I’ve build a nice working configuration with both Philips Hue bulbs and Legrand MyHome Play switches (using OpenWebNet Binding beta5 and Legrand USB/Zigbee stick 088328).
I plan to purchase wall outlets and switches from the new ‘Legrand Celiane with Netatmo’ product range. This product range is incompatible with former Legrand MyHome Play product range (that may become obsolete). The new ‘Legrand Celiane with Netatmo’ uses a modern REST API co-developed with Netatmo.
Is somebody working on a binding ?
@Massimo: I don’t know if equivalent switches and outlets are already available at Bticino.
This products range works with zigbee 3.0
I do not know if a usb zigbee 3.0 key will be sold.
myhome play and xxx with netatmo should be compatible soon
Hello to everyone. i’m new in this forum but i’m practicing in openhab from few months.
I’m interested to buy the new connected components from Biticino/Legrand.
I’m interested to use the gateway:
associated to the following controllers for roller shutters
Are this components supported by the “Biticino Add On”?
Anyone have tried this configuration?
Thanks a lot
No, since these two Living Now components are quite new, and use a completely different integration protocol, they are not currently supported by the BTicino Add On or binding.
M
As a workaround you can connect the LivingNow set-up with Alexa and then use the Alexa Binding to import your things/items in OH 3.
This is working for me and it is quite quick and reliable.
The only disadvantage is that you need to rely on two bridges : LEGRAND and Alexa Skill.
