openhab/apt-repo2 stable main’
Thank you!
you can get the stable version from jfrogio also
echo ā€˜deb JFrog stable main’ | sudo tee /etc/apt/sources.list.d/openhab2.list
sudo apt update
should be the correct way, as swamiller said (APT Repo Public Key Expiration & Update - #23 by swamiller), the repo has moved
you really shouldn’t use [trusted=yes]
That worked for me!
indeed the first-boot.bash worked after applying that command.
just for info: today i wanted to make a fresh install, because yesterday i changed many things to make the installation work. i wanted to apply the command before any setup starts. i found out, that in the meantime the problem got fixed on github: Temporarily move stable repo (#663) Ā· openhab/openhabian@1741bb7 Ā· GitHub
thank you for providing a solution so fast!
I did the key update as suggested (see output from apt-key list)
/etc/apt/trusted.gpg
pub rsa4096 2015-07-25 [SC] [expires: 2023-07-24]
EDB7 D030 4E2F CAF6 29DF 1163 0757 21F6 A224 060A
uid [ unknown] openHAB Bintray Repositories owner@openhab.org
sub rsa4096 2015-07-25 [E] [expires: 2023-07-25]
… and it seems to contain the updated key. But it didn’t work. Neither did
the trusted=yes option for me.
So what’s the supposed solution?
Should I change the repository as suggested?
Introduction | openHAB still points to bintray?
Or should I just wait until the problem is fixed?
Are you still working on the fix?
Thanks!
Now I installed the actual openHABian v1.5 based on Debian Buster supports RPi4 on my Raspberry pi 2 and it’s okay. No more Errors.
Adding [trusted=yes] did not work for me immediately. There seems to be a bug in apt on Ubuntu that does not disable the signature check if the lists had already been downloaded before. Removing the local package lists fixed it:
sudo rm /var/lib/apt/lists/*openhab*
Thanks, that helped on my Debian stretch.
But still this can only be a workaround.
I have tried, but still not working for me.
(Armbian / orangepi-pc)
My system also does not accept the signature of this repo:
W: GPG-Fehler: https://openhab.jfrog.io/openhab/openhab-linuxpkg stable Release: Die folgenden Signaturen waren ungültig: EXPKEYSIG 075721F6A224060A openHAB Bintray Repositories <owner@openhab.org>
W: The repository 'https://openhab.jfrog.io/openhab/openhab-linuxpkg stable Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
How do I get OpenHAB updates working again?
Same issue with the repository not being signed.
sudo apt-get update
Reading package lists... Done
W: The repository 'https://dl.bintray.com/openhab/apt-repo2 stable Release' is not signed.
deb https://openhab.jfrog.io/openhab/openhab-linuxpkg stable main was added to sources and I updated the key.
sudo apt-key list gave me this for the repository key.
uid           [ unknown] openHAB Bintray Repositories <owner@openhab.org>
The documentation for Linux listed the new and old repositories. The old directions didn’t have the jfrog.io repository leading me to believe the directions were updated and both repositories should be in the sources. So I’m not sure if there is still a problem in the repository, it seems like the problem started when the key was renewed.
A post above said the snapshot repository changed, but did the stable release repository change hosts as well?
folks,
I’m also getting an error with this.
RPi-4 running Buster
added the key and now I get this
…which looks right?
and an apt update gives me this;
root@homeauto:~# apt update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Ign:3 http://repos.azulsystems.com/debian stable InRelease
Ign:4 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Hit:5 http://repos.azulsystems.com/debian stable Release
Get:6 https://dl.bintray.com/openhab/apt-repo2 stable Release [6,051 B]
Ign:7 https://dl.bintray.com/openhab/apt-repo2 stable Release.gpg
E: The repository 'https://dl.bintray.com/openhab/apt-repo2 stable Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
I’ve tried the various tips above like deleting the cache etc but it’s still the same; fails.
Is there any difference between Debian Jessie and Buster for this?
I tried this but leads me to:
Hit:1 Index of /webupd8team/java/ubuntu xenial InRelease
Hit:2 Index of /raspbian stretch InRelease
Hit:3 Index of /debian stretch InRelease
Hit:4 Index of linux/debian/ jessie InRelease
Hit:5 InfluxData - Package Repository jessie InRelease
Ign:6 JFrog 54 InRelease
Err:7 JFrog 54 Release
404 Not Found
Reading package lists… Done
E: The repository ā€˜JFrog 54 Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
Any ideas how to go on?
I think I’ll try [trusted=yes] for the moment
BR
Markus
