Bindings (NTP, Spotify, Alexa, Exec) stop to work / "hang" randomly
Hi all,
i run currently 3.4.2 on my RPi4. I suffered a long time from the UI freezes caused by heap, but that was finally solved by @florian-h05 with a fix in 3.4.1 https://github.com/openhab/openhab-addons/pull/13824
Unfortunetally as written in my last post above the issues on the NTP binding still happen and became worse.
Openhab runs w/o freeze since 20 days. I just experienced temporary “freezes” of NTP binding, but most likely that is a different topic maybe coming from 3.4.1.
I am getting aware the issue, because I have a current datetime item updated via the NTP binding. That item is displayed on my MainUI page. Randomly i notice that this item is not updated anymore. Then different other issues happen:
  • Spotify, amazonechocontrol, NTP binding stops working, things shows error status
  • actions triggered by javascript rules are not being executed, e.g. a rule triggers a shell command. the rule is triggered but the exec binding action is not executed
What usually helps is to restart the Spotify binding via console. Then also the datetime item is being updated properly and also the others bindings start working again. But sometimes also that does not help, so then i need to restart openhab.
It is a quite strange situation so I would be very thankful on hints on how to further proceed and narrow down the potential root causes.
Many thanks in advance.
Below my systeminfo:
Karaf
  Karaf version               4.3.7
  Karaf home                  /usr/share/openhab/runtime
  Karaf base                  /var/lib/openhab
  OSGi Framework              org.eclipse.osgi-3.17.200.v20220215-2237
JVM
  Java Virtual Machine        OpenJDK Client VM version 11.0.15+10-LTS
  Version                     11.0.15
  Vendor                      Azul Systems, Inc.
  Pid                         12958
  Uptime                      1 day 2 hours
  Process CPU time            3 hours 17 minutes
  Process CPU load            0.00
  System CPU load             0.00
  Open file descriptors       327
  Max file descriptors        102,642
  Total compile time          26.293 seconds
Threads
  Live threads                286
  Daemon threads              140
  Peak                        339
  Total started               103893
Memory
  Current heap size           393,294 kbytes
  Maximum heap size           1,496,704 kbytes
  Committed heap size         678,092 kbytes
  Pending objects             0
  Garbage collector           Name = 'Copy', Collections = 1799, Time = 51.987 seconds
  Garbage collector           Name = 'MarkSweepCompact', Collections = 7, Time = 4.853 seconds
Classes
  Current classes loaded      27,238
  Total classes loaded        28,965
  Total classes unloaded      1,727
Operating system
  Name                        Linux version 5.15.84-v7l+
  Architecture                arm
  Processors                  4
The only things I see in the logs dont seem to be related.
2023-03-27 17:27:14.892 [ERROR] [ommunicator.AbstractHomematicGateway] - java.util.concurrent.ExecutionException: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
2023-03-27 17:49:10.896 [WARN ] [ternal.handler.HomematicThingHandler] - Channel not found for datapoint '000E5709B28D4B:1#QUICK_VETO_TIME'
2023-03-27 17:57:24.245 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
Finding the cause of a memory leak (seems like you experience one, however could you please provide me your full openhab.log from when UI freezes? Just remove some personal information like location …) is difficult without doing a heap dump and analysing it, but we can try to figure out what might be the cause.
Regarding JS Scripting, I am pretty sure that there is no memory leak left after doing several heap analyses.
Given that a restart of the Spotify binding sometimes solves this problem, I would uninstall the Spotify binding and check if the issue persists. If not, we can be pretty sure that it is the Spotify binding.
The first line indeed is something I have noticed always when my openHAB went out of memory, even though it doesn‘t seem related on the first sight.
Hi @florian-h05 ,
many thanks for your swift reply.
I will definitely try deactivitating the spotify binding.
I’ll send you the logs per private message.
Regards
When it seems there are no updates anymore and other bindings are also blocked. They use a shared limited thread pool. In general it means the binding thread pool is blocked, possibly on a deadlock. To get the thread info you can issue the following command on the Console :
threads --monitors --locks
This will give a list of threads and hopefully gives an insight in what threads are blocked.
