This rule is one part of a bundle designed to allow the creation, configuration, and utilization of Bayesian probability calculations for some item states using the MainUI. The three parts are:
Bayesain Group Modification Rule (this rule)
Credit: This is an OH3-ready implementation of @cweitkamp’s awesome Bayesian aggregation design pattern. So, much of the credit goes to him and you will want to read through his post for a more detailed explanation of the underlying concepts and very clear description and example of probability selection.
This rule is intended for use only with the Bayesian Group Control Widget (see link above). It provides much of the functionality for that widget and will not offer much functionality without it.
Installation and Use
After downloading this rule from the marketplace you only need to create one instance of the rule and there are no required parameters. The rule is usually triggered by an item but that item will be automatically created the first time the rule is run or when the widget is initialized, so there is no need to create the item or input the item name into the rule.
Use without the widget
This rule does have one use indepenent of the widget. If this rule is run manually (press the Run Now
button or ctrl + r from the rules detail page) then it will run a check of the metadata for all Bayesian groups and print any errors or warnings to the log as well as adding those errors and warnings to the metadata for each item as necessary.
Language:
- JSscripting ECMAScript 2021+
Dependencies:
- JSscripting Add-on
Changelog
Version 0.2
- Fixed template formatting issue
Version 0.1
- initial release
