Hello! When you start OpenHAB2 openhab.log the following lines:
2017-02-27 16:14:34.693 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-daily-sun at midnight for thing astro:sun:home
2017-02-27 16:14:34.758 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-positional with interval of 60 seconds for thing astro:sun:home
2017-02-27 16:14:34.790 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-daily-sun at midnight for thing astro:sun:home
2017-02-27 16:14:34.804 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-positional with interval of 60 seconds for thing astro:sun:home
2017-02-27 16:14:35.669 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:home.job-event-start-set#event', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:home.job-event-start-set#event', because one already exists with this identification.
at org.quartz.simpl.RAMJobStore.storeJob(RAMJobStore.java:279)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201702100936]
at org.quartz.simpl.RAMJobStore.storeJobAndTrigger(RAMJobStore.java:251)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201702100936]
at org.quartz.core.QuartzScheduler.scheduleJob(QuartzScheduler.java:886)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201702100936]
at org.quartz.impl.StdScheduler.scheduleJob(StdScheduler.java:249)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201702100936]
at org.openhab.binding.astro.internal.job.AbstractDailyJob.schedule(AbstractDailyJob.java:103)[206:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractDailyJob.scheduleEvent(AbstractDailyJob.java:70)[206:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractDailyJob.scheduleRange(AbstractDailyJob.java:58)[206:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.DailyJobSun.schedulePlanetEvents(DailyJobSun.java:33)[206:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractDailyJob.executeJob(AbstractDailyJob.java:47)[206:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractBaseJob.execute(AbstractBaseJob.java:40)[206:org.openhab.binding.astro:2.1.0.201702121957]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201702100936]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)[104:org.eclipse.smarthome.core.scheduler:0.9.0.201702100936]
2017-02-27 16:14:35.853 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:home.job-event-end-set#event', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:home.job-event-end-set#event', because one already exists with this identification.
at org.openhab.binding.astro.internal.job.AbstractDailyJob.scheduleRange(AbstractDailyJob.java:59)[206:org.openhab.binding.astro:2.1.0.201702121957]
2017-02-27 16:14:35.886 [INFO ] [.astro.internal.job.AbstractDailyJob] - Scheduled astro event-jobs for thing astro:sun:home
2017-02-27 16:14:35.889 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:home.job-event-start-night#event', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:home.job-event-start-night#event', because one already exists with this identification.
at org.openhab.binding.astro.internal.job.DailyJobSun.schedulePlanetEvents(DailyJobSun.java:35)[206:org.openhab.binding.astro:2.1.0.201702121957]
2017-02-27 16:14:36.094 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:home.job-sunPhase-civil_dusk', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:home.job-sunPhase-civil_dusk', because one already exists with this identification.
at org.openhab.binding.astro.internal.job.AbstractDailyJob.scheduleSunPhase(AbstractDailyJob.java:87)[206:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.DailyJobSun.schedulePlanetEvents(DailyJobSun.java:66)[206:org.openhab.binding.astro:2.1.0.201702121957]
2017-02-27 16:14:36.113 [INFO ] [.astro.internal.job.AbstractDailyJob] - Scheduled astro event-jobs for thing astro:sun:home
It is not every time you boot, sometimes unknown error. What is it? Am I doing something wrong? I have 3 OpenHAB2 server and all such trouble.
check if you have the same manual AND via PaperUI configured location …
Edit: if you have “Simple Mode” switched to ON, all items will be created automatically, so that could also be a problem if you have text file configuration.
Hello!
I’m all set up through the files. Simple mode is turned off. In paperUI elements are automatically added, I guess from the file.
My stuff I quoted above, except astro.cfg
It seems like the time he and excess? I’ll try to remove it.
Errors everything about the event, but I do not have events.
Thank you!
2017-03-01 15:37:21.005 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-daily-sun at midnight for thing astro:sun:myhome
2017-03-01 15:37:21.031 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-positional with interval of 60 seconds for thing astro:sun:myhome
2017-03-01 15:37:21.038 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-daily-sun at midnight for thing astro:sun:myhome
2017-03-01 15:37:21.042 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-positional with interval of 60 seconds for thing astro:sun:myhome
2017-03-01 15:37:21.297 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:myhome.job-event-start-set#event', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:myhome.job-event-start-set#event', because one already exists with this identification.
at org.openhab.binding.astro.internal.job.AbstractDailyJob.schedule(AbstractDailyJob.java:103)[222:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractDailyJob.scheduleEvent(AbstractDailyJob.java:70)[222:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractDailyJob.scheduleRange(AbstractDailyJob.java:58)[222:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.DailyJobSun.schedulePlanetEvents(DailyJobSun.java:33)[222:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractDailyJob.executeJob(AbstractDailyJob.java:47)[222:org.openhab.binding.astro:2.1.0.201702121957]
at org.openhab.binding.astro.internal.job.AbstractBaseJob.execute(AbstractBaseJob.java:40)[222:org.openhab.binding.astro:2.1.0.201702121957]
2017-03-01 15:37:21.405 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:myhome.job-event-end-set#event', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:myhome.job-event-end-set#event', because one already exists with this identification.
at org.openhab.binding.astro.internal.job.AbstractDailyJob.scheduleRange(AbstractDailyJob.java:59)[222:org.openhab.binding.astro:2.1.0.201702121957]
2017-03-01 15:37:21.442 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:myhome.job-event-start-night#event', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:myhome.job-event-start-night#event', because one already exists with this identification.
2017-03-01 15:37:21.478 [INFO ] [.astro.internal.job.AbstractDailyJob] - Scheduled astro event-jobs for thing astro:sun:myhome
2017-03-01 15:37:21.494 [ERROR] [.astro.internal.job.AbstractDailyJob] - Unable to store Job : 'astro:sun:myhome.job-event-start-civilDusk#event', because one already exists with this identification.
org.quartz.ObjectAlreadyExistsException: Unable to store Job : 'astro:sun:myhome.job-event-start-civilDusk#event', because one already exists with this identification.
2017-03-01 15:37:21.537 [INFO ] [.astro.internal.job.AbstractDailyJob] - Scheduled astro event-jobs for thing astro:sun:myhome
2017-03-01 15:40:08.353 [WARN ] [stro.discovery.AstroDiscoveryService] - Can't get latitude and longitude for the current location: {}
java.io.IOException: java.util.concurrent.TimeoutException
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:236)
The first and second line repeated in the third and fourth line …
In paperUI there is nothing superfluous.
It is not every time you restart openhab2. It happens that there are no errors.