You could also try to increase the number of threads available in the threadpool because the current configuration is too limited due to some bindings taking to much time, blocking other bindings. You can change these settings in the configuration file runtime.cfg which can be found in the $OPENHAB_CONF/services directory, e.g. /etc/openhab/services/runtime.cfg
many thanks @hilbrand for that hint. I just ran the command and the result is quite extensive. openhab runs since approx 1,5 days. So I will run that command as soon as the issue occurs and then repost it. Could not paste the whole log here because too big, maybe there anything you can already see in the dump below?
"sshd-SshServer[341485](port=8101)-nio2-thread-1" Id=96675 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@978423
    at java.base@11.0.15/jdk.internal.misc.Unsafe.park(Native Method)
    at java.base@11.0.15/java.util.concurrent.locks.LockSupport.park(LockSupport.java:194)
    at java.base@11.0.15/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2081)
    at java.base@11.0.15/java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:433)
    at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1054)
    at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1114)
    at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
    at java.base@11.0.15/java.lang.Thread.run(Thread.java:829)
"sshd-SshServer[341485](port=8101)-nio2-thread-2" Id=96676 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@978423
"HttpClient@7cca4b-96761" Id=96761 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@14e5510
    at java.base@11.0.15/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:234)
    at java.base@11.0.15/java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(SynchronousQueue.java:462)
    at java.base@11.0.15/java.util.concurrent.SynchronousQueue$TransferStack.transfer(SynchronousQueue.java:361)
    at java.base@11.0.15/java.util.concurrent.SynchronousQueue.poll(SynchronousQueue.java:937)
    at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.reservedWait(ReservedThreadExecutor.java:324)
    at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:399)
    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
    at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
"OH-httpClient-common-112631" Id=112631 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@102f103
"OH-httpClient-common-121537" Id=121537 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15888cc
    at java.base@11.0.15/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2123)
    at org.eclipse.jetty.util.BlockingArrayQueue.poll(BlockingArrayQueue.java:382)
    at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.idleJobPoll(QueuedThreadPool.java:974)
    at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1018)
"OH-httpClient-common-128469" Id=128469 in RUNNABLE (running in native)
    at java.base@11.0.15/sun.nio.ch.EPoll.wait(Native Method)
    at java.base@11.0.15/sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:120)
    at java.base@11.0.15/sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:124)
      - locked sun.nio.ch.Util$2@222556
      - locked sun.nio.ch.EPollSelectorImpl@7e9643
    at java.base@11.0.15/sun.nio.ch.SelectorImpl.select(SelectorImpl.java:141)
    at org.eclipse.jetty.io.ManagedSelector.nioSelect(ManagedSelector.java:183)
    at org.eclipse.jetty.io.ManagedSelector.select(ManagedSelector.java:190)
    at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.select(ManagedSelector.java:606)
    at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:543)
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produceTask(EatWhatYouKill.java:362)
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:186)
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
    at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
    Locked monitors: count = 2
      - sun.nio.ch.Util$2@222556 locked at
          2 java.base@11.0.15/sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:124)
      - sun.nio.ch.EPollSelectorImpl@7e9643 locked at
"OH-httpClient-common-132227" Id=132227 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15888cc
"OH-httpClient-common-132726" Id=132726 in RUNNABLE (running in native)
      - locked sun.nio.ch.Util$2@1b5755
      - locked sun.nio.ch.EPollSelectorImpl@eea575
      - sun.nio.ch.Util$2@1b5755 locked at
      - sun.nio.ch.EPollSelectorImpl@eea575 locked at
"OH-httpClient-common-133150" Id=133150 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15888cc
"qtp8526513-142139" Id=142139 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@b61859
"HttpClient@7cca4b-154387" Id=154387 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@14e5510
