Hey Guys,
im new to openHAB.
Is there something similar to blockly ?
Thanks for your help!
Hey Guys,
im new to openHAB.
What is blockly. Can you provide a refence?
Hey and thanks for your answer.
Sorry i tought it is well known ^^
blockly is a visual code editor.
It can be integrated to ioBroker to build automations.
Would be great if it could be used in openHAB too.
Is Node-Red the kind of thing you’re looking for?
It works very well with openHAB2
The openhabian script has an option for installing it, or you can do a manual install and just add the openhab_v2 (version 1.1.17) set of nodes
HABMin contains a graphical rules editor/creator that is similar - check the OpenHAB docs here
Or as @MDAR says, use Node-RED
That is obsolete has not worked for quite a while now.
Hey and thanks again!
they both look really cool, i will try them!
Hi @vzorglub - I’ve never used it, just saw it in the docs ![]()
Blocky works in Node-RED. So I would go the Node-RED route.
Thank you so much for posting this.
My JavaScript programming skills are terrible, so this is a great solution.
All I have to do now… is learn Blocky… ![]()
