Hi guys!
Another example ![]()
This solution is not final or complete but can help new members to start with OpenHAB (at least that’s my objective
). It is based on all feedback and solutions shared by members of the community to my questions in this forum.
Automation #5: Window Opened Alert
Notify me when a window has been open for more than an hour
In this example, I will use the Expire Binding to fire a notification after an hour.
Items
Contact Bathroom_Window (gWindows) { channel="mqtt:topic:MyBroker:Home:Contact3" }
Switch Bathroom_Window_Timer (gWindowTimers) { expire="1h,command=OFF" }
Contact Bedroom_Window_A (gWindows) { channel="mqtt:topic:MyBroker:Home:Contact4" }
Contact Bedroom_Window_B (gWindows) { channel="mqtt:topic:MyBroker:Home:Contact5" }
Switch Bedroom_Window_A_Timer (gWindowTimers) { expire="1h,command=OFF" }
Switch Bedroom_Window_B_Timer (gWindowTimers) { expire="1h,command=OFF" }
Rules DSL Implementation
rule "(DSL) Window open for more than an hour"
Member of gWindows changed
val sensor = triggeringItem
// Get associated timer based on the item naming pattern
val timer = gWindowTimers.members.findFirst[ t | t.name == sensor.name+"_Timer" ] as SwitchItem
if(sensor.state == OPEN) {
timer.sendCommand(ON)
} else {
if(timer.state == ON ) {
timer.postUpdate(OFF)
rule "Timer expired for a Window Contact Sensor"
Member of gWindowTimers received command OFF
// Send notification
Jython implementation
from core.rules import rule
from core.triggers import when
import core
@rule("(Py) Window open for more than an hour")
@when("Member of gWindows changed")
def window_x_open(event):
timerX = ir.getItem(event.itemName+"_Timer")
if event.itemState == OPEN:
#Set/Reset timer for event.itemName
events.sendCommand(timerX, ON)
else:
if timerX.state == ON:
# cancel timer
events.postUpdate(timerX, OFF)
@rule("(Py) Timer expired for a Window Contact Sensor")
@when("Member of gWindowTimers received command OFF")
def timer_expired(event):
# send notification
Happy coding!
Humberto
Note :
- Suggestions or recommendations to improve the implementation are welcome!
- Do you have more complex automations that shares the same logic of this example? Please share it
Other automation examples