"OH-httpClient-common-155674" Id=155674 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@102f103
"qtp16251738-197153" Id=197153 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@11992b9
"qtp8526513-197456" Id=197456 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@b61859
"qtp16251738-199277" Id=199277 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@11992b9
"qtp8526513-199457" Id=199457 in RUNNABLE (running in native)
      - locked sun.nio.ch.Util$2@fa5942
      - locked sun.nio.ch.EPollSelectorImpl@14a2cac
      - sun.nio.ch.Util$2@fa5942 locked at
      - sun.nio.ch.EPollSelectorImpl@14a2cac locked at
"Thread-21421" Id=199680 in RUNNABLE
    at java.base@11.0.15/java.io.FileInputStream.readBytes(Native Method)
    at java.base@11.0.15/java.io.FileInputStream.read(FileInputStream.java:279)
    at java.base@11.0.15/java.io.BufferedInputStream.read1(BufferedInputStream.java:290)
    at java.base@11.0.15/java.io.BufferedInputStream.read(BufferedInputStream.java:351)
      - locked java.lang.ProcessImpl$ProcessPipeInputStream@b3fe66
    at java.base@11.0.15/sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:284)
    at java.base@11.0.15/sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326)
    at java.base@11.0.15/sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)
      - locked java.io.InputStreamReader@695079
    at java.base@11.0.15/java.io.InputStreamReader.read(InputStreamReader.java:181)
    at java.base@11.0.15/java.io.BufferedReader.fill(BufferedReader.java:161)
    at java.base@11.0.15/java.io.BufferedReader.readLine(BufferedReader.java:326)
    at java.base@11.0.15/java.io.BufferedReader.readLine(BufferedReader.java:392)
    at org.openhab.binding.ipcamera.internal.Ffmpeg$IpCameraFfmpegThread.run(Ffmpeg.java:133)
    Locked monitors: count = 3
      - java.lang.ProcessImpl$ProcessPipeInputStream@b3fe66 locked at
          3 java.base@11.0.15/java.io.BufferedInputStream.read(BufferedInputStream.java:351)
      - java.io.InputStreamReader@695079 locked at
          6 java.base@11.0.15/sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)
          9 java.base@11.0.15/java.io.BufferedReader.readLine(BufferedReader.java:326)
"qtp8526513-201432" Id=201432 in RUNNABLE (running in native)
      - locked sun.nio.ch.Util$2@15363f
      - locked sun.nio.ch.EPollSelectorImpl@4a431d
      - sun.nio.ch.Util$2@15363f locked at
      - sun.nio.ch.EPollSelectorImpl@4a431d locked at
"OH-items-2349" Id=201722 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@1c1d57c
    at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1053)
"qtp8526513-201956" Id=201956 in RUNNABLE (running in native)
      - locked sun.nio.ch.Util$2@19ba625
      - locked sun.nio.ch.EPollSelectorImpl@20db67
      - sun.nio.ch.Util$2@19ba625 locked at
      - sun.nio.ch.EPollSelectorImpl@20db67 locked at
"OH-items-2353" Id=202065 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@1c1d57c
"OH-safeCall-284" Id=202564 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@e63695
"qtp8526513-202664" Id=202664 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@45a958
"qtp16251738-203113" Id=203113 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1454d1a
"qtp16251738-203116" Id=203116 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1454d1a
"qtp16251738-203118" Id=203118 in RUNNABLE (running in native)
      - locked sun.nio.ch.Util$2@11a5f36
      - locked sun.nio.ch.EPollSelectorImpl@4f8d1e
      - sun.nio.ch.Util$2@11a5f36 locked at
      - sun.nio.ch.EPollSelectorImpl@4f8d1e locked at
"qtp16251738-203117" Id=203117 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1454d1a
"qtp16251738-203119" Id=203119 in RUNNABLE (running in native)
      - locked sun.nio.ch.Util$2@f60bb8
      - locked sun.nio.ch.EPollSelectorImpl@1a4ac21
      - sun.nio.ch.Util$2@f60bb8 locked at
      - sun.nio.ch.EPollSelectorImpl@1a4ac21 locked at
"OH-homematicGateway-6660" Id=203238 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@64b80c
    at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.poll(ScheduledThreadPoolExecutor.java:1223)
    at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.poll(ScheduledThreadPoolExecutor.java:899)
"OH-homematicGateway-6665" Id=203464 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@64b80c
    at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.poll(ScheduledThreadPoolExecutor.java:1218)
"OH-items-2367" Id=203501 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@1c1d57c
"qtp8526513-203792" Id=203792 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@b61859
"OH-items-2373" Id=203812 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@1c1d57c
"OH-discovery-2786" Id=204025 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c9fee3
