Hi, I’m using the Bitron Video ZigBee USB Funkstick and I’m able to make it work and pair several devices that I have but after a while it stops working and no updates are received nor commands sent. It is usually fixed by just unplugging and plugging the dongle, then it works for a while.
In the events.log I see that it works till 4:43, then no more updates:
2019-08-05 04:41:45.394 [vent.ItemStateChangedEvent] - zigbee_device_01382722_286d97000105ca1f_286D97000105CA1F_1_temperature changed from 26.56 °C to 26.57 °C
2019-08-05 04:41:47.067 [vent.ItemStateChangedEvent] - zigbee_device_01382722_286d97000106cc54_286D97000106CC54_1_temperature changed from 26.59 °C to 26.60 °C
2019-08-05 04:42:01.298 [vent.ItemStateChangedEvent] - zigbee_coordinator_ember_01382722_rx_dat changed from 13958 to 13981
2019-08-05 04:42:02.923 [vent.ItemStateChangedEvent] - zigbee_coordinator_ember_01382722_tx_ack changed from 13958 to 13981
2019-08-05 04:42:12.738 [vent.ItemStateChangedEvent] - zigbee_device_01382722_286d970001032626_286D970001032626_1_temperature changed from 22.26 °C to 22.90 °C
2019-08-05 04:42:31.293 [vent.ItemStateChangedEvent] - zigbee_coordinator_ember_01382722_rx_dat changed from 13981 to 14004
2019-08-05 04:42:31.312 [vent.ItemStateChangedEvent] - zigbee_coordinator_ember_01382722_tx_ack changed from 13981 to 14004
2019-08-05 04:43:01.312 [vent.ItemStateChangedEvent] - zigbee_coordinator_ember_01382722_rx_dat changed from 14004 to 14024
2019-08-05 04:43:01.364 [vent.ItemStateChangedEvent] - zigbee_coordinator_ember_01382722_tx_ack changed from 14004 to 14024
In the openhab log I see that from 4:42 it keeps polling without any result:
2019-08-05 04:42:12.717 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001032626: Updating ZigBee channel state zigbee:device:01382722:286d970001032626:286D970001032626_1_temperature to 22.90 °C
2019-08-05 04:42:49.212 [DEBUG] [converter.ZigBeeConverterTemperature] - 286D970001050CFC: ZigBee attribute reports ZclAttribute [cluster=TEMPERATURE_MEASUREMENT, id=0, name=MeasuredValue, dataType=SIGNED_16_BIT_INTEGER, lastValue=2663, lastReportTime=Mon Aug 05 04:42:49 CEST 2019]
2019-08-05 04:42:51.853 [DEBUG] [converter.ZigBeeBaseChannelConverter] - 286D970001050CFC: Channel zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_temperature updated to 26.63 °C
2019-08-05 04:42:51.858 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Updating ZigBee channel state zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_temperature to 26.63 °C
2019-08-05 04:50:27.511 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling...
2019-08-05 04:50:27.517 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_batterylevel
2019-08-05 04:50:35.522 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_batteryalarm
2019-08-05 04:50:43.526 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_water
2019-08-05 04:50:51.530 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_tamper
2019-08-05 04:51:02.809 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_batteryvoltage
2019-08-05 04:51:10.819 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_temperature
2019-08-05 04:51:18.828 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001050CFC: Polling zigbee:device:01382722:286d970001050cfc:286D970001050CFC_1_iaslowbattery
2019-08-05 04:55:23.184 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling...
2019-08-05 04:55:23.188 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_intrusion
2019-08-05 04:55:31.193 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_batteryvoltage
2019-08-05 04:55:39.197 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_batteryalarm
2019-08-05 04:55:47.201 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_motion
2019-08-05 04:55:55.206 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_iaslowbattery
2019-08-05 04:56:03.211 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_batterylevel
2019-08-05 04:56:11.216 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_temperature
2019-08-05 04:56:19.221 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D97000105CA1F: Polling zigbee:device:01382722:286d97000105ca1f:286D97000105CA1F_1_tamper
2019-08-05 05:06:00.150 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D970001032626: Polling...
As I said if I unplug and plug the USB seems to recover, any ideas?
- Hardware: Raspberry PI3 Model B (ARM)
- OS: Raspbian GNU/Linux 9.9 (stretch)
- Java Runtime Environment: Zulu8.38.0.163-CA-linux_aarch32hf / build 1.8.0_212-b163)
- openHAB version: 2.5.0~M1-1
