I now removed the items from json items file…they do not add anymore after restart…however I still have the following messages…
However there are still lines inside the itemchannellink.json…file. Should i remove these as well, i guess so…
2017-10-12 22:05:47.728 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.NumberItem with key'LivingRoom_Power' already exists! Failed to add a second with the same UID!
2017-10-12 22:05:47.734 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.library.items.SwitchItem with key'LivingRoom_Switch' already exists! Failed to add a second with the same UID!
2017-10-12 22:05:48.389 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2017-10-12 22:05:48.662 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2017-10-12 22:05:48.713 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.thing.link.ItemChannelLink with key'Solar_Power -> zwave:device:6f2c15ba:node8:meter_watts' already exists! Failed to add a second with $
2017-10-12 22:05:48.720 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.thing.link.ItemChannelLink with key'Router_Switch -> zwave:device:6f2c15ba:node16:switch_binary' already exists! Failed to add a second $
2017-10-12 22:05:48.743 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.thing.link.ItemChannelLink with key'WellWater_Power -> zwave:device:6f2c15ba:node10:meter_watts' already exists! Failed to add a second $
2017-10-12 22:05:48.782 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.thing.link.ItemChannelLink with key'Solar_Switch -> zwave:device:6f2c15ba:node8:switch_binary' already exists! Failed to add a second wi$
2017-10-12 22:05:48.797 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.thing.link.ItemChannelLink with key'WellWater_Switch -> zwave:device:6f2c15ba:node10:switch_binary' already exists! Failed to add a seco$
2017-10-12 22:05:48.823 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.thing.link.ItemChannelLink with key'Router_Power -> zwave:device:6f2c15ba:node16:meter_watts' already exists! Failed to add a second wit$
2017-10-12 22:05:50.163 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