"OH-items-2379" Id=204184 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@1c1d57c
"OH-common-6794" Id=204210 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@6a9349
"OH-discovery-2788" Id=204223 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c9fee3
"qtp8526513-204228" Id=204228 in RUNNABLE (running in native)
      - locked sun.nio.ch.Util$2@c88617
      - locked sun.nio.ch.EPollSelectorImpl@1c16bea
      - sun.nio.ch.Util$2@c88617 locked at
      - sun.nio.ch.EPollSelectorImpl@1c16bea locked at
"OH-scheduler-3232" Id=204247 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@4dfe01
"OH-common-6795" Id=204256 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@6a9349
"HttpClient@7cca4b-204305" Id=204305 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@420a0e
"OH-discovery-2789" Id=204354 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c9fee3
"OH-discovery-2790" Id=204482 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c9fee3
"OH-common-6801" Id=204497 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@6a9349
"OH-homematicGateway-6701" Id=204516 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@64b80c
"org.apache.karaf.shell.ssh.SshTerminal@1c2d20b input pump thread" Id=204528 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@f565e8
    at org.apache.sshd.common.channel.ChannelPipedInputStream.read(ChannelPipedInputStream.java:144)
    at java.base@11.0.15/java.io.InputStream.read(InputStream.java:205)
    at org.jline.terminal.impl.ExternalTerminal.pump(ExternalTerminal.java:141)
    at org.jline.terminal.impl.ExternalTerminal$$Lambda$1921/0x452e6828.run(Unknown Source)
"Karaf ssh console user openhab" Id=204529 in WAITING on lock=org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl@1945390
    at java.base@11.0.15/java.lang.Object.wait(Native Method)
    at java.base@11.0.15/java.lang.Object.wait(Object.java:328)
    at org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl.start(CommandSessionImpl.java:802)
    at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:300)
    at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:169)
    at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:149)
    at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:179)
    at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.doExecute(ConsoleSessionImpl.java:467)
    at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.run(ConsoleSessionImpl.java:407)
"pipe-threads --monitors --locks" Id=204530 in RUNNABLE
    at java.management@11.0.15/sun.management.ThreadImpl.dumpThreads0(Native Method)
    at java.management@11.0.15/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:521)
    at java.management@11.0.15/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:509)
    at org.apache.karaf.shell.commands.impl.ThreadsAction.execute(ThreadsAction.java:78)
    at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84)
    at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68)
    at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86)
    at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599)
    at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526)
    at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415)
    at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416)
    at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229)
    at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59)
    at java.base@11.0.15/java.util.concurrent.FutureTask.run(FutureTask.java:264)
    at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
    Locked synchronizers: count = 1
      - java.util.concurrent.ThreadPoolExecutor$Worker@d088fd
openhab>
another thing I noticed last time that happened:
A rule with a cron trigger did not fire at the desired time. So I am wondering how this can happen, because the dateTime item not properly updated by NTP binding in my understanding is not connected to the cron triggers at all. So is that an indication, that not the NTP binding is an issue, but rather “openhab internal” issue?
Another strange thing is that some dateTime items which are set in Javascript rules using NOW are showing the correct time…
Now the issue happened again.
I ran the command again, but after I first scan I dont see anything major different to the first dump did.
I attached the log, maybe @hilbrand you can see something special.
oh.log (173.7 KB)
Now I rebooted the complete system. If the error happens again my next step will be to deactivate the Spotify binding as suggested by @florian-h05
I am running now since 21 days after reboot. I only had once the NTP issue, restarted the Spotify binding and since then everything is fine
So I will observe longer …
