After upgrading to openHAB 4.1 (from 3.3), I sporadically see this exception:
2023-12-30 15:52:20.628 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.avmfritz.internal.handler.AVMFritzHeatingDeviceHandler@3b5de336': Cannot invoke "org.openhab.binding.avmfritz.internal.dto.HeatingModel.setTsoll(java.math.BigDecimal)" because "heatingModel" is null
java.lang.NullPointerException: Cannot invoke "org.openhab.binding.avmfritz.internal.dto.HeatingModel.setTsoll(java.math.BigDecimal)" because "heatingModel" is null
at org.openhab.binding.avmfritz.internal.handler.AVMFritzBaseThingHandler.handleCommand(AVMFritzBaseThingHandler.java:580) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at jdk.proxy1399.$Proxy1536.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:95) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
After this exception occurred, even the UI is frozen. Only a reboot brings back proper operation. Since heatingModel
seems to be an implementation detail, I expect there to be a bug in the binding. I’m using the latest firmware 7.57 for my AVM Fritz!Box 7590, my openHAB 4.1 is running inside a Docker container.
Does anyone have a suggestion how I can fix this or even find out what is causing this? A search here did not show up that anyone else had this issue, only something related in AVM Fritz Binding things unknown after upgrade OpenHAB 2.5 to 3.4 – but before recreating all the items, I’d prefer to investigate on the issue.
Best regards,
ceedee
