since I started usage of JavaScript rules addons, I experience the issue, that the main ui simply does not load after 2 to 4 days. The website just stays blank. The issue is reproducable. Openhab continues to run. I see in the events.log that items are being updated and I can also log into the console. So to me it seems it is Main UI related.
186 x Active x 80 x 3.2.0 x openHAB Core :: Bundles :: UI REST Interface
216 x Active x 80 x 3.2.0 x openHAB Core :: Bundles :: UI
217 x Active x 80 x 3.2.0 x openHAB Core :: Bundles :: UI Icon Support
219 x Active x 80 x 3.2.0 x openHAB UI :: Bundles :: Main UI
274 x Active x 80 x 3.2.0 x openHAB UI :: Bundles :: Basic UI
275 x Active x 80 x 3.2.0 x openHAB UI :: Bundles :: Icon Set :: Classic
Restart Openhab Service: Then it everything works for a couple of days.
Logs
In the logs I see the follwing WARN messages:
2022-02-01 07:16:38.523 [WARN ] [ternal.handler.HomematicThingHandler] - Channel not found for datapoint '000E5709B28DC3:1#QUICK_VETO_TIME'
2022-02-01 07:25:50.922 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
2022-02-01 08:09:29.882 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
2022-02-01 08:18:34.985 [WARN ] [ternal.handler.HomematicThingHandler] - Channel not found for datapoint '000E5709B28D4B:1#QUICK_VETO_TIME'
Check the heap size of your Java VM and check logs for heap memory errors. I have a lot of things and items and I had to increase the heap size in /etc/default/openhab.
thanks for your reply @stefaanbolle . I checked and I dont have heap errors in the log. I had only once when I somehow messed with a javascript rule and the system crashed. But that was only one entry in all logs.
2022-02-01 18:14:35.473 [WARN ] [org.eclipse.jetty.io.ManagedSelector] - java.lang.OutOfMemoryError: Java heap space
Today I updated to 3.3.M1 so I’ll observe if that brings any improvement.
so I also increased the heap size and upgraded to 3.3.0.M1, but after approx. Main UI stays again blank. Any ideas where to further investigate?
Karaf
Karaf version 4.3.6
Karaf home /usr/share/openhab/runtime
Karaf base /var/lib/openhab
OSGi Framework org.eclipse.osgi-3.16.300.v20210525-1715
JVM
Java Virtual Machine OpenJDK Client VM version 11.0.12+7-LTS
Version 11.0.12
Vendor Azul Systems, Inc.
Pid 11627
Uptime 1 day 22 hours
Process CPU time 4 hours 20 minutes
Process CPU load 0.03
System CPU load 0.04
Open file descriptors 381
Max file descriptors 102,642
Total compile time 25.480 seconds
Threads
Live threads 286
Daemon threads 132
Peak 291
Total started 168704
Memory
Current heap size 249,938 kbytes
Maximum heap size 989,888 kbytes
Committed heap size 495,424 kbytes
Pending objects 0
Garbage collector Name = 'Copy', Collections = 2095, Time = 1 minute
Garbage collector Name = 'MarkSweepCompact', Collections = 5, Time = 1.793 seconds
Classes
Current classes loaded 29,096
Total classes loaded 29,184
Total classes unloaded 88
Operating system
Name Linux version 5.10.63-v7l+
Architecture arm
Processors 4
I guess you have the same SSE problem like a few others here.
See the ticket with all infos here .
I am currently testing if https connection solves the problem.
Do you have a secured or unsecured connection when UI freezes?
Thanks @Oliver2. Indeed it seems this is related to the SSE problem. Now I realize the issue started to appear when I started to use conditional formatting for oh-label-widgets as below. I use http, since I have not checked how to setup https.
Is there any way to restart a specific bundle, to get thue UI loading again? So far the only way for me is to restart openhab service.
I doubt that restarting openhab service will solve the problem. You better refresh the browser.
https is available out of the box. You just need to change the URL in the browser
https://openhab:8443/
You also need to import the certificate into your browser or operating system of the client to avoid error messages
Thanks for the hint, I will check if https works when http freezes the next time.
I was misleading. Restarting of course is not solving, but at least a workaround to access the MainUI. For me the webpage stays completely blank. I can not access it at all.
misunderstanding. I thought you have a general problem with blank pages.
My suggestion to cleaning cache makes no sense as you have to stop and restart openhab service anyway
@Oliver2. it seems using https only solved the problem for me. Main UI now stable since 3 days. Many thanks. But I assume the underlying issue still needs to fixed, right?
Karaf
Karaf version 4.3.6
JVM
Version 11.0.12
Pid 31005
Uptime 3 days
Process CPU time 6 hours 50 minutes
Process CPU load 0.02
System CPU load 0.05
Open file descriptors 335
Total compile time 29.164 seconds
Threads
Live threads 300
Daemon threads 133
Peak 304
Total started 249233
Memory
Current heap size 238,690 kbytes
Pending objects 0
Garbage collector Name = 'Copy', Collections = 3274, Time = 1 minute
Garbage collector Name = 'MarkSweepCompact', Collections = 5, Time = 1.822 seconds
Classes
Current classes loaded 29,447
Total classes loaded 29,656
Total classes unloaded 209
Operating system
Architecture arm
Processors 4
there were changes to the model. people have reported blank pages and the reason for this is circular referencing of model tags.
If you have an item which belongs to a group and that is referenced to a location and the item is also referenced to the location then you have this kind of problem which leads to blank pages as MainUI is busy.
try to find that kind of referencing
