Best hardware platform
Well, of course… if you’re thrashing your SD card it’s simply going to wear out eventually. Same with SSD. It might make more sense to run the old school mechanical platter drive instead if you’re writing a lot. There’s a reason why file servers still use mechanical platters!
In my experience, an inordinate number of corruptions have been associated with brownouts, but as long as the battery backup solution is capable of supplying a steady output voltage regardless of the behavior of the input voltage (active power regulation) things seem well.
Your brownout or blackout statement may be right or not (note I support getting a UPS, too) but you’re still missing the point.
OH by no means can be compared to OpenSprinkler or similar lightweight SD write loads as @rlkoshak showed.
Point is you wrote this in an openHAB forum where a lot of people use Raspis running on SD, and it is highly dangerous to make them believe that all they need is a UPS.
But they also need to take complementary measures to protect them from having their OH servers crash every few months, see this standard post.
Can you post what NUC exactly you have chosen? I am also looking for a somewhat “low energy”-platform, I even thought about using my synology, but it consumes 30 Watt…
Regarding the general discussion, I agree that Openhab does not have to take care about backing up the underlying OS. OpenHAB is an application, and it even has it’s own backup-scripts which do fine as long as the underlying OS has no modifications.
And even with these scripts, it is far ahead of any Windows-Program, which usually has no backup at all. Even Windows itself has no really good backup, if you want good backup for Windows, you have to stick with 3rd-party software.
So perhaps one should think about which HW to use with Openhab when it comes to backup. If it is Raspberry, one have to deal with Linux (which is not a bad thing, by the way), and if one does not want that, he can still opt to Windows.
If I should choos a NUC for home automation, I would go for the NUC7PJYH. It´s powerfull, even thought it´s “just” a J5005 CPU. And it´s very cheap.
@Kim_Andersen any reason why that one in particular?
I am now choosing one nuc as my 10 years old laptop is starting to be unstable, but I was thinking of the cheapest nuc, with 8gb+120gb ssd it is around 200e, the “next better one” is around 300e.
But I do not think openhab needs anything special, I was thinking of running few databases and perhaps network monitoring of of it, but again, I do not see it using more then 5-10% of it potential?
Or am I wrong? Should I buy a bit more expensive/powerful one?
From its specs and the price, the NUC7PJYH is a very powerfull. The J5005 is a rather good and fast CPU.
The next reason is, it hardly use any energy. About 10-14 Watt. Thats very low for such a powerfull computer.
In my opinion, a smart home system should be powerfull and use a very limited amount of energy. Unfortunatly these two options often dont go hand in hand.
The price, here in Denmark, is just about 180 Euro. With 8GB RAM it´s 258 Euro, (I already got a spare SSD). It may seem alot comparing to an Rpi or something simular. But a server like this will handle whatever you need it to regarding openhab use and hardly use any energy. Two things which in my opinion is very important.
As openHAB2 is working almost well on a raspberry3, it’s more a question of the other software, such as “a few databases” :wink:
Think about 2GByte for openHAB2 plus another 2GByte for a MySQL database (should suffice for private usage)
So 8GByte RAM is more than sufficient. As of processors, anything will fit (given that it’s a current 64bit processor) and the main thing is to find a power-saving model, because the computer will run 24/7.
I agree with you @Kim_Andersen , I was just thinking about the one you mentioned vs the cheapest nuc, f.eks NUC6CAYH which starts from 130e locally (without ram and ssd).
That is Intel NUC Celeron J3455 on 1.5 GHz, and as @Udo_Hartmann says, compared to pi which works just fine, I am sure this cheapest nuc will do all it is being asked to. Or would it?
(I will order one cheapest soon, so please let me know if some upgraded version is more suitable :slight_smile: (power consumption is not priority) )
The J3455 CPU NUC should be good enough for openhab. But I have never tried anything like that.
I think I would hate it simply because of its lack of CPU cache and use of DDR3 these days, wether or not I´ll ever going to need it to run openhab. Thats just the way I am :laughing:
That is a good point, especially buying ddr3 in 2019.
However, considering the 100e price difference, I can purchase 4tb storage for my other nas server :slight_smile:
Then the choice goes from “the best” to “good enough” :slight_smile:
Here in Denmark:
The NUC J3455 is priced 146euro
The NUC J5005 is priced 186euro.
Thats 40euro in differences?
Both need RAM and Hardrive.
I wouldnt have any second thoughts about the choise between them. I would spend the 40euro extra and never look back. No matter if I need it or not :slight_smile:
Ofcouse, if you can spend the extra 40euro on something else, which will give you something better, then thats what you should do.
I run openHAB in NUC as well. What I can recommend is to run openHAB on Proxmox VE.
Proxmox VE is open-source server virtualization environment (debian distro + KVM hypervisor + nice web GUI). Basically everything can be done via GUI, so for new users it should be rather easy to use as well.
What is great in Proxmox, is that is also support scheduled snapshot (live) backups out of the box without need to shutdown the VM.
Even Proxmox is very lightweight and most probably run well also on cheapes NUC, I recommend to buy little bit better than just cheapest one.
My NUC7i3BNH is overkill for openHAB only, but I run some other VMs as well. My NUC support both M.2 and 2.5" drives and I have installed proxmox on M.2 SSD and all VMs to other.
There is a guide in this forum how to install Proxmox VE and openHAB
https://community.openhab.org/t/from-newbie-to-newbie/33431
I have never used any kinds of WM´s before… I just buy more computers and use it for single stuff. Expensive, yes, but it makes it abit more easier for me to comprehend :slight_smile:
Virtualisation is a really nice and cheap technique to improve usage and workload of hardware.
Proxmox is free of charge if you don’t want support. :wink: if the system is growing, it’s possible to build a datacenter by using 3 or more real computers. A datacenter is able to run virtual machines (without real hardware) on every node, failover is built in :slight_smile:
Indeed a big adventure park, but openHAB is just one fraction of services to run at such a datacenter…
I was actually planing to run single VM on it (as discussed deeper in my other post here Intel NUC vs Laptop for (single) VM running OpenHab and other automation related services)
That way I can easily backup entire system, because I am quite clumsy. Although I love Ansible deployment as Rich suggested on that other post. I use it on my workstation on virtual machines to test things out.
@Kim_Andersen not sure why in norway price difference is 80e between the two (ram is almost the same, few euros there as well). I will sleep on it :slight_smile:
P.S. you should try Virtualisation if you never did, just spin some vagrant machine on your desktop and see how you like it, ability to take snapshots and rebuilt machine in 60s when testing is priceless for me (probably because I do not know what I am doing with linux, so most of the time I am just guessing)
Real benefit comes from easy backups. If you screw accidentally your openHAB env or after update you meet any problems, it takes couple of minutes and your environment is up and running again.
true one can use dockers to backup services, but you can use both, docker for per-service backup, and also vm for entire system backup (which I think is important for openhab and home automation in general, as it is quite complex system with a lot of thing happening)
Many (many!!) years ago I tried something… I think it was one of the first versions of WMware… I dumped it cause it was too difficult to get access to peperials, USB´s, drives etc…
But I like the idea to run several indepent systems on one hardware devices. I just hate struggling to get even simple things to work… (hmm, I probably never should have startet on openhab then :slight_smile: .
I suspect it is much easier now. I run on ESXi and have had no problem mounting USB devices inside my VMs. That was the easiest part to work with in my setup.
Probably… I just havn´t had the patience to try again. Found it easier to just buy yet another computer :wink:
