My goal is to get a volume slider to control the volume of my powernode (and slaves). I have looked into this topic but I can’t get it to work.
What I have done so far is:
I created a volume channel (number) under my existing Bluesound thing. Filled out the command extension
with Volume?level=%2$s (taken from the previous post). After that I created a volume item (dimmer) and linked it to the volume channel.
I am not able to control the volume right now. The slider shows changing volume numbers.
With the command http://10.10.10.111:11000/Volume?tell_slaves=1&db=2
in my browser I can put the volume louder. With -2 at the end the volume will get softer.
This is the code from the channel.
UID: http:url:5651c472bb
label: Bluesound
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: http://10.10.10.111:11000
delay: 0
stateMethod: GET
refresh: 2
commandMethod: GET
contentType: application/xml
timeout: 3000
bufferSize: 2048
channels:
- id: Status
channelTypeUID: http:number
label: Status
description: ""
configuration:
mode: READWRITE
stateExtension: Status
- id: Volume
label: Volume
description: ""
configuration:
commandExtension: Volume?level=%2$s
And Item
label: Volume
type: Dimmer
category: ""
groupNames: []
groupType: None
function: null
tags:
- Point
This is the warning from the frontail viewer.
Requesting 'http://10.10.10.111:11000/' (method='GET', content='null') failed: 404 Not Found
I also used this API document from Bluesound.
At this moment I am stuck and any help is appriciated.
