Avoid error messages in logs with jsonpath transformation
I am using OpenHab with Zigbee2MQTT as Bridge to my zigbee devices.
As an example this remote control:
Thing topic tradfriRemote2 "Tradfri Remote 2" {
		Type string : tradfriRemote2	[stateTopic="zigbee2mqtt/remote-tradfri-2", transformationPattern="JSONPATH:$.action" ]
		Type number : battery		[stateTopic="zigbee2mqtt/remote-tradfri-2", transformationPattern="JSONPATH:$.battery" ]
Sometimes these zigbee things (or let it be zigbee2mqtt) don’t send the complete mqtt message, so e.g. sometimes it sends the battery status only, without a “action” part in the mqtt message. This causes error messages in the log everytime:
2024-10-17 12:06:27.025 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.action' in '{"battery":80,"linkquality":21,"update":{"installed_version":604241925,"latest_version":604241925,"state":"idle"}}'. Pattern: '$.action'. Value: '{"battery":80,"linkquality":21,"update":{"installed_version":604241925,"latest_version":604241925,"state":"idle"}}'
It does not harm anything but I generally don’t like error messages in my logfiles :wink: Do you have any idea how I could avoid these parsing issues?
MQTT 2.5 M1+ How to implement the equivalent to MQTT1 REGEX filters.
It’s an old post but this still works this way. TL;DR is to chain a REGEX filter that matches only those messages that you want to pass to the JSONPATH. If the REGEX doesn’t match it doesn’t return anything and the message is dropped.
That’s working perfectly, thank you! (Had to copy paste that “∩” character :smile: )
For managed Things, you can put each transformation on a separate line instead of using the intersection operator.
